My new sharp lc-24ls240e was an ex display and wont show any other source list then HDMI i think i need to restore to factory settings but cant seem to find a way to do this, am rubbish with anything technical so would love some advice
    New Friend:
I have this tv as an ex display, but the installation and retune menu will not appear, any suggestions please??
Posted on Jan 13, 2013
  • piercy56
    piercy56 Jan 13, 2013
    i have this tv as an ex display, but the installation and retune menu will not appear, any suggestions please??
DRebel
  • 19 Answers
SOURCE: Sharp Aquos LC-32B20E wont display a PS3 output via HDMI
kitconnolly,
I too went through this problem.
Step 1 - Plug in your "composite" cables and the HDMI cable to the PS3. Obviously, the "composite" cable are the ones that came with the system. You need to start with them as the default connector.
Step 2 - After connecting the "composite" cable and the HDMI cable to the PS3, connect the other ends to your TV.
Step 3 - Power on your PS3
Step 4 - Select display settings-->video output settings
Step 5 - Change from the current video cables to HDMI. (Your tv has different inputs. When you switch to HDMI in the PS3, you will have to switch your TV to the HDMI input that it is connected to, to get a picture)
Step 6 - Be quick, the PS3 will display a "test" for 30 seconds. You need to switch your tv to the correct HDMI input and press "X" on your controller to accept the change.
Let me know how this works for you.
Posted on Apr 03, 2009
swami nathan
  • 208 Answers
SOURCE: Sharp Aquos LC-37P50E connected to computer with HDMI cable
I got the chat , but some how it got disconnected.
But i would like to help you in this aspect.
HDMI stands for High Definition Multimedia Interface, and supports transmission of both audio and video in high fidelity.
First make sure these things,
Both your computer and your TV will need to support HDMI interface.
It's quite a recent thing in PC graphics cards, so you may have to resort to S-Video, DVI or VGA for the video, plus a 3.5mm stereo cable (or the optical TOSLINK equivalent) for the sound.
Let know your comments and i will follow up with the suggestions.
Thanx for using fixya,
Good luck.
Posted on Sep 28, 2008
mistersony
  • 320 Answers
SOURCE: HDMI Input Stopped Working Sony Bravia KDL-40S2000
Bad input board BU or AU
Posted on Oct 18, 2008
gymhasafit
  • 31 Answers
SOURCE: Sharp Aquos LC-46d65U HDMI connect
First off a little tip that manufacturers don't tell you is that you HAVE to TURN OFF the POWER to ANY UNITS that you are Connecting to via HDMI!!!!!!! If not you can short out the Inputs!!!!!!!! HDMI is usually Automatic, But sometimes you need to go into the Menus on all Devices to the HDMI section and write down their settings and compare them. Any definition that you are not sure of check the Manual or Google it! Match all the Settings (there won't be Much!) Hopefully the Inputs were not Damaged it only takes one time to short it out and then the Repairman makes a few bucks! Good Luck!
Posted on Apr 29, 2009
  • 8457 Answers
SOURCE: sharp aquos no sound through hdmi
Reset all audio factory setting.Tries unplug,replug it well work,if ur backlight video board it still good.
Posted on Dec 17, 2009
Testimonial: "worked like a charm thank you so much, i was about to throw in the towel and get a new tv, now i don't have to thanks again"
Sharp displays frozen on start up logo. Just shows SHARP and wont change sources or anything. Model # LC-65LE645U
Sounds like corrupted firmware. A firmware update might be necessary. If you wish to get some details; check the site linked here. Pull up older posts.
Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail.
Bfore doing anything; try a hard reset to this set, and check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
May 24, 2016 | Sharp Televison & Video
Lc? monitor
I think you need to degauss your monitor settings to remove these lines. Usually these lines can be removed easily in the CRT monitor setup but as for the case of LCD monitor they are cause due to array of dead pixels. Show it to a good technician for an immediate fix. breastfeeding pillow
Jul 06, 2013 | Computers & Internet
Sharp aquos LC-40E67U HDMI board KF030 XFO30WJ red light on the HDMI board.
Normally, these board have no repair. It will be best to replace it.
Jun 06, 2013 | Sharp Televison & Video
I have a Sharp LC-42D62U and have our DVR from cable connected to HDMI #4. I want to hook up a Roku via HDMI to HDMI #5 but the input source shows unavailable sign. Is there a way to get both HDMI...
If your Tv has this many HDMI ports it will have a menu to access each one separate. Go to your Tv's settings menu and look for your HDMI ports to use.
Jul 30, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a Sharp LC-46E77UN TV. Remote will start TV green light on. No picture, just stays black. PVR is on and connected to TV via HDMI cable. Cannot turn off green light. Must use power button on TV and...
THe problem is in the set top box. Or common called the tuner box. IT looses the 5 volts to the main display and thus the monitor will go into a shut down state. THESE boxes are factory repair only and must be sent off to repair.
Feb 20, 2011 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
LC-26DA5U 26 in. HDTV-Ready LCD Television: i connect a hdmi cable 2 my hd cable box - the pic...
The cable box needs to be set to send different signals when using hd tv and standard tv. Usually a good setting would be 720p in hd and 480p in standard. The tv is working fine it is the cable box sending the signal. If you have another hdmi source such as a dvd player you may hook that up to show the tv is working just fine.
May 07, 2010 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
Sharp aquos no sound through hdmi
Dec 17, 2009 | Sharp Aquos LC32D41U 32 in. LCD TV
When plugging in a new PS3 to hdmi input 4 or 5 on the Sharp Aquos LC-42D62U, it is not picking up the connection and I can't select it on the input menu
Does the HDMI output on the PS3 have to be turned on first in its settings? Make sure the settings on the PS3 are at a minimum of 720p as if it is set to 480i the TV probably wont notice anything connected to HDMI.
Nov 06, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Setting up sharp 46
Try to isolate the problem.
Try plugging in another source such as a DVD, is there audio? If yes, problem may be with the optimum box. If no, most likely a problem with the TV.
Also, if you are using HDMI with the HDTV box, make sure the box is set to output audio through HDMI.
Feb 10, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Televison & Video Logo
223 people viewed this question
Top Televison & Video Experts
