Question about Sony KV-24FV12 24" TV
Don't know how to change from cable to antenna
We don't have the origional remolt control. The TV has been used with cable until now. We now need to watch progrems broadcast by antenna. I tried everything I could think of in the menu setup but I still cant't pull in the TV stations. When I swithch it to AV-1 and input the RCA signal from the VCR, I can change the chanels on the VCR and get the chanels onto the TV that way . I'd like to do it directly without going through the VCR.
Thanks,
Roman
    Genius:
  • Sony Master
  • 1,102 Answers
On the back of your set
there may be a small switch someone with 2 or 3 different options
Posted on Jan 20, 2009
No picture or sound
You need a antenna HD for air signals. I hope this helps. leave feedback and thank you
Jul 11, 2016 | Televison & Video
I purchased a LG 32lx4dc tv from a hotel liquidator but i can't it to work at home? I don't have the remote. Can I access the menu using a universal remote? Will I ever get it to work at home?
Here is what worked for me:
1. On the LST-4100A box, there is a black, removable card with an F-connector (Cable In) and a RJ-11 (Data). Unscrew the two retaining screws and remove this card. There is an antenna-type connector on the inside that will need to be disconnected from the card.
2. Connnect the control box to the TV via the serial cable (Display Control).
3. Plug in power cables to TV and control box. Turn on TV.
4. There are two lights on the control box. Make sure the "Power" light is on solid and the "Status" light is flashing quickly. If not, cycle power on both the TV and the control box.
5. Press "Menu" and hold the button until the menu disappears.
6. Quickly, press "2 6 6 3" then press "Enter". A small menu should open in the upper left.
7. Scroll down to "DBox". Change to "Off". TV will restart.
8. Disconnect the serial cable from the TV. The remote controls should now work normally with the control box disconnected.
Oct 01, 2012 | LG 32LX4DC 32 in. LCD Television
When did tvs go digital
It started this year
You can watch digital on any tv but you do need digital receiver box
You can use digital antenna if you don't have cable or satellite
Either way you need that digital box
I know - more money to spend
Feb 06, 2012 | Curtis-Mathis Televison & Video
Do i need a antienna for regular tv. if i do where does it go in the back of tv. help
Yes of course you do. It goes on the RF coaxial jack (the same one that cable TV would connect tto) labeled antenna. Don't let anyone sell you a special expensive "digital antenna" because digital TV uses the same frequencies that UHF has always used and thereby requires the same antenna, or at least the smaller portion of the older antennae.
Aug 17, 2011 | Vizio L32 32 in. LCD HDTV
Really? cool... so I have a Panasonic HDTV 720p... just moved, no cable, but I have a TV antenna. Amplified indoor antenna. GE brand model 24700. I powered and connected the coaxial cable between the tv...
You need to go into on screen TV tuner/channel scanning setup page and change the signal source from CABLE to ANTENNA so it will scan again to pick up off the air signals. Please read the TV user manual for more details.
What is the model number of the TV?
May 15, 2011 | Televison & Video
Watch tv properly with JVC DVD off
Some philips tv's have a built in aerial amplifier, perhaps if you bought a digital aerial booster it will improve the picture quality.
Apr 05, 2010 | JVC DR-MV1S DVD Recorder/VCR
The color on our Sony tv is now distorted. The
if this is an older tv and your state might have changed to digital programming then i would suggest trying to look at the back of the set and see if you have anything to fix this problem or you might want to CHECK AND SEE IF YOU HAVE VIDEO ON or CABLE on or TV on. Sometimes if you have Antenna switch to cable then your channels would be red and picture distorted. change the antenna to air for tv. or from tv to cable.
Feb 24, 2010 | Televison & Video
My toshiba tv only goes up to channel 12, when it reaches channel 12 it starts back at channel 1.
You will need to re-scan the channels, i don 't know where it is on the menu of this set. If you are on cable, you need to make sure your tv is set to cable tuning, or you cannot get channels past channel 13. Same is true for antenna if you are on antenna make sure you are set for this.
Nov 20, 2009 | Toshiba 36A40 36" TV
Chanel will not go up or down.
George, your tv`s tuning system is set to "air", (roof top antenna) you need to go into your menu and change it to "cable", then do "autoprogram" again and it will add the channels above 13. You really should order the original remote for yourself, you can probably get one here; www.partstore.com Good Luck and Happy Holidays
Dec 04, 2007 | Toshiba 20AF41 20" TV
Sony KV-24FV12 24" TV Logo
98 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
