Question about Microsoft Office Professional 2007 Full Version for PC
Will not show reports below a "blue line" in check register
The blue line appeared between my last update and the update I just added. I cannot pull up the report that was added after the "blue line". I have never seen this line before and have used it many times. I am using QuickBooks 2006
  • 73 Answers
The blue line in a register indicates transactions that have been entered in the future, past today's date. Check your transaction dates as well as your system clock. It's possible your system clock is off.
Posted on Feb 09, 2009
When i am opening it, it is showing the program cannot start because loader.dll is missing from your computer try reinstalling it
Microsoft is constantly updating and improving Windows system files that could be associated with Loader.dll, sometimes resolving your DLL problems may be as simple as updating Windows with the latest Service Pack or other patch that Microsoft releases on an daily basis.
To help you install Windows update, please follow the steps given below:
- Steps used in (Windows XP, Vista, 7, 8, and 10).
- Click the Start button.
- Type 'Windows Update' into the search box and select it.
- The Windows Update dialog box will appear, if updates are available, click on 'Install Updates' button.
- After installing Windows Update, it is recommended to restart your computer once and then try using the computer.
If issue persists, you can use a built-in utility called 'Microsoft Register Server' (regsvr32.exe) to re-register your Loader.dll file.
In some cases your DLL file may not register properly and so you may get the error. To help you register Loder.dll file, please follow the steps given below:
- Type 'command' in the search box... DO NOT hit ENTER yet!
- While holding 'CTRL + Shift' on your keyboard, hit ENTER.
- You will be prompted with a permission dialog box and click Yes.
- Type the following command: regsvr32 /u Loader.dll and hit ENTER, this will UN-REGISTER your file.
- Now type the following command: regsvr32 /i Loader.dll and hit ENTER, this will RE-REGISTER your file.
- Close the command prompt window and restart the computer once again to check if the problem is fixed.
GuruAid.com
May 13, 2016 | Computers & Internet
Internet download manager serial number
Step-1 : Firstly GoTo www.internetdownloadmanager.com and download latest trial version of IDM. And if you already have installed IDM on your computer then GoTo ->help->Check for updates...and update your IDM to current version.
Step-2 : It will automatically ask you for registration if you already installed IDM else click on registration, Now a new dialog(window) appears that is asking for Name, Last Name, Email Address and Serial Key..
Step-3 : Enter your Name(Any Name), Last Name, Email ID and in Serial Key paste any key from the following ->
RLDGN-OV9WU-5W589-6VZH1
HUDWE-UO689-6D27B-YM28M
UK3DV-E0MNW-MLQYX-GENA1
7ADWY-RVBYI-MPP2K-Y7BXS
And click on ok to register. You also can enter any key from your side. Means you have to enter wrong key, so enter anything
Step-4: After your click ok, it will show an error message that you have registered IDM using fake serial key and IDM will exit. Now here the hack starts.
Step-5 : Now GoTo "Computer -> C:\(Drive) ->Windows -> System32 -> drivers -> etc". Else in window paste it C:\Windows\System32\drivers\etc .. Xp and vista user cstrong>
127.0.0.1 tonec.com
127.0.0.1 www.tonec.com
127.0.0.1 registeridm.com
127.0.0.1 www.registeridm.com
127.0.0.1 secure.registeridm.com
127.0.0.1 internetdownloadmanager.com
127.0.0.1 www.internetdownloadmanager.com
127.0.0.1 secure.internetdownloadmanager.com
127.0.0.1 mirror.internetdownloadmanager.com
127.0.0.1 mirror2.internetdownloadmanager.com
After adding this, save notepad file and then exit from here.
Note : In windows vista and windows 7, due to security rea
Jul 09, 2013 | Lenovo Computers & Internet
What is the default password for cisco
There are two main methods to return a Cisco router to its original factory defaults. These two methods are described below.
Method 1
1. uses the config-register 0x2102 command in global configuration mode.
