Hdd lg dvd recorder rh399h says incorrect region code; can't play back
SOURCE: LG RH1999H DVD HDD Recorder
1. Turn machine on
2. Use remote to open disc tray
3. Use remote to go to setup area of menu (Home - Left) and scroll down to 'Lock' symbol
4. Press 0 seven times
Posted on Nov 01, 2007
SOURCE: Playing region 1 DVDs in LG DR165 receroder
go to dvd set up then scroll dow to lock then push 0 seven times
Posted on Feb 04, 2008
jaffa012001
  • 376 Answers
SOURCE: region free unlocking code for LG RH2T80 DVD Recorder
Goto 'Setup'
Scroll to 'Lock' (don't scroll sideways from here)
press '0' seven times
press 'Enter'
Posted on Oct 19, 2008
SOURCE: incorrect region codde
This is for DVP31XXX series i hope it works all on DVP31 series. It has been tested on DVP3146K /51 and it has been worked...
1. Make sure there is no disc in the player.
2. Turn power off and on again.
3. Open the tray.
4. On the remote, hit 9879 and then 0. This changes unit to Region 0, meaning it'll play all regions.
5. Hit OK on the remote.
Good Luck Guys!
Posted on Oct 27, 2008
SOURCE: LG RH387 HDD DVD Player wil not play Disc's from other Regions.
1. Go to http://hk.lge.com/support/support_lgeservice.jsp
2. Go to "Product Support"
3. On the left panel, find "Device Driver", then "DVD Player/Recorder".
4. Download the "RH3xx.iso" from the linked page.
5. Burnt ISO to a CD (must be burnt as an image, use free software such as ImgBurn http://www.imgburn.com/)
6. Load CD onto the LG player
7. You will be prompted to choose a new region code - go with 0 for region-free
Posted on Mar 30, 2009
LG DVB-T HDD/DVD RECORDER MODEL RH2T160 REGION CODES
hi,
try the following to make ur dvd playre region free.
p { margin-bottom: 0.21cm; }
1.Power ON
2.Eject Tray in DVD Mode
3.Press "0" seven times
4.Enter "0" as New Region Code
5.Press Enter
ur player will become region free
ok
Dec 27, 2010 | LG RH177 DVD Recorder/HDD Recorder
I own a lg rh399h dvd recorder. I have finally figured out how to record from dvd to hdd, but it records in real time (slowly). Does anyone know how to :fast copy'' from dvd to hdd???
LG HDD/DVD RECORDER RH399H
Insert an empty DVD + R. The system asks whether to format - Format.
Select a recording on the HDD to copy to DVD.
Enter
Select dubbing
with arrows select type of recording to make (XP, SP, EP etc)
The system show the duration you can copy to you DVD. If small enough the FAST option also appears.
If big copies while playing the orriginal (I.e. playback speed)
Aug 28, 2009 | Audio Players & Recorders
Jan 12, 2009 | LG RH1999H DVD Recorder/HDD Recorder
Need to play region 1 DVD in region 2
I just got a RH387H in Hong Kong, region 3, but the above method doesn't work, this model has slightly different icon, no "lock" icon, I tried in other similar location but no effect, hopefully someone will provide a method.
ipw
Jun 28, 2008 | LG RH1999H DVD Recorder/HDD Recorder
hi
try a search on your dvd here check for region codes dvd
riz.
May 31, 2008 | LG RH177 DVD Recorder/HDD Recorder
Jan 23, 2008 | LG RH177 DVD Recorder/HDD Recorder
SAMSUNG HR733 DVD RECORDER WILL NOT PLAY ANY REGION DISCS AT ALL
On page 45 of the user manual it says this:
Both the HDD & DVD RECORDER and the discs are coded
by region. These regional codes must match in order for the
disc to play. If the codes do not match, the disc will not play.
The Region Number for this HDD & DVD RECORDER is
described on the rear panel of the HDD & DVD RECORDER
If you changed the region codes on your player it will not work. They should be set back to 1 or whatever your model says on the back of the unit.
If this unit was purchased outside the United States, it may not work in the United States.
Here is a copy of the manual if you need it:
http://downloadcenter.samsung.com/content/UM/200506/20050618115856781_HR720-00758C-XAC-Eng_0519.pdf
Dec 08, 2007 | Samsung DVD-HR720 DVD Recorder
Can this play all regions?
Press Setup
Scroll to Lock
Press 0 (7 times)
A message will appear saying it is region free
Nov 06, 2007 | LG RH177 DVD Recorder/HDD Recorder
LG RH277H - won't play bought DVD'S
The cd tray eject after put in the DVD movies, but VCD working fine...it is means that the drive's region code haven't set yet .(please refer to user manual to setting the region code) ..or unplug the recorder drive from the dvd player,using the computer setting to change the region code by connecting to computer's IDE cable .
Oct 19, 2007 | LG RH177 DVD Recorder/HDD Recorder
Ld dvd hdd player rh7624w recorder
To make the unit play all regions do the following: 1. Put in a DVD that will play (in our case region 2) 2. When it starts playing, press eject 3. While the drawer is open press "0" seven times 4. When you get the "Congrats" press Enter and done! Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 12, 2007 | LG DR197 DVD Player/HDD Recorder
Televison & Video Logo
112 people viewed this question
Top Televison & Video Experts
