Question about Itomic IMID10MT 10" Android 2.3 Gingerbread Tablet w/ 1.14GHz ARM11 Processor, 512MB RAM, 4GB Internal Storage, 1024 x 600 Resolution, 16:9 Aspect Ratio, Capacitive Touchscreen, Integrated Webcam, Microphone, Speakers, Gyroscope Sensor, Headphone Jack & HDM
My tablet will not turn on
Tablet was on and working this morning. I turned it off for a couple of hours and now will not turn on. When plugged in on the charger the blue light comes on , but tablet will not turn on.
    Problem Solver:
  • 7 Answers
While it plugged in to the charger just reset the phone..but as you know all the data will be gone
Posted on Jan 06, 2013
How do i reset tablet if tablet is not turning on
Since you didn't mention the brand name, etc, I'm going to give you some basic instructions that hopefully will reset your tablet to at least get it turned on so that you can do a more in-depth troubleshoot.
You're going to have to drain the battery battery first of all, and even though you cannot turn the device on, just leave it be with the battery inserted for 24 to 48 hours. After that, you'll need to plug the tablet into a charger and allow it to charge for a full, normal cycle (4 to 8 hours, depending on your tablet.) After that, try turning the tablet on again.
If that doesn't work, remove the battery from your device for about 10 minutes and while the battery is removed, hold the power button down for 10 seconds. Replace the battery and try to turn the device on.
If the steps above don't work, then the best idea is to take it to a qualified repairperson for diagnosing the issue.
Mar 03, 2016 | Tablets & eReaders
Why doesn't it turn off using switch?
Hold button down for a couple seconds. A screen should pop up asking to turn off device. Say yes. Hope this helps!
Jan 31, 2016 | ASUS Google Nexus 7 Tablet
Tablet not charging while plugged in
Turned off the tablet, unplugged the charger and kept the tablet off for about 30 minute to one hour, plugged in back the charger, then turn on the tablet. After that I you might see the tablet started charging. Good Luck.
Jul 10, 2015 | ASUS MeMO Pad HD 7
Why won;t my irulu 10.1.1 tablet turn on. i push the button and nothing happens, when charger is plugged in it gets warm both tablet and plug
It sounds like you've done most of the things you would reasonably be expected to do to make it function; since it is only 2 months old I would strongly urge you to go back to the retailer and make them replace it or refund you, as your rights in most countries/states allow.
If you're set against doing this, try holding down the power and volume down key for at least ten seconds to see if this boots it into hard reset mode. If this doesn't do anything, try again holding down power with each of the other buttons to see if you can activate any other developer/reset modes.
However, I have read reports that this particular tablet has up to a 40% failure rate in its first six months.
If you can possibly get it refunded, do that and buy something else.
Jan 02, 2015 | Irulu 10.1 inch Android 4.0 Touchscreen...
Android tablet won't turn on
Please make sure the tablet is charged for at least 4-6 hours. Also, make sure the correct button is being used, oftentimes we hear the back or home button has been used in error. If the issue persists, you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
Support Troubleshooting Guide
Feb 20, 2014 | Kocaso M1060W Tablet
Tablet wont turn on
Hi Leah.
if you plug it again is it indicate charging.
if yes it can be power button problem.
if not it can be softwear or hardwear error.
you have to repair it.
regards,
nuwan
Jan 10, 2014 | FUHU nabi Jr. 5" Capacitive Touch Android...
Why does my tablet when i turn it on it has a battery sign with an explanation mark inside it and will not turn on
The exclamation mark means that your tablet has no battery left. You should try plugging your tablet in for a few hours before turning it on (if it doesn't turn on by itself.) If that doesn't work and you still see the exclamation mark, I suggest that you ensure the charger is properly plugged in to the socket and that its properly attached to the tablet.
Sep 05, 2012 | Tablets & eReaders
Itomic IMID10MT 10" Android 2.3 Gingerbread Tablet w/ 1.14GHz ARM11 Processor, 512MB RAM, 4GB Internal Storage, 1024 x 600 Resolution, 16:9 Aspect Ratio, Capacitive Touchscreen, Integrated Webcam, Microphone, Speakers, Gyroscope Sensor, Headphone Jack & HDM Logo
260 people viewed this question
Top Itomic Computers & Internet Experts
David Payne
David Payne
Are you an Itomic Computer and Internet Expert? Answer questions, earn points and help others
