How can I bolt down my TV stand on. A Sanyo dp4841?
I have a 42 inch Sanyo plasma TV how do I remove the stand
Consult owners manual or if you do not have it GOOGLE the model number with manual after it.
Most of these sets must be CAREFULLY LAID FACE DOWN AND BOLTS REMOVED TO RELEASE THE BASE FROM THE SET.
Do not try that without the instructions in the manual.
Mar 11, 2012 | Sanyo Televison & Video
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the four screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all four screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
My sanyo tv stand by light keeps flashing and it wont turn on can you tell me whats up with it
i have 32inch sanyo tv i have blue light on front whitch comes on when on stand by it wount come of standby eney idears on how mutch it will cost to get fixed x
Nov 13, 2010 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
How do I take the stand off of my sanyo tv
try flipping the tv on its side so you can see the bottom there should be screws on the stand going into the tv uscrew it and the stand should come off
Apr 06, 2010 | Sanyo DP42746 42 in. Plasma Television
Sanyo DP19649 - how od I unlock the stand pivot so
Sorry you can not pivot the table stand on the tv. If it is a wall mount can you give model # and make. Or you can look in back of the tv and you should see the pivot point in the center of the bracket that holds it to the wall.
Dec 27, 2009 | Sanyo Televison & Video
Mounting to TV Stand
there are two types of stands, some are wall type which needs to be mounted using rawl bolts, nuts are suppose to hold a stand, some are ground stands which are suppose to be put on a flat surface in order to balance.
Jul 29, 2008 | Panasonic TH-50PZ77U 50" Class Plasma HDTV
TV Stand
Start at the link below. Select your country, and then look for customer service, or support. They will tell you who their dealer is in your area for Sanyo parts and service. You will be guaranteed to have the proper parts.
http://us.sanyo.com/home.cfm
Jerry G.
Mar 30, 2008 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
