Question about Biostar Computers & Internet
Mother board wont boot up
Got motherboard installed and working , did all updates , and then downloaded Win 8. everything was working fine. I was playing an on-line game , when I was done I went to log out of game and computer locked up, after a minute or 2 the computer just shut off. Now it will not boot up, no power to mouse , nothing on the monitor. I did plug the harddrive into another computer and it booted up fine so I know its not a software issue
  • 32,281 Answers
The switch mode power supply maybe faulty. try installing another power supply.
Posted on Jan 07, 2013
  • 183 Answers
SOURCE: MSI PM8M-V (MS-7104) Ver. 1.0 I
Try resetting the CMOS. You may do so by temporarily removing the CMOS battery and place it back.
Posted on Feb 10, 2011
  • 452 Answers
SOURCE: computer powers off while booting, green light stays on!
1. check the cpu fan is properly working with normal speed..
2. go to bios setup and restore all settings to default.
3. if windows start and problem comes after some time , then it might be virus. so, go for a virus scan.
Posted on Oct 15, 2007
  • 4 Answers
SOURCE: motherboard
I have one sitting in front of me , unfortunately I cannot get it to you but will be happy to tell you the positions. It's not very difficult to fix and I will stick by until you get it correct. I hope I don't complicate this in an attempt to keep it clear and don't be insulted by my answer. I am guessing you don't have a great deal of experience working inside the box and it can become confusing. This is much easier than the length of this answer suggest. You will do this in about 30 seconds, move anything that is in you way and make a note of where it came from. If your hand is small you are lucky but don't force anything and if you are pushing on anything trying to get down there see what it is before pushing more. Better to move it.
There is a front panel connector that is on the bottom right of the board if you orientate the board by placing the computer access panel in front of you with the front of the computer facing to your right. Then right below the floppy disk controlled socket (the smallest flat cable in the box) if no floppy the empty socket below the battery.
There is a double row of pins, looks like 2 rows of 10 pins each. Mine are multicolored, pink and green etc. and the should be marked + and minus, at least plus. The number 1 pin is on the left. The 1 pin is actually the bottom left and the 2 pin is above it. Back down to the bottom row and pin 3 is right next to 1 and the 4 pin right above it. Pin 3 is the second pin on bottom left. Follow the way it goes? The bottom is 1, 3, 5, 7, 9, 11, 13, 15, 17, 19 and right above 2, 4, 6, 8, 10, 12, 14, 16, 18, 20.
Pin 2 is + so put your Power SW on pin 2 and 4 with the colored wire on pin 2. Colored wire in the pair should be positive, and it can be blue, red, green, mine is red and white.
The Power LED goes right next to the Power SW on pins 6 and 8, the colored wire on pin 6, mine is blue and white. And finally the HDD LED goes on pin 7 and 9. All counting from the left to right. My pins are not marked as I think its not critical how the LED is connected and if it does not light then reverse those 2 pins. My colored wire is on pin 7 and its blue. May as well finish, the Reset button is wired to pins 17 and 19 with 17 being positive and the speaker if you have one hooked up (your tiny internal speaker not for listening to music) is a 4 pin connector with the middle 2 sockets empty and fits over the last 4 pin s on the bottom right. 13, 15, 17, and 19. Pin 13 is +. There may be other wires but I don't know where they go depends on what they are but this is what you need. Good luck. And make sure all is unplugged and touch the box to ground yourself or wear a strap. Look but don't touch is a good rule for now.
Posted on Feb 22, 2008
sodeep
  • 3267 Answers
SOURCE: Usb keyboard no longer recognised during boot process
Restore your PC before the BIOS update. BIOS updates are not required until & unless you face problems while running a software and it will prompt you for BIOS update. Do this update if its vital othewise do not intergere in the BIOS. I faced the same problem and after unistalling all drivers and again reload the original driver from MB VD slved it. Another thing in BIOS is USB setting at high-spped & full-speed. Try changing those settings and retry. Mine worked!...sodeep
Posted on Mar 22, 2009
  • 104 Answers
SOURCE: wont boot
i think the cpu may have a problem with the board or the memeory. either its bad, damaged or incompartible with your system. try out another cpu
Posted on Sep 29, 2009
ASUS M3A78-EM stopped seeing second drive
update your drivers and check the cables out as well
Jan 01, 2013 | ASUS M3A78-EM Motherboard
Installed win 7 lost real tec sound. No drivers work. also can not connect to network printer. sound is important now. have syntax sv266a mother board. No sound board it is in the mother board. I have...
Which operating system were you using earlier?
Try downloading the drivers for that version.
Then right click on those drivers and click on "Troubleshoot Compatibility"
Then install it in the old operating system mode.
Feb 27, 2011 | Syntax SV266A SKA KT266A Motherboard
I reinstalled win xp on my dell optiplex 210L since then everything is working great except my integrated ethernet port will not work. I have tried to install the drivers over and over. I also flashed my...
Hello
Check in the bios that your ethernet is indeed enabled.Also check system properties for any yellow question marks listed next to ethernet connections.If you have a question mark you will need to reinstall the drivers.
Feb 10, 2011 | Dell (E210882) Motherboard
D865GVHZ mother board Doesnt boots
If everything was working fine before, and you flashed bios unsuccessfully, then yes, if would be a bios problem.
If you didn't flash the bios you should check the connections on your monitor. If that's okay then check your memory, hard drive and cpu.
Good luck,
Hank
Aug 17, 2009 | Intel D865GVHZ Motherboard
Wont boot
Mar 24, 2009 | Gigabyte GA-K8VT800 Motherboard
About windows setup
Hi niket_shah, sorry but you're board Asus M2N-MX, does support Win XP SP2.
Chances are that while installing windows updates one or more updates failed. People like myself know from repairing PC's which updates need to be installed first. If you're Win XP SP2 did not or would not install than either the Win CD is not a valid Microsoft Win XP SP2 CD or (You have a copy) & there is something wrong with the CD. After a fresh (New install) of Win XP with SP2 there is more than 90+ updates for SP2 which must be downloaded through windows update program. Or you're windows will not function properly.
Just to show you what versions of windows the M2N-MX board does support. Click the link listed below. Once the link loads click the + sign next to Audio. Scroll down the page an notice the different Window version listed for you're board.
http://support.asus.com/download/download.aspx?modelname=M2N-MX&SLanguage=en-us
To recap this issue. The problem is either the WinCD or possibly you're hard drive. Make sure you allow windows to perform a full format before installing window. (Not a quick format).
Mike
Apr 12, 2008 | ASUS M2N-MX Motherboard
No Sound
it may look fine, but i think there is some trouble with the installation of motherboard on the new case take a review on it.
it happened to me before.I just reinstall it to the new nase and chechk for any lose connection or any busted chips. in that case try some new motherboard
Apr 07, 2008 | ASUS P4C800 Deluxe Motherboard
Intel 945GCCR mother board network drivers problem
hi dear .
when start up the computer automaic run bios , when i exit it display this masseg :
reinstall jumber in normal mode .
and the jumber is in normal mode already .
thanks .
Jan 29, 2008 | Computers & Internet
Computers & Internet Logo
48 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
