Question about Destroyit 2601-2 Shredder
Destroyit shredder 2601 will not turn on.
There are no lights on the panel. Can't find a fuse. The full switch is working ok. The bin is not full.
Do you know here I can get a repair manul and parts?
  • anthonyzig May 11, 2010
    I can provide parts if you can provide me with the serial number.
SOURCE: Staples SPL-1506X Shredder Issue
I had the same problem. I have a solution but I do not recommend this unless you have technical experience with repairing electrical appliances. I took the back cover of the main shredder unit to expose the wiring (there are 7 screws in total). The bin full sensor has a blue, green, and red connected to it. I clipped the blue wire to defeat the Bin Full error. You can look through the plastic window to check that the bin is full.
Posted on Aug 09, 2008
FixinFax
  • 3085 Answers
SOURCE: I need help in trouble shooting my staples
Therer should be a tab hanging down that senses when the paper height trips it.
Blow into the sensor with canned air.
Posted on Oct 13, 2009
  • 610 Answers
SOURCE: SHREDDER INDICATOR KEEPS COMING ON WHILE SHREDDING
look for two LED lights where paper falls into bin and wipe them off, but the sensors could be faulty as well. I have seen both.
Posted on Nov 11, 2009
  • 3 Answers
SOURCE: destroyit 4104 manual
I know that shredderparts.com has parts for it, but I don't know about the manual for this machine.
Posted on Nov 18, 2009
  • 86 Answers
SOURCE: destroyit 3102 drive gear part number
The part number you need is 2601 062 as long as your looking for the gear that meshes with the motor shaft. The price is around 25.00 dollars and phone number for destroyit or as known MBM corp. 800-223-2508
Hope this helps leave feedback if so. If you have trouble getting part contact me i'm a dealer and can get you the part.
Posted on May 17, 2010
When bin was full, I emptied it only to find that my shredded no longer worked on auto, forward or reverse
Dear Sir,
Maybe, just maybe, I have an answer for you.
Somewhere on the part of your shredder that touches the bin, there is a tiny switch that touches the bin, and it is a safety switch that causes the shredder to stop working if the bin is removed.
In the shredder I have, and have had, the switch is usually plastic, and is the same color as the plastic body of the shredder.
Proper positioning of the bin to the "bottom" of the shredder is critical to it's working, as the bin presses on the switch to "close" it.
God bless your efforts.
May 09, 2016 | Techko SH1524CP Shredder
Destroyit 5009 Shredder No power to the oil pump.
Investigate the operation purpose of the Oil Pump. Did you measure the voltage across the terminal or observe that the pump was not operational. It must have an auxiliary function that is not related to main operations. Investigate the purpose of the Oil Pump and deduce what would make it operate then check that switch if their is no voltage measured across the pumps terminal when it should be operating. This deductions may help lead to the problem and a solution.
Aug 27, 2013 | Destroyit 5009 Shredder
Destroyit 2600 manual
Sorry, I need a parts manual for a cross cut 2600 shredder
Oct 04, 2011 | Destroyit 2601-2 Shredder
We have a destroyit 2602 cross cut shredder, when we put the paper to be shredded in, the shredder would go on automatically, now that does not hapeen. we have to manually press the on button.
The paper sensing switch lever has bent or broken or the switch is faulty. Check between the wheels about in the middle of the shredder to see if you see if the little plastic finger. If the finger is visible and can be moved, the switch is faulty. REMEMBER TO UNPLUG IT BEFORE DOING ANY INVESTIGATION.
Feb 20, 2011 | Destroyit 2602 Shredder
Destroyit 3102 drive gear part number
May 14, 2010 | Destroyit 3102 Shredder
Office max shredder, says bin full but its not, only half full
I had the same problem. I found that the sensor on the shredder is light sensitive. The viewing window in the bin was letting too much light in and was triggering the bin full light to turn on. I covered the window with a piece of paper and then restarted the shredder.It worked fine after that.
Feb 08, 2010 | OfficeMax 0M96431 Shredder
The basket full light will not go out
YOU WILL HAVE TO HAVE SENSORS REPLACED
Sep 15, 2009 | Fellowes DM15C Shredder
Fellowes shredder will not work
Check the front door switch and the BIN FULL switch actuator.
Oct 22, 2008 | Office Equipment & Supplies
DM15C stops after 4 seconds, open bin light comes on
I lived with the problem for 6+ Months -- drove me NUTS -- Today, I called Fellows -- Spoke to "JoAnn"... She said this works 80% of the time...
Pull out the bin -- put your foot inside to hold the shredder down -- pull up on the top of the shredder -- you WILL hear a POP as the plastic top disengages from the bottom but TRUST ME THIS IS OK! -- take off this top section (which houses the blades) -- flip it over -- you will see 6 screws total but it is the sets of 2 screws close together to focus on -- right next to the screws you will see a tiny glass sensor -- use a q-tip and alcohol to give them a wipe -- press the top back on -- bin back in -- you are DONE -- This took me less than 1 minute and it works as it did the day I got it! Go shred something!  :)
Feb 09, 2008 | Fellowes DM15C Shredder
Destroyit 2601-2 Shredder Logo
150 people viewed this question
Top Destroyit Office Equipment & Supplies Experts
Tom Chichester
Jean DeLauche
Jean DeLauche
Are you a Destroyit Office Equipment and Supply Expert? Answer questions, earn points and help others
