Question about Schwinn Airdyne Ad4 Upright Bike
I Need Console for 1988 Airdyne
I am looking for a replacement console for my Airdyne. The batteries were corrosive and broke the connectors in the part that snaps out, so I think I need to find a new console.
  • 21 Answers
The age of the machine is not as big of a replacement parts hinder as is Schwinn going through so many buy outs since 1988.
One of the best exercise repair parts on online is FitnessRepairParts.com. They have consoles which are similar to your generation of machine for 170.00 - 240.00
Otherwise schwinn was most recently owned by Nautilus/Bowflex/LAMAR fitness and they may be able to help through their website.
Sorry, I don't have a great source of imformation to help with. I repair Schwinn exercise and it has become very hard to find parts recently as the new generation of AEROdynes are very different. Although, up until maybe 1-2 years ago, nothing had changed for 30 years.
Alternatively, search craigslist and ebay. You may have to buy an entire unit to get the part you desire. Often they have a drive mechanism worn out which devalues them to the seller, but has minimal to do with your search.
Good Luck.
Posted on Jan 08, 2013
What kind of batteries does the schwinn Airdyne take its about 22 yrs old?
Most computer console batteries for Airdynes are AA, you'll have to open up the console/meter housing in the back to replace them. I will be attaching a link to a diagram of the housing. Hope this helps, sincerely SportSmith..
http://www.sportsmith.net/images/product_support/schwinn/service_manuals/Airdyne%20Evolution%20electronic%20trouble%20shooting.pdf
May 21, 2015 | Schwinn Cycling
Honda cb750f 1982. No power from battery to main console. All fuses intact.
If this was a wheelchair, as the category suggests, the first thing would be to ensure the battery is in good shape, holds a charge, and the cables are tight on the terminals.
Then, we would check the connectors. Depending on the type of connectors, they can get quite a bit of corrosion in a year so may need cleaning- mechanical scrubbing, contact spray, or whatever depending on the type and severity.
If still nothing, we check the cables and path with a multimeter- battery to first connection, then to 2nd connection, etc. until we find a problem.
If still nothing, we call the shop.
May 21, 2014 | Drive Geo Power Wheelchair
Vision fitness premier threadmill
see the chart attached. Tigh the upper and lower connector+ribbon cable inside, and clean it. However adjust the REED swtich see the diagram attached. , tight the connector and clean it. If your system has battery, replace by new ones with the same type, and clean the contacts spring from oxide, corrosion, and dust,
Dec 18, 2013 | Vision Fitness - T9550 Folding Treadmill...
The console doesn't display the time, calorie, distance and speed mode.
adjust the REED switch, see the diagram attached, clean it, and test for open or faulty, tight the connector very well.
2) tight the ribbon cable inside, and clean it.
3) tight the upper connector and lower connector and clean it.
4) measure the input voltage to the board display.
5) if your system has batteries replace by new ones with the same type alkalines (clean the contacts batteries very well from oxide, corrosion)
God bless you
Nov 26, 2013 | Bowflex TreadClimber TC5
Console isn't working
1) Adjust Reed Switch see the diagram, test it, clean it and tight the connector very well.
2) see if the fuse are o.k
3) tight the ribbon cable inside console board, and clean it.
4) see if the power goes on.
5) Replace batteries if your system ( have it) clean it the spring contacts battery for corrosion, oxide, etc.
Nov 18, 2013 | Exercise & Fitness
I need assembly picture or diagram for original airdyne.
Here is the diagram for the original Schwinn Airdyne. Only the computer is different.
Aug 25, 2010 | Schwinn Original Airdyne
I recently purchased an older schwinn airdyne and the console is missing the battery screw cap cover. I called around and it is no longer an available part. Anyone know how I might fix it without the cap...
I would take the cover of and expose the wire connection make sure you polarity is correct if you are good soldierer solder in long wires thru the bottom plate of console then solder a battey holder maybe a "AA" battery attach that with Velcro reassemble console ansee if it fire up
Feb 23, 2010 | Cycling
Ds lite got water in and battery connection corroded - can i fix
yea you can repair you have to ask gamestop on teh part for it
Oct 29, 2009 | Nintendo DS Lite Console
Owner's manual for older Schwinn Airdyne
http://support.nautilus.com/support/schwinn/uprightbikes/prdcdovr~3550012/Schwinn+Airdyne+Exercise+Bike.jsp
Follow this link and you can download the owners manual as well as the exploded parts schematics. There will be information about the different years. other than the consoles they have remained the same for 20 + years. If you ever need to replace the bottom bearing be sure to get the lock ring as well. It changed from left hand thread to right. Thats it. You can also upgrade the console to the newer version. A little expensive but with proper care a 20 year old Airdyne will last till the frame rusts out from under it.
Apr 23, 2009 | Schwinn 430 Elliptical Trainer
How can I remove gear shift knob on a 2003 Navigator?
it looks like you disconnect the shift cable and remove the center console finish panel with the shifter.
SECTION 501-12: Instrument Panel and Console 2003 Expedition/Navigator Workshop Manual
REMOVAL AND INSTALLATION Floor Console —Front, Navigator Removal and Installation
  1. Apply the parking brake.
  1. Position the front seat forward.
  1. Remove the two front floor console rear bolts.
  1. Position the front seats rearward.
  1. Disconnect the battery. For additional information, refer to Section 414-01 .
  1. Remove the pin-typ retainer and the window control switch panel.
    • Disconnect the electrical connectors.
  1. Move the shift lever to NEUTRAL and position the shift indicator bezel aside.
  1. Remove the screws and the center console finish panel.
  1. Disconnect the shift cable.
  1. Disconnect the front floor console electrical connectors.
    1. Loosen the electrical connector bolt.
    1. Disconnect the connector.
    1. Disconnect the electrical connector.
  1. Remove the front floor console side finish panel.
    • If equipped, disconnect the electrical connector.
  1. Remove the front floor console front bolts.
  1. Remove the floor console.
Apr 17, 2009 | 2003 Lincoln Navigator
Schwinn Airdyne Ad4 Upright Bike Logo
183 people viewed this question
Top Schwinn Exercise & Fitness Experts
Steve
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
