Question about Mitsubishi VS-6055 60" Rear Projection Television
Older projection tv display issues. most objects have a white border on the right side.
I have a mitsubishi vs 6051 from december of 94. i recently noticed these problems occuring intemitently now it is constant. ive tried adjust all of the display options such as contrast and the like. i also realigned the test page where you move red and blue crosshairs. i dusted out the inside as well. someone had mentioned about the possibility of magnetized dust causing issues. any help or pointing in the right direction would be great.
  • terry fridley Jun 30, 2007
    the exact issue is that white shading appears to the right of objects in semi- bright scenes.its always to the righte. its almost as if someone just took white paint and outlined everything to the right of a darker edge.
  • 398 Answers
What exactly is the problem? There is no such thing as magnetized dust. Your convergence IC's only need to be replaced if you see that the red, green and blue are no longer lining up in the correct positions, especially around the edges. One common Mitsubishi problem in the older sets is CRT coolant leaking and dripping onto the main board. But we need to know exactly what the problem is that you are seeing before we can get more specific.
Posted on Jun 30, 2007
    Scholar:
  • 47 Answers
The problem is definitely in the convergence circuits. There two large ICS located on the convergence board. They both must be replaced. Also they both have current limiting resistors one on +15 volt supply and one on the _-15 volt supply. These must be checked and replaced if found defective. This repair usually runs about $300-400 dollars depending on the area you live in and the level of integrity of the technician. These are good TVs and usually have only a few problems , the convergence and sometimes the power supply. Scrivitron
Posted on Jun 29, 2007
    President:
  • 3,130 Answers
What is the problem? And I have heard a lot in my rime but magnetized dust??? You did not really say what the problem you are having.
  • Larry  Dillon
    Larry Dillon Jun 29, 2007
    Opps I have heard a lot in my TIME.
SOURCE:
Mitsubishi VS-55609 distorted Picture Flickers
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
May 14, 2010 | Mitsubishi VS-5059 50" Rear Projection...
I have a mitsu VS-45605 and it seems that all 4 main colors have split. is my tv toast?
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Mitsubishi VS-45605 50" Rear Projection...
My Mitsubishi VS-60621 seems to have a convergence problem
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Mar 05, 2010 | Mitsubishi VS-60621 60" Rear Projection...
The TV would periodically shut off, and not come back on for a while. It kept getting worse and worse, and now it wont turn on at all. You can hear a clicking sound when it shuts down. The TV is a...
Sounds like bad solder around the power supply or deflection circuits. take the back cover off and using something non conductive i.e a wooden salad spoon try knocking on some of the heatsinks and around the circuit if it reacts it may help you pinpoint the area of the problem. next you`ll need to pull out the circuit and solder the connections that look weak, they might have a ring like hairline crack around the solder joint. good luck and don`t forget to unplug before working on it.you dont want to end up with curly hairs
Nov 02, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Mitsubishi Big Screen TV Model VS-6051 will not turn on. I hear a clicking sound when I unplug it from the wall but it still does not turn on.I have tried using an alternative power source and it still...
hello VS6051 POWER SUPPLY PULSATES ON/OFF IC9A1(267P062010)
VS6051 VZ2 POOR START L9A30(BEAD ON LEG OF R9A21)-R9A22 TO 1.2K, R9A12 TO 15K,C9A15 TO 330UF
VS6051 VZ2 POOR START,ADD 22UF/100V PARALLEL W/C9A17
VS6051 VZ2 WILL NOT POWER ON D9A00(264P102020) IC9A0(267P112050)
Sep 19, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Have a bow in the top of the screen for a Mitsubishi vs-6051
Call a good TV Tech and tell him the problem is the convergence amp IC's are bad and need replacing. This should not cost over $325
Jul 28, 2009 | Mitsubishi VS-6055 60" Rear Projection...
I have a Mitsubishi vs-4543 tv that when powered
check the power supply section.. probably the electronic component got problem.
Jun 04, 2009 | Mitsubishi VS-4544 45" TV
52" mitsubishi rear projection tv model vs6051 sound no picture
Not exactly familiar with this model but sounds like the projector lamp is burned out. Hopefully it's a replaceable type. Try calling these people - http://www.purelandsupply.com
Mar 29, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Mitsubishi vs-60705
Can you explain what the crack look like?
Dec 18, 2007 | Mitsubishi VS-60705 60" Rear Projection...
VS-6051 fuzzy picture
Those three Knobs were the focus or screen controls . your problem may be dust and dirt on the lens or the tubes could be getting soft. It could also be a convergence trouble and thats very common in these sets . a picture would be nice see where your problem lies BUT let me warm you down there where you were plying and turning those little knobs is about 32000 volts!!did you know this ? A tv set is not something to experiment with as it could kill ya. Unless you have technical background in electronics I would call a servicer to assist you. Good Luck
May 26, 2006 | Mitsubishi VS-6055 60" Rear Projection...
Televison & Video Logo
117 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
