Have vintage Fairfield planters Clock Model 4. Need help doesn't work
Just purchased it. Doesn't come on when plug in. What should I do next to find out why it doesn't work
  • 1082 Answers
SOURCE: 1 charger doesn't work. Set
Retun it for replacement under warrenty. Check your reciept or other doc for return procedure. May have to go to manufacturer.
Posted on May 07, 2011
dunnbiker
  • 8546 Answers
SOURCE: my remote on my Model
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes. Or check eBay - much cheaper.
Posted on May 10, 2011
SOURCE: I have a mp3 player
Dear Consumer,
We regret and apologize for the inconvenience caused to you.
We would request you to kindly share your contact details or contact the Philips Consumer Care on below mentioned details.
Thanks & Regards,
Philips Consumer Care, India customercare.india@philips.com 1800-102-2929 1860-180-1111
Posted on May 14, 2011
  • 21 Answers
SOURCE: The dvd driver doesn't work.
Did you check your DVD player program setting?
What about DVD region setting for? (If you use non-us DVD like PAL.)
Posted on May 28, 2011
Ironfist109
  • 3018 Answers
SOURCE: I can't turn off either
  • Hi, I can help.
  • As long as the alarm indicator is illuminated on the LCD screen the alarms will sound.
  • To get rid of the alarm indicator press the "enter" button on the top of your alarm clock. No more alarms at all.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for leaving FixYa.
Regards, Tony
Posted on Aug 24, 2011
Sharp Carousel Model R-209KK-W is flashing all 8's and keypad not working
The first thing to try is to do a hard reset.
Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it still doesn't work, it may need repair, which can be done for $39.95 in most cases.
Jun 10, 2012 | Microwave Ovens
I've changed battery in isys+ pre amp on vintage vec500 and now tuner doesn't work (it is blinking green on note tuner no matter of tune and no note letters showing - blank screen)
Is the battery installed in correct polarity? If so- try rotate it in position to rub through potential corrosion.
Since it has a remote battery, it would not hurt to look at the installation to make sure no wires are broken. Especially the ground wire to the pickup.
It might also be a good idea to apply some contact cleaner to the output plug since it is in the power circuit. Cycle the plug in and out a few times to clean the contacts. Also some contact cleaner to the preamp controls would be useful.
Be aware some lubricants may contain silicone and that can interfere with wood finishes or repairs to the finish in the future.
Apr 06, 2012 | Music
Got a 4 channel amp but can only use 2 channels, dont know why//
Did you check the fuses on the amp. If one of them has blown, this will shut it down. You will also need to check to make sure your RCA cables from the unit aren't crimped. This could kill the signal. Have you swaped the RCA cables to see if the other side works. If so and it still doesn't, check thos fuses. If this still doesn't help, you may have internal problems with your amp. Hope this helps
Aug 19, 2011 | Car Audio & Video
The maytag skybox doesn't get cold anymore. we had it outside for a while (we didn't realize you couldn't have it outside) & it worked great all last summer. this spring, we realized it...
First you need to find out if the compressor is kicking on or not. If it isn't then it could be the starting capacitor (item 23), start relay (item 7) or the compressor itself. Since you had it outside I would suspect the capacitor or relay. http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Refrigerator-Parts/Model-MBV1976AAB/3048/0168000/M0510224/00001
Does the skybox make noise (like your refrigerator starting a cycle)? If not, I would unplug it for a short while and let it set. Then when you plug it back up listen for noises on whether the compressor kicks on or not. If it doesn't then you can check the cap and relay board. Or have your compressor checked for operation and freon.
Jun 21, 2011 | Maytag SkyBox MBV1976A Beverage Dispenser
We are trying to replace the belt on the bissell 89q9 model. We purchased belt 8 and got in onto the brush however the brush doesn't spin anymore. Even trying to turn it by hand doesn't work. One...
Remove the beater brush assy & remove the
shaft & brgs that go through it 7 clean out the
hair,fuss ect,so it will turn
You need to take your vacuum apart once a year or more
to clean things so they continue to work
May 22, 2011 | Vacuums
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
No name on the oven so presume it's a Europa same as the cooktop. It won't move off 0:00 with automatics on the lefthand side showing.
Hi -
I'm assuming this is an Omega/Creda Europa oven. All you need to do to make the oven work again is set the clock. The 0:00 and "AUTO" will stop flashing and the oven will work again. You didn't specify a model number, but you should be able to set the clock as follows:
1. Hold down the two buttons on the left-hand side under the clock display. One should have a symbol of a bell and the other, a symbol of a cookpot (not a cookpot and 'STOP').
2. While still holding both of these buttons, use the + and - buttons to set the clock to the correct time. The clock needs to be set in 24 hour format.
If this doesn't work, look for the buttons under the clock with the bell symbol and the cookpot symbol. Hold both of these buttons in and use the + and - buttons to set the clock.
If this doesn't work or your clock doesn't have these buttons, let me know and I'll check for other possible methods of setting the clock on Europa ovens. If you can find the model number it would assist me greatly. This should be on a sticker on the rim of the oven and can only be seen when the oven door is open - possibly at the bottom. The model number should be something like 40-1, 60-1 or 66-1.
If you can't find the model number, please let me know how many buttons there are in total below the clock and which symbols are written above each button and the order from left to right. I will then be able to provide the correct instructions for your oven.
Hope this helps.
Regards,
BElectric
Apr 18, 2011 | Ovens
43 people viewed this question
 Grubhead
Grubhead
