No picture,no sound. tv stuck on standby and does not respond with the remote control
It is a spectre flat tv. I could not find the model number since it is mounted on the wall, but on the front of the tv it has the following information: "ATSC.HDTV X37". Any suggestions to repair this?
  • 1,238 Answers
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Posted on Jan 06, 2013
  • 118 Answers
SOURCE: Attaching Wall Mount Support to AKAI Flat Panel
You use the four outer holes as suggested in the manual on page 12, see below:
Posted on Nov 18, 2008
ward_knutson
  • 64 Answers
SOURCE: Want to wall mount tv but don't don't were to bolt.
I have my 32" Protron mounted on my wall. There are six holes on the back of the set that you attach the mount. I cant find any links to pictures but it should be pretty straight forward. You should be able to use any generic LCD wall mount, just make sure it can hold an 32" since I made the mistake thinking all wall mounts were the same. I purchased mine at Best Buy but you should be able to find a mount anywhere. You will need to fasten the mount onto the studs in your wall. Drywall by itself will not be sufficient and cannot support the weight of the TV.
The wall mount should come with everything you need, e.g., screws, brackets, etc., with the exception of the tools. FYI... it's not going to be an easy job so be patient and take your time. It's probably going to take the good portion of a day. Also, as for the holes on the back, just be careful when performing the final mount to make sure it doesn't fall. It would be wise to have someone help you.
Posted on Nov 25, 2008
  • 125 Answers
SOURCE: need to take a flat panel tv off the wall mount
Here are a few spots you can try. Underneath, there might be locks that use alan keys. You might need a long alan key depending on how big your TV is. Unscrew these alan keys as much as possible. Some mounts require up to pull the bottom of the TV out and then lift straight up. Try using a flashlight and look all around the TV, Also check the top. Some have clips that need to be pushed to the side. These clips have holes in them and sometime held in with zip ties to keep them locking the TV, You will need to cut the zip ties. Hope this helps...
Posted on Mar 15, 2009
jerryg50
  • 1667 Answers
SOURCE: LG TV 32LB9D VOLUME STUCK AT 100, NO RESPONSE TO REMOTES
The fault may be on the control board. Sometimes the button switches can be stuck, or there may be something causing some conduction on the control circuit board. It is also possible to have a component failure that is causing a continuous command to keep the volume to the high position.
Something that causes failures of controls in TV sets is when people clean the screen, they spray liquid cleaner on the screen. Some of it drips down in to the controls and on to the circuit board. This will usually cause damage, and thus the set will require shop service.
Jerry G.
Posted on Apr 10, 2009
  • 11 Answers
SOURCE: How do i attach a Wall Mount to the TV?
I have the same TV, and I bought a mount with 4 connector holes. I was able to connect 3 of the 4 and it has been fine as the TV does not weigh too much. The TV was not designed with the current mode of either wall or stand mount. It was just intended for stand. I have had it on the wall for over 2 years.
Posted on Jan 02, 2010
Emerson tv model ld190em1 no picture or sound has a red standby light and will not respond to remote or controls on the tv
Bad power supply board..Mabe you could find the board at ShopJimmy.com
Usually around $35..
Jul 22, 2017 | Emerson Televison & Video
How can i repair a tv that turns on but has no picture or sound
Have you tried a factory reset? I had a similar problem my TV was stuck on standby (red light only) I did this
  1. Turn on the TV.
  2. Wait approximately 40 seconds for the TV to completely start up.
  3. On the TV remote control, press and hold the UP ARROW button
and it worked!
Oct 16, 2015 | Sony KDL46EX400 46 in. HD-Ready TV
MY SONY TV MODEL NUMBER-KDL-40S2510IS STUCKED ON STANDBY MODE. HOW CAN I UNLOCK IT MANUALLY
You should have its remote control to make it out of standby. In most cases, all remote controls for Sony devices should work with all Sony equipments with On/OFF, Volume+/-, & Program+/-. If you have any other Soney equipents' remote control, try it.
If the main board to your TV is faulty, it won't go beyond standby mode. You have to check this too.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 30, 2014 | Televison & Video
Samsung TV stuck on with picture and volume and no working controls on TV or remote
Sounds like main board fault. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy. Electro help
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 21, 2014 | Samsung Televison & Video
Bush 24 inch tv/dvd combi screen went blank as if it's on standby. won't respond to remote control. one week old. is it seroius?
try switching on tv point remote at the tv pressing the menu/exit button and holding for 10/20 seconds hope this works for you
Oct 07, 2012 | Bush Industries IDLCD26TV16HD LCD TV
Tv doesnt respond to buttons or remote
this is looking like a common LG problem our tv started doing this tonight
May 15, 2010 | LG 42LC2D 42 in. LCD HDTV
Stuck on standby
Neovia Neo-3775: Standby Led permanently on amber when powered up with no screen or sound. Does not respond to remote or to TV controls.My problem is same as Ed's posted in 2009 - any ideas?
Jun 22, 2009 | Philips TP2785C 27" TV
No picture or sound. MODEL #19LA20Q
The faint light indicates that there is not enough power being provided to the other circuitry as well the humming sound is a good indication that the power supply needs ot be replaced or repair. If your TV is less then a year old, still under manufacturers warranty.
Let me know if you require further assistance.
Dec 03, 2008 | Proscan 19LA25Q 19 in. LCD Television
No picture and a crackling noise when remote standby button is pressed
I will need the model number of your tv in order to help you. Sounds like a flyback arcing. Please respond to this same post with your model number.
Jul 06, 2008 | Televison & Video
Hyundai 42" Plasma TV
Try www.hyundai-world.com That is the manufacturers website. Good luck. Ask them if that set can played in the USA without a special power supply.
Nov 19, 2007 | Hyundai HPT-4250 Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
