Question about Vehicle Parts & Accessories
2003 chevy trailblazer. alarm problem 771xv
My viper alarm system 771xv is draining my battery overnight. and i cant get my new remote programed what could be the problem?
CHECK THAT YOUR BYPASS POWER IS ONNECTED TO THE ACC.CABLE FOR IT WILL NOT DRAIN YOUR BATTERY
Posted on Jan 22, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
2013 taurus with viper 211hv remote entry drains battery overnight.
If your battery is draining overnight and, you attribute it to the alarm, it could be a improperly installed starter kill relay. If the relay is wired to battery instead of ignition will do it.
Feb 19, 2014 | 211HV Keyless Entry System
Viper 211hv draining battery
If you are sure it is the system draining maybe the installer did not properly connect the GEM module. It would be wise to return to where it was installed and have that checked. If you are unsure if that is the cause then you could unplug remote unit and see if problem persists..
Light just blinks on center unit of 5701v viper
if the light dosent turn off when you turn the key on it means it is not reading the ignition wire check them. without the ignition you cant program the remote
Jun 01, 2013 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I own a 2003 Chevy Trailblazer, do I have to buy additional parts to have it installed, All I want it to do is remotely start my vehicle and lock and unlock my doors
Yes you will need a module to interface the GM Anti-theft system in your vehicle. It's a fairly simple solution, and should run you around $100. it needs to fool your car into thinking the key is in the ignition when it remote starts, or else the Factory Anti-theft will trigger and not allow your vehicle to start, and trigger the factory alarm. ( your horn with sound off)
Jan 06, 2011 | 5101 LE 1 Way Car Remote Starter System
Stop working
Well if your alarm doesn't work and your car doesn't start is because it has have installed what is call killswitch.You have to disconnect your alarm and attach togeter your wire that it runs to your killswitch.
Jan 04, 2010 | Remote Start System
I lost my remote for my viper 350 hv,and when i used my key to open the door the alarm went off,and disconnect the viper box,and bought a new remote,and when im trying to program my new remote and plug my...
You have to turn your ignition on and press the valet button switch, to turn off the alarm. Then, you have to use that same valet button to learn the remote to your alarm, following the steps in the installation manual.
Sep 20, 2009 | Viper Security and Remote Start System...
Viper 771xv remote start problem
the led should blink a code that tells you why it shut down or failed to start
Jul 05, 2009 | Vehicle Parts & Accessories
Viper remote 771xv works, but gives three steady tones at regular intervals after using.
That means that your remote is not receiving a signal from the remote starter. That's a two-way unit designed to transmit(tx) and receive(rx) signals to and from the antenna or brain. If it doesn't do either one, the remote will give you three triple beeps.
Jan 01, 2009 | 791XV The 791XV is a 2-way Security and...
Vehicle Parts & Accessories Logo
669 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
