Question about Samsung Refrigerators
Samsung Model# rf268abrs. Why is my filter leaking?
I have installed 2 filters and it still continues to leak, Why?
  • 61 Answers
SOURCE: using without water filter
The effort it would take to eliminate filter would be too much. Just leave filter in place. If new house filter is working right you should never have to replace fridge filter and your water will be double-filtered :)
Posted on Jul 03, 2008
  • 74 Answers
SOURCE: water leaks when filter is connected
Does it leak from the back or the front of the appliance ??
Posted on Aug 28, 2008
SOURCE: The water input to the water filter is leaking - admiral model GC2224GEKB
my water filter water line is leaking from the bottom in the back of my refrigerater. How can i get to it to repair it.
Posted on Oct 09, 2008
  • 172 Answers
SOURCE: GE Profile water filter housing leaks
Hi there is a grommet you can replace.
#WR02X10678 it is about $7.00 It can help seal the plug sometimes. Ge does want you to buy the whole filter assembly it is number
#WR17X11618 $51.50 . You may also consider putting a new filter in. It seals better than the plug it is number
#gwf $42.95. I dont know why they dont sell a o-ring kit. I guess they just dont make much money on o-rings. I hope this will help you. Have a nice day.
Michael Anderson
Anderson Appliance Repair
(865)945-3808
Posted on Feb 17, 2009
SOURCE: Water filter leak Whirlpool ed25rfxfw01
I have an undersink filter from Whirlpool that is leaking also. I had an older one that also leaked and I replaced it. Worked fine for about six months then water all over under the sink. I believe it is leaking from the O-ring which seals the body and the cap. I think they have a lousy design and will look for another filter.
Posted on Jan 01, 2010
Why does water leak after cleaning the filter?
If you have the manual handy, check the debris filter removal and reinstallation procedure. There may be some little thing that can spell the difference between leaks and no leaks.
Aug 11, 2015 | Samsung WF218ANW 4.0 cu. ft. High...
What else can cause this leak
there is a plunger inside them takes o rings too
May 02, 2015 | Refrigerators
Hayward sand s166t. leaking from bottom
Are you sure it is leaking from a spot "Originating" at the bottom? Many times this is what is seen, but the water is actually traveling down the side.
If at the bottom, you either have a cracked tank, or the drain cap is loose, missing the cap gasket or it is on "Cross Threaded"?
But... most likely from experience, it leaking at the valve clamp.
Nov 17, 2012 | Hayward S166T Pool Filter System w1 HP...
Gxrlqr filter leaks
MAKE SURE THAT WHEN YOU REPLACE THE FILTER IT IS IN THE SAME ORDER AS THE ONE YOU REMOVED OR THAT IT IS THE SAME MODEL TYPE REPLACEMENT , I WOULD TRY TO TURN IT AROUND FIRST , A THIN WRAP OF "WHITE PLUMBERS TAPE" , AROUND THE SCREW TOP INNER SEAL MAY CORRECT THE LEAK , ABOUT THE FILTER , WELL , IT MAY JUST BE SIMPLY IN THE REVERSE ORDER , TRY TO FILP THAT OVER , AND WHEN YOU RESEAL THE CAP ON THE FILTER MAKE SURE THAT THE SEAL IS ON PROPERLY , APPLY PLUMBERS TAPE ONCE AROUND , AND *"BEFORE YOU TIGHTEN IT" , GENTLY , REVERSE THE CAP BACKWARDS , SLOWLY , UNTIL YOU FEEL IT "SEAT " PROPERLY , "THEN" YOU MAY TRY TO RE-TIGHTEN IT . THIS SHOULD REMEDY YOUR LEAK , IF IT CONTINUES MAKE SURE THEN THAT YOU HAVE THE CORRECT REPLACEMENT FILTER MODEL FOR YOUR PARTICULAR ITEM . HOPE THIS HELPS YOU . NOW GO FIX IT ! GOOD LUCK .
Aug 19, 2012 | General Electric GE SmartWater Household...
Replaced DA29-00003B water filter in Samsung Refrigerator (RS2530BBP), with DA29-00003G filter. Water comes out extremely slowly....any suggestions? Tried holding ice type button for 3 seconds and...
Recheck you steps and see the warnings:
1) Turn on the main water supply & shut-off valve of the water
supply line.
2) Run water through the dispenser until the water runs clear
(6~7 minutes). This will clean the water supply system and
clear air from the lines.
3) Additional flushing may be required in some households.
4) Open the refrigerator door and check if water leaks around
the water filter.
Remove any residual matter inside the water supply line after installing filter.
NOTE :A newly-installed water filter cartridge may cause water to briefly
spurt from the dispenser.
Jun 04, 2011 | Samsung AquaPure DA2900003A Refrigerator...
Oil leak from oil filter i thimk or its from very close to the filter
Your leak could be the result of a missing oil filter gasket or an improperly sealed oil filter gasket. Remove and inspect. either way, the fix should be easy.
Please remember to rate this solution.
The FixYa Team.
Feb 04, 2011 | 2000 Pontiac Grand Am GT
Water leaks into cabinet fron filter
You need a new filter housing to stop this from happening. You can repair this yourself and save a ton of money!!
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7 AM until 7 PM CST with your brand and model number and we will get the correct part out to you asap. We also provide part removal/installation instructions for you when you get your parts through us.
We hope to hear from you soon and we hope you have a terrific New Year! Thanks, Ella
Jan 08, 2010 | Refrigerators
FILTER LEAKS!
go to the hardware store or even a home depot or lowes and get some plumbers pipe dope........a small tube will be plenty. remove the filter and dope up the areas where the two components hook together. it is magical.
May 20, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
When engine is running a squwishing sound and oil leaks from somewhere around the oil filter
around the oil filter where the filter screws on? like right there where the open end of the filter and the motor meet? If so, either #1 you have the wrong filter, #2 filter not on tight enough, or #3 the gasket from the OLD filter is still on. For problems #3 remove filter and check for 2 gaskets, remove one. Retighten. #2 Tighten filter a little more. If you have to use a tool, odds are you're doing it WAY TO MUCH and it's a different problem. #1 recheck filter number with vechile make, model, and engine size. If that's not where it's leaking from, please be more precious about where it's leaking from.
Apr 27, 2009 | 1992 Chevrolet G20
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