2. Check the configuration register on the router by issuing the show version command.
3. The configuration register setting is displayed in the last line of the show version command output and should be set to 0x2102. If this is not the case, enter the config-register 0x2102 command once in global configuration mode.
router#configure terminal
router(config)#config-register 0x2102
router(config)#end
router#
4. If the show version command is issued again, the same line in the command output will have '(will be 0x2102 at next reload)' appended to the current register setting.
5. Erase the current start-up configuration on the router with the write erase command.
Reload the router with the reload command. When prompted to save the configuration, DO NOT save.
router#reload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]
Once the router reloads, the System Configuration Dialog appears.
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
The router is now reset to the original factory defaults.
Method 2
1. uses the config-register 0x2142 command in global configuration mode.
2. Enter the config-register 0x2142 command in global configuration mode.
router(config)#config-register 0x2142
This causes the router to ignore the start-up configuration on the next reload. If a show version is issued, the last line in the command output will have '(will be 0x2142 at next reload)' appended to the current configuration register setting.
3. Reload the router using the reload command in enable mode. It is not necessary to save when prompted to save the system configuration.
router#reload
After the router has reloaded, the System Configuration Dialog appears.
4. Enter no to the question "Would you like to enter initial configuration dialog?"
5. Change the configuration register setting to 0x2102 by entering the config-register 0x2102 command once in global configuration mode.
6. Issue the write memory command in enable mode to overwrite the existing start-up configuration with the current running configuration.
7. Reload the router with the reload command in enable mode.
Once the router reloads, the System configuration Dialog appears.
Note: The configurations below are stored in ROMMON, and cannot be reset to Factory Default Settings by the write erase or config-register 0x2142 commands.
warm-reboot
memory-size iomem <not default>
Jun 18, 2013 | Computers & Internet
My 1990 gmc k2500 sierra four wheel drive has blue smoke coming out of tail pipe and runs low on tranny fluid and i need to add 2 qts a week but there are now leaks.how am i loosing tran fluid?
Pull the vacuum line of the transmission modulator valve. If there's oil in the line, the diaphragm in the modulator valve is cracked and engine vacuum is pulling trans fluid into the engine intakee
Oct 18, 2017 | 1990 GMC Sierra
I haven't had any trouble following the manual to program and run this machine until today. Now it appears to be adding all the days together...I have used the Z daily function and it just continues to...
This is almost impossible. The first thing to do is make sure you are not accidentally performing an X read instead. Depending upon the brand, the top of the daily report should show 'Z' , 'Z1', or 'ZZ1' If it shows X instead of Z or the total keeps rising every day, then you are not performing a Z (reset). you are printing an X (examine only report). If you still have trouble, let me know the brand and model.
Oct 10, 2010 | Casio Parts Cash Register PC Desktop
Income from some accounts not reported in profit/loss report
Go into the report and select "Customize" and be sure these new accounts are turned on (checked) to be added to your report results.
Apr 09, 2009 | Intuit QuickBooks Premier 2009 Full...
Blue line appears in the middle of check register between last input and prior input. Cannot pull up reports past blue line. Using QuickBooks 2006
The problem has been solved!!! Thanks to your premium assistance plan. The crn was willing to stay with me until we figured out this problem.Thanks to him and many trials and errors we found out that a future date had been placed on past checks. Thanks again for the help!!
Jan 20, 2009 | Intuit QuickBooks® Pro 2006 Full Version...
Catastrophic failure reported by operating system - Vista home pr
Try this..
START button > RUN
Type in or Copy/Paste from here into the command line...
REGSVR32 JDBOLEDB.DLL
This will try to register it. If no error messages pop up it's been added.
To unregister it do... /u
REGSVR32 /U JDBOLEDB.DLL
Nov 24, 2008 | Microsoft Windows Vista Home Premium with...
Microsoft Office Professional 2007 Full Version for PC Logo
192 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
