Question about Makita DCS6421 64cc Chainsaw with 20" Bar & Chain & 84cc Upgrade Option - DCS 6421 BB 84
Need to remove the clutch assy on a makita dcs
2 Suggested Answers
SOURCE: Can't get clutch plate off of makita 340 dcs
Thank you bobcatman. i am assuming that left hand thread translates to moving the clutch plate clockwise in order to remove. I sure appreciate the full explanation.
sincerely
john
Posted on Oct 21, 2008
Bit stuck makita HR5210C How do I remove it.
Strip the chuck assy and see if you can pry the broken bit forward. If it is really stuck then the front Assy will need to be stripped.
Mar 12, 2014 | Drills
How to separate the crankcase on a Makita dcs 540 chainsaw?
You can see how to repair this saw in the Makita DCS540 Manual. It is around page 28 I think.
Feb 05, 2013 | Makita Dcs 540, 20" Chainsaw Chain 78dl...
How do you remove the clutch on a makita 8406 have split the body so far ..thanks
How is the clutch removed from the makita 8406 core drill
May 15, 2011 | Makita Drills
My Makita 3.0ah cordless drill does not drive anything when I put pressure on it. Would the clutch be worn and if so is it easy to repair?
Clutch is part of the transmission assy - yes it is about the only thing that it can be causing your issue. It is a fairly inexpensive and easy fix on Makita - the worst part is removing the chuck.
Jun 25, 2010 | Makita 18V 1/2"CRDLS Drill Kit
How do I take the chuck assy. off a Makita 12 volt drill driver?
open chuck up all the way, and look down inside for a screw at bottom that needs to be removed, then twist it off.
Apr 11, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
MAKITA DCS 341 SAW IS NOT OILING BLADE-HOW DO I REPAIR?
I was able to find an OM but no IPL and it is not a current model. With no IPL as a disassembly guide I cannot get into specifics. Makita is the parent company of Dolmar (German and actual manufacturer). A local Dolmar dealer may be able to help. You might also find help and guidance here:
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
Beg for manuals thread (ArboristSite) (free to join)
http://www.arboristsite.com/showthread.php?t=72322
A large international collection of chainsaw enthusiasts dealers (more than one Dolmar dealer on hand) and mechanics.
I found a current DCS34-16 IPL here:
http://www.makita.ca/index2.php?event=tool&id=270&catid=40
it has an inboard clutch so I fear it will be of little value.
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL that I cannot find). The folk at ArboristSite are very helpful. That is where I would go at the unsuccessful completion of 1. HTH
Lou
Feb 09, 2010 | Makita Garden
you need a piston stop to stop the engine from rotating,then with a clutch tool you can spin off the clutch,most of them are left had thread.if you don't have a clutch tool you can use a hammer and punch on one of the main arms of the clutch itself.for a piston stop you can use a piece of 1/4"rope.put the piston at the bottom of the stroke and stuff the rope in the sparkplug hole,this stops the piston from reaching it's full stroke.
Oct 20, 2008 | Makita DCS51018 18" 45cc Chain Saw 2 Cycle
I am trying to find the magneto gap for amakita dcs 340 petrol chainsaw
use a regular post card inserted bet fly wheel and mag close enough
Oct 05, 2008 | Makita Garden
Makita 8444d mxt drill
what is the setting in your clutch. if you set the clutch to the highest setting and it`s still slipping then you need transmission assy.
May 28, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Makita DCS6421 64cc Chainsaw with 20" Bar & Chain & 84cc Upgrade Option - DCS 6421 BB 84 Logo
97 people viewed this question
Top Makita Garden Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you a Makita Garden Expert? Answer questions, earn points and help others
