Question about Sunbeam Kitchen Appliances - Others
Sunbeam vt40 the toaser drops for a few seconds every minute or so
Adjust the screw on the bottom which adjusts the tension created by the heaters. If this doesn't work, "bump" it some to dislodge crumbs that may be inferfering with the trip lever for the thermostat.
If nothing works, try kitchenmade usa or toaster central who both work on and fix vintage toasters.
Frank@kitchenmadeusa.com
Posted on Oct 26, 2013
Why does my Sunbeam 5891 bread maker reset itself a few minutes into baking a loaf ?
If you have another setting, try that and see if it works without reset.
Oct 29, 2015 | Sunbeam Kitchen Appliances - Others
Vox vt40 factory reset
Consider reading the Manual for this amp, it explains how to reset to factory with the VFS5 footpedal. Or with the power off ..hold down CH1 & CH4 then turn power on.. when the Bank & Channel leds start blinking.. then release the Channel buttons. Next press the Tap switch ... the bank & channel leds will change from blinking to lit. with in a few seconds it will enter preset mode.
Apr 12, 2014 | VOX Amplification Vox VT40+ Valvetronix...
I have sunbeam .9cuft microwave model:SGB8901 may be a year old. Now as soon as I plug in, the microwave starts running. It runs as long as the door is closed. When i enter the timer it wont work. It...
follow this steps and fix it. God bless you
  1. Main control boardIf your microwave runs for a few seconds and stops, the first thing to check is the main control board to ensure that a shortage has not occurred. If the part is defective then it will need to be replaced to prevent continual shut offs. If this is not the issue, the next step would be to check for a faulty touchpad.
  2. Touchpad/Control panelIf the control board is not the issue and your microwave continues to shut off after running for only a few seconds, the next thing to check is your touchpad, which is also known as a control panel. Although uncommon for this issue, symptoms are usually that the display and some buttons are working properly; however, when selected some buttons are not functioning. If this is the case the touchpad will need to be replaced.
Oct 23, 2013 | Sunbeam Microwave Ovens
Sunbeam steam valet instructions
How to fill your Sunbeam Steam Valet
Here is how you fill your Steam Valet. Press the small button on the back of the handle and pull bottom of handle apart from the top half of steam valet. Then take off the white cap on the inside of the handle and fill with water to top. Place cap back onto the opening and slide handle back and click in place. Plug in and you're ready to steam within a few minutes. If it spits out water let heat up a little longer if that doesn't stop it then tie a thin cloth over the top part where steam comes out to keep the water from spitting out onto your fabric. Hope these instructions are clear enough. More questions about this iron go to www.manualslib.com.
Feb 29, 2012 | Sunbeam Irons
How to fix the minutes because on my clock the minutes are going like seconds?
Seems like the 'Set' button is stuck. This causes the counter to increment at 1 second intervals.
Feb 25, 2011 | Sunbeam & 60 Minute Timer
I have a healthometer model bfm884dqn-60 and i have already set the height the first time. how do i change it?
Took me a minute or two to figure this out. You hold the number of the user that you want to change (1-4) and then, while holding it down, you press and hold the 'select' button. The screen will blink, and after holding both down for a few seconds, a flashing 'Erase' message will appear. Select YES, and then you can enter new information.
Feb 06, 2010 | Sunbeam Healthometer Body Fat and Weight...
The heater keeps shutting off, i unplug and wait a few minutes, then try again it works for a few more minutes then shuts off again.
Defective thermostat is shutting it down before it reaches the correct temperature. Essentially the thermostat is acting too sensitive.
Finding parts could be tricky probably worth replacing for the potential repair cost.
Jan 02, 2010 | Sunbeam LowProfile Space Heater
Sunbeam SLP3310-UM shuts off after 2 minutes. I unplug it and hear a relay clicking after a couple of minutes. Replug it, and shuts off again after 2 minutes. It worked fine last year, not this year.
It's broken --- call Sunbeam customer service (888) 264-9669 and have your receipt and serial number ready. They are aware that these have faulty switches in them.
Nov 26, 2009 | Sunbeam Pool & Spa
Lost recipe manual book
Here is a link to download the manual.
Sunbeam 5833 Manual
When you get to this page click on the link to "Download the complete user guide"
You will then get a security window to enter 4 numbers that are shown. Enter the numbers in the blocks. Click on "Download the User Guide".
You can either open it, or save it. I imagine you will want to save it to your computer. To do so, click on "Save". A window will open. In the drop down menu at the top, select "My Documents". In the "File Name" box, backspace and name it something more recognizable (Sunbeam 5833 Manual). Click on save and it will be downloaded to your computer.
If you have any problems, comment back, and I'll help you further.
Thanks for using Fixya!
Nov 25, 2008 | Sunbeam 5833 ExpressBake Bread Maker
Sunbeam 2359 Mixmaster No Longer Turning On
Could be switch failure or failure of another component due to age.
Oct 27, 2017 | Food Mixers
Kitchen Appliances - Others Logo
102 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
