Question about Euro-Kitchen SPAGNA VETRO 198D-36 Stainless Steel Kitchen Hood
Replace transformer in a hood ventilation for euro fans
    New Friend:
    Problem Solver:
  • 8 Answers
Please see my reply at http://www.fixya.com/support/t9977585-sv168n_36_spagna. I just replaced a failed transformer in a similar model.
Posted on Apr 27, 2014
KitchenAid Retractable Exhaust Fan problem when rising. When button is pushed, unit rises up about an inch. Requires 10 or more presses to extend fully. Otherwise fan and retraction is normal.
Kitchen Ventilation ' Kitchen Hoods and Fans ' KitchenAid
www.kitchenaid.com/major-appliances/hoods-and-vents/
KitchenAidShop and find how our hoods and ventilation systems clear the air in your ...Retractable Downdraft Design ... Telescopic Downdraft System in Stainless Steel.
30" Retractable Downdraft System, 600 CFM (KXD4630YSS ...
www.kitchenaid.com/shop/-[KXD4630YSS].../KXD4630YSS...
KitchenAidLearn about features and specifications for the KitchenAid 30" Retractable ... This 30-inch retractable downdraft vent rises 14 inches to help filter steam from ... 14" Rise. Enhances overall capture above the cooktop for more effective ... Makes it easy to select and adjust fan speed depending on your ventilation requirements.
KitchenAid® 36" Retractable Downdraft System, 600-1200 ...
Jan 10, 2016 | KitchenAid Dishwashers
Replace halogen bulb
Please see my answer at http://www.fixya.com/support/t9977585-sv168n_36_spagna. I suspect your problem is with a failed transformer, rather than the actual halogen fixtures.
Oct 29, 2013 | Euro-Kitchen SPAGNA VETRO 198D-36...
Euro spagna vetro series 218 light not working
Please see my reply at http://www.fixya.com/support/t9977585-sv168n_36_spagna. I think you may have a failed transformer.
Oct 09, 2013 | Euro-Kitchen SPAGNA VETRO 198D-36...
We have a SV168n-36 Spagna Vetro Range Hood and it works well but the lights are having problems now. They only come on intermittently and when they do come on once they heat up they shut back off.
I had the exact same problem with my Spagna Vetro hood. The fan worked fine, but the lights started working intermittently and then stopped working altogether. The problem in my case was a failed transformer, which sits between the power switch and the lights and is necessary to step-down the voltage from conventional 120v to 12v to support the halogen bulbs in the unit. Although there are several steps to resolving the problem (replacing the transformer), it's really not difficult. Here's what I did to solve the problem:
1) Shut off the circuit at the breaker (always very important :^) )
2) Removed the glass arch from the top of the hood. Four screws hold it in place and are accessed from above the unit.
3) Removed the access panel above the fan and light switches. This panel is visible underneath the glass arch, when the glass arch is removed. I slid the lower section of the decorative stainless chimney cover upward to gain complete access to the back two screws of this panel.
4) I unplugged the original transformer from the light on/off switch (connected with two yellow wires on my unit). Remove the wire-nuts and disconnect the 12v leads from black and white wires that connect the transformer to the halogen bulb fixtures.
5) Using a flat-head screwdriver, I pried the transformer off the metal surface to which it was adhered with double-stick tape. This was strongly adhered and took a bit of prying.
6) Found a replacement step-down electronic transformer at the hardware store. My hood takes only two 10 to 20 watt bulbs, so only a small transformer is required. The original one I removed was rated to 70 watts max. I replaced it with a transformer rated to 60 watts max. Either was more than sufficient to cover the 20 watt load produced by my two 10 watt bulbs. Cost of the replacement was about $15.
7) Connected the replacement transformer to the hood power switch. Here, I had to be a little careful to maintain the original polarity of the wires from the switch. This is because the original transformer, though it had one white and one black wire on its 120v side, was attached to the switch via two identical-looking yellow wires, using a non-standard plastic connector. The new transformer did not have one of these connectors on its 120v input wires (black and white), and I wanted to make sure that the I wired the replacement exactly as the original had been wired. Fortunately, the original plastic connector ensured a consistent polarity. When I looked at the end of the connector, one lead was square and one lead was round and noted that the square lead had been attached to the White wire on the original transformer. The replacement transformer also had a white and black wire for its 120v side. So, I marked the yellow wire from switch that attached to the white wire through the square lead. Then, I cut off the plastic connector from the yellow wires, stripped the sheathing from them about 1/4 inch, and attached the white wire from the new transformer to the previously marked yellow wire, using a small wire nut. I then connected the black wire from the transformer to the remaining yellow wire in the same way.
8) On the 12v side of the transformer, the wires are the same color and I did not pay close attention to polarity, simply connecting each to the spliced wires leading to the halogen bulbs (that I exposed when I removed the wire nuts from them in step 4, above) using fresh wire nuts.
9) The double-stick tape that attached the original transformer to the hood remained firmly attached to the metal surface of the hood and it was still very tacky on the surface that had been attached to the original transformer. So, after I tidied up the wires in the space, I positioned the new transformer over the tape and pressed it down firmly, which seemed to adhere the new transformer to the hood pretty well.
10) With the connections completed, and power restored to the circuit at the breaker, the lights worked fine, and the fan continued to work fine. I reversed the steps I used to expose the switch and transformer.
So that's all there was to it. The cost of parts was about $20 for the transformer and a bag of wire nuts. Investigating the problem probably took more time than the actual repair, which took about 20 minutes from start to finish.
Aug 03, 2011 | Euro-Kitchen SPAGNA VETRO 198D-36...
I have a Euro-Kitchen 218 Series "Spagna Vetro" exhaust fan with four 35w halogen lights and two electronic dimming controls. Well, the lights all stopped working, although the control panel shows the...
DW, It is not the transformer. It could be the dimming controls. Also, instead of using a bigger transformer go in for CFL bulbs and reduce the load on the transformer. And contribute towards efforts to reduce global warming by using less electricity.
Sep 28, 2010 | Euro-Pro Kitchen Ranges
I have a viking vipr161ss ventilation system. When I push the button on top of the ventilator nothing happens. When I manually activate the microswitch located in the electrical box under the cabinet the...
Hi- It sounds like you diagnosed the problem correctly. There is a chance there is something wrong with the board but I would replace the top switch first. They are pretty expensive if I remember correctly and be careful of the wiring colors, the last one I changed had the wire colors reversed but the wire labels were correct. Good luck.
Sep 24, 2010 | Viking VIPR Series Versavent Kitchen Hood
Fan olny run on hight speed
The fan speed selector switch has failed and needs a replacement. Here's the parts breakdown for it. It's number 26 in the diagram.
SG
Apr 07, 2009 | Jenn-Air ® Ventilation System for...
I can switch on lights and fan, but then they switch off
It could be either. Usually i would say its the control board, but its very possible that its the transformer. I would start with that, the trans=25$ then control board = 110$
Its the small transformer (blue/yellow/black/white) wires coming out of it.
Jan 22, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
Euro-Kitchen SPAGNA VETRO 198D-36 Stainless Steel Kitchen Hood Logo
261 people viewed this question
Top Euro-Kitchen Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you an Euro-Kitchen Kitchen Range Expert? Answer questions, earn points and help others
