Question about GE Spectra JBP78 Electric Kitchen Range
I have an Spectra Electric Range, Number 164D3871 P001. One day lights dimmed in house and oven starting beeping. Said F8 originally where clock is and changed to F2 when I started pressing buttons. Beeping stops for a short time when I Hour/Min buttons but starts gain after a couples minutes and keeps beeping. Oven nor brolier works at all but stove tops work. Can anyone please help? Thank you! Chuck
eagle338
  • 4889 Answers
SOURCE: My oven keeps beeping F2
checkout this link...
http://forum.doityourself.com/showthread.php?t=75624
Posted on Nov 04, 2007
  • 833 Answers
SOURCE: ge spectra gas stove top not lighting
There is nothing fancy about how the gas controls work on this unit. Do all burners give you the same problem? If so, it could be a kinked service hose or a service valve that has been partly shut. If it is limited to a single burner or two, the valve may be gummed up and should be replaced.
Posted on Dec 13, 2007
SOURCE: F7
I just fixed my F7 GE Oven. The ribbon cable on the control module was misplaced. disconnect the ribbon cable, cleaning it and re connecting fixed the problem for good.
Posted on Dec 28, 2007
aborcass
  • 2651 Answers
SOURCE: troubleshooting range
f1 code relates to a problem with the electronic oven control, no fixing the part only option is to replace it
Posted on Feb 23, 2008
SOURCE: GE Spectra XL44 Gas Oven, flashing "Locked Door". Can't use oven or close door
I had the same problem happen tonight. I have an XL44 self-cleaning gas range. We unplugged it for several minutes and pressed 'cancel' a bunch of times--neither worked. We finally lucked out--opened the oven door and pressed a black button on the upper left side of the front of the oven. It turned out the flashing words and unlocked our door. Weird. There was nothing in the manual about this...
Posted on Dec 28, 2008
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Bought used ge spectra range had to change the power cord to 3 prong to fit outlet--now nothing works except light when turning burners on and clock
Did you hear a "pop" or smell like something was burning? Sounds like old oven could have been 3 phase, and you new oven single phase, Check the power requirements for oven and see what kind of power you are supplying it with.
Mar 30, 2010 | GE Spectra JBP78 Electric Kitchen Range
GE spectra JBP66 electric oven that displays the F2
f 2 code states that oven has exccded 590 deg w/door in unlocked position or 990 f in locked . either the themp prop is bad or the relay in the EOC ( clock ) is welded closed . I would replace the prob first ( less expensive ) then the clock if needed .. **** ..
Dec 23, 2009 | GE Spectra JBP78 Electric Kitchen Range
Purchased at Maytag Gemini MER6770 in 2000. It
Sounds like the cancel (or stop) button is making contact by itself. Clock (oven control board) may need replacement.
One option to buy it new, your part number is 12001661
Coupon "New10" chops 10% off.
Another is to send the clock to be rebuilt. Google "stove timer rebuild", you'll find plenty of companies which can repair your original clock. In case you need it, the original part number is 74004542.
To get to the clock, remove the back of the control panel. Good luck.
Oct 24, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Ge oven JTP15 beeping and flashine F7 error
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Jun 17, 2009 | GE JTP15 Electric Single Oven
Oven wont turn on and f7 keeps beeping, but stove top burners work on ge spectra xl44 on model number jgbp86bea3bb
Well, F7 error code occures due to
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Good Luck!!
Have a nice Day!!
Thanks
Mar 07, 2009 | General Electric Stove/Oven/Range Chrome...
Oven does not work
Open the control panel to expose the clock/oven control.
With a volt meter verify incoming voltage to the clock control.
Check all wires for good contact.
If it still does not work replace the clock.
Remember to unplug the range to check the wires for good contact.
Mar 04, 2009 | GE Spectra JBP78 Electric Kitchen Range
Troubleshooting range
Feb 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore electric range 911.9369181
F8 Failure of Electronic Range Control (ERC) Replace Electronic Range Control/Clock (ERC)
Dec 01, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
GE Spectra JBP78 Electric Kitchen Range Logo
194 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
