Kyocera mita 2030 paper jam 00 error. Paper removed, still not working.
4 Suggested Answers
SOURCE: Kyocera KM-3035 - Paper Jam 00 error. Paper removed, still not working.
Check to make sure that their is no paper that is jammed in the paper draw. Also open the main panel where you would change the toner and pull out the little draw underneath the toner, I believe it is marked A2. Make sure that there is no paper there as well. Another place that paper will sometimes hide is in the left panel by the duplex system. Sometimes a little piece of paper gets left behind and this can cause the system to think there is still paper jammed in the machine. If all else fails try restarting the system. If you are still experiencing a problem than I would recommend you call your servicing dealer.
Hopes this helps.
Henry
Posted on Aug 15, 2008
shawn38
  • 200 Answers
SOURCE: I have a continous red light (paper jam) on a
If you are not seeing any paper there you most likely have a bad paper detect sensor. The paper detect sensor is what looks for the proper timing of the paper moving through the machine and indicates a jam when the paper stops.
Posted on Mar 25, 2011
  • 3 Answers
SOURCE: auto paper feed jamming
clean the rollers with alcohol. this will renew the rubber and clear up the problem
Posted on Jun 27, 2008
My kyocera KM 1815 keeps saying "paper jam 00 open left cover and remove paper jam but there is no jam
Hi
Check all the paper movement from the tray, left or right cover, front cover, if so then remove jammed paper. Otherwise the paper sensor spring guide missing or fell off from its original position. Check carefully where the sensor locate. paper sensors detect all the paper movement in the machine during copying or printing, so locate the place in the machine which the paper usually jammed, see the screen of the machine, it will locate the place where the paper jammed mostly. Sensor not return to it original position that is why ( remove paper jam keeps blinking)
Aug 11, 2014 | Kyocera Mita Office Equipment & Supplies
Km2035 error J00 kyocera mita
J00 is an unidentified jam. Means that a paper jammed in the machine and the user switched the machine off and then on again. So the machine lost the ability to inform the user where the jam is. As a result the user has to find out where the jammed paper or piece of paper is.
Jul 16, 2014 | Kyocera Mita Drum Cleaning Blade Km 1620...
I Keep getting a j10 display when I try to print on the display
A J10 shows up if there is no feed from the upper paper tray. Check the operation of the paper feed clutch for the upper drawer.
Good luck,
Peter
Dec 18, 2013 | Kyocera Mita Mita Copier Toner Cartridge...
Kyocera km 5035 error c2500
Paper feed motor problem.
Ensure that all cassettes are correctly loaded with paper.
Ensure that by removing the paper cassettes no paper is jammed behind them/in the copier.
press 1087 1087 on the key pad,then 906 then start,then execute then start.
Press 001 to exit.
Aug 14, 2013 | Kyocera Mita Km 3035, 4035, 5035 Fs9120dn,...
Kyocera mita km2530 paper misfeed jam00
This usually means that no paper has been fed from the paper cassette or the machine was turned off when you had a paper jam.
Remove the paper cassette from the machine and ensure that nothing is stopping the paper from feeding.Also look into where the machine locates in the copier to ensure that no paper is jammed behind the cassette.
The paper feed rollers may need cleaning or replacing.
Jan 03, 2012 | Kyocera Mita KM-2530 Laser Printer
I have a continous red light (paper jam) on a kyocera Mita fs 1000+ not obvious paper jam,..... what's wrong?
Dec 24, 2010 | Kyocera Mita FS-1020D Laser Printer
Have Kyocero 2050. Error - Misfeed paper - Open Left Cover and remove misfed sheet. Jam 00. I opened left-side cover and found no sheets stuck anywhere in sight. I can't find Jam 00 definition in...
I was having the same problem with the same model and same error. Then I discovered there's an extra panel you can pull out of the side - it's not the one the display is indicating, it's the one all the way on the side. When you pull on the grey level and it comes down, keep pul;ling on the grey level because ANOTHER panel comes down under that and I found some paper jammed in there. Once I removed it it worked fine.
Dec 13, 2010 | Kyocera Mita KM-2050 Printer
Kyocera mita j11 error code
On most Kyocera Mita copiers a J-11 code indicates a possible paper jam when paper is being fed from drawer #1, but sometimes a J-11 will be indicated when the paper fails to feed from the drawer. Check the paper stops and paper guides in the drawer and make sure that they are flush against the paper, also cleaning the paper feed and pick-up rollers with a rag dampened with just plain water will help sometimes unless the rollers are completely worn out. If all this doesn't help you may have a paper feed clutch or lift motor that has failed.
Sep 18, 2009 | Kyocera Mita Office Equipment & Supplies
Kyocera Mita FS1010 fault
check your user guide... it will explain this error... or contact kyocera customer support...
Jun 25, 2009 | Kyocera Mita FS 1010 Laser Printer
Hopes this helps.
Henry
Jul 20, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
150 people viewed this question
k24674
