Question about Makita 10" Miter Saw LS1030N
Removing guard on makita 5704r
How do i repace guard on makita 5704r power saw
efs_perpends
  • 1996 Answers
SOURCE: I took the guard off the 10" Makita Mitre saw (spring loaded)!
Oh, you got it off. I bet you can put it back on again.
It's much easier if you take the blade off first. Then you'll be able to reach inside when you need to. Be patient, don't force it, and make sure when you get the spring reconnected properly that the guard moves freely out of the way when you chop, and returns when you raise the saw back up.
It's a bit of a trick, but I bet you can manage it..It's been awhile, but it seems to me there's a way to get the bolt started before you engage the tension on the spring...I'd have to have it in my hands to say exactly.
Here's a link to the exploded parts view at the Makita site, just in case. And it might help to have an extra pair of hands, or a piece of duct tape to hold the guard in place when you go to put the blade back on.
Posted on Apr 10, 2009
rowdy45176
  • 2176 Answers
SOURCE: I have a makita circular saw 5704r. I droped the
it is a retaining ring and you need a special pair of pliers to remove this. If the guard is sticking remove the blade and lube and try and blow out with compressed air, if other let me know and I will try and help.
Posted on Jan 31, 2010
rowdy45176
  • 2176 Answers
SOURCE: The return spring for the blade guard on my Makita
there should be a hole in the housing towards the back of the saw, you can go to Makitatools.com and download a breakdown for this tool.
Posted on Feb 03, 2010
  • 157 Answers
SOURCE: where do i get a diagram of how to instal guard
Hello. Here is the link to the Parts Breakdown of your unit. It should show what you need to know to reassemble your saw. If not, use the contact information to speak to customer service and they should be able to assist. If this is helpful, please rate it a four-thumbs up, Thank You.
http://www.makita.com/en-us/Modules/Tools/ToolSupport.aspx?ID=370
Posted on Apr 05, 2011
rowdy45176
  • 2176 Answers
SOURCE: How do I assemble the blade guard for my Makita
lay the spring into the plastic safety cover, you will see a catch for one portion of the spring, the cover plate goes over it and there is a tab on it to catch the loose end and then the center plate which screws on to hold everything in place, check by turning the plate that holds it onto the saw for free movement. You can go to makitausa.com and in the header area on the right type in your model number ls1030n and you can download or look at a breakdown to see what I am talking about. Let me know if you need more assistance, just found your question.
Posted on May 04, 2011
How do I remove the boot guard on my makita
They are one of the hardest to remove - we usually clamp the end of the boot in a vise and using a couple screwdrivers from the handle end, turn the boot inside out and peel it off.
Jan 15, 2015 | Makita JR3050T Recipro Saw 9 Amp
How to replace a makita circular saw guard
Simple, unpug tool. Remove blade and back flange. Remove circlip and lift off guard. Unclip spring. Re-fit new guard. Refit spring and circlip. Refit blade.
Aug 18, 2013 | Makita Saws
Replace spring for saw guard makita ls 1030
Remove the guard and holder assy and place it on a flat surface as you undo the screw you will see how the spring fits into the holder under the bracket and also the locating pin.
Apr 02, 2013 | Makita Saws
Change blade Makita LS1030 10-Inch Compound Miter saw
There is an 8mm bolt on the front of the guard. Loosen/remove this and the central guard mount will drop slightly. Behind the metal guard is a slide lock for the blade spindle. Push the lock bar and turn the blade untill it catches and is held solid. Then remove the blade fixing bolt and bobs your uncle. Alternativly, with all mitre saws, you can just pop an old bit of wood on the work base and then use the spannrer/allen key supplied to turn the blade so it bites into the wood as if you are trying to cut it. This will hold the blade steady and you will also be turning the bolt in the right direction.
Jul 23, 2012 | Makita 10" Miter Saw LS1030N
How do I replace the blade guard on my 10" Makita
If you want to replace the plastic cover there is a screw towards the front of the saw that must be removed and then the bolt at the back loosened and the guard will pull off. If you need more info get back to me with the other questions and I will try and help
Jul 10, 2011 | Makita 10" Miter Saw LS1030N
How to remove guard and blade on LS1013
Theres a nut on the guard you need to loosen. Guard will then open enough to change blade. if you want to remove it completely theres a phillips srew you also need to remove.
Jan 24, 2011 | Makita 10" Miter Saw LS1030N
Jan 30, 2010 | Makita 7 - 1/4 & 34 Circular Saw Kit
How do I install the spring after changing the blade on the Makita 10 miter saw
what spring? do you mean the one in the guard? if so you don;t have to remove it to change the blade, give me the exact model number or you can go to makitatools.com and download a breakdown that shows the reassembly of the guard, it is not that hard, and also you can download an owners manual that shows the proper blade replacement procedure.
Jan 16, 2010 | Makita 10" Miter Saw LS1030N
Makita 10" Miter Saw LS1030N Logo
114 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
