Question about Refrigerators
Loud buzzing noise from control panel area Hoover fridge freezer (model HCA45001)
Noise stops when pump/motor starts. both fridge and freezer compartments working normally.
dididsaythat
  • 291 Answers
SOURCE: SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor
Check fan motor for continity IF none replace fan motor
Posted on Oct 12, 2007
  • 1462 Answers
SOURCE: Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Posted on Jun 25, 2008
SOURCE: Loud buzzing noise from compressor area and freezer not cold enough
I have a 1.5 year old GE refrigerator and freezer. This unit had not given me any problems until 2 days ago when I constantly heard a loud buzzing sound coming from the freezer. I called GE and Best Buy (bought it there) and asked to troubleshoot this over the phone. They suggested sending a technician over for $100 just for the visit + labor + parts which could add up to hundreds of dollars. So, I researched the web and blogs like this. The answer to my problem was simple. Something that I placed inside the freezer was blocking the air circulation vent. So, I turned off the whole refridgerator and I removed everything from my freezer. For good measure I dislodged some ice and frost that had developed over the vent. I carefully put back everything into the freezer, but this time being careful not to block the vent. I turned on the power and voila! No more buzzing sound!!! I hope this works for you too.
Posted on Feb 28, 2009
  • 16 Answers
SOURCE: GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
FAN MAKING NOISE BECAUSE OF BAD COMP BOARD, PUT UP WITH NOISE OR REPLACE EXPENSIVE BOARD
Posted on Mar 25, 2009
  • 11 Answers
Typically this happens when the ice maker is not getting the water pressure it needs to fill the trays. Replace your filter on the ice maker and this should solve your problem.
Posted on Aug 22, 2009
GE profile fridge making loud humming noise
The door being open so long caused warm moist air to collect and freeze inside the unit.
Take everything out, unplug it and let it thaw out for an entire day. All the frost will thaw, and probably run water all over the place so put towels down.
When you plug it back it, it should work fine.
Jul 26, 2014 | Refrigerators
Loud buzzing noise
Yes that is your relay they are pretty common use your model number to track one down may tag is owned by whirlpool so most local places will have them
Mar 01, 2014 | Maytag MFD2560HES Bottom Freezer French...
Samsung RF266AEPN BUZZING NOISE and back Panel Iced
Sometimes they ice up because the defrost cycle does not work, check for a faulty fuse, in the circuit board.
Jun 04, 2017 | Samsung RF266AEPN
Why has my fridge freezer started to make a louder humming noise?
no problem with that it is normal..your ref working properly it is just the motor you hear
May 22, 2012 | Beko Refrigerators
Buzzing noise from back of freezer
need to remove rear panel inside of freezer section. check for normal operation of evap fan motor. check for ice build up on evap.
Apr 21, 2009 | Amana ARS2464B Side by Side Refrigerator
Whirlpool Gold Refrigerator Buzzing sound when motor is on
some thing could be toching the fan at the back of the fridge or freeze fan making noise
Apr 02, 2009 | Refrigerators
Evaporator Fan Motor noise is excessive for this refrigerator. GE Profile CustomStyle Model PTI22SFMARBS Serial# SF900146V
Despite my urge to vent about GE refrigerators, I'll keep this short.
If you have a constant squealing noise from the evaporator fan in the freezer, there's a good chance the fan just has failing bearings, and replacing the evaporator fan might solve the problem.
But if the noise is intermittent; quiet sometimes but sometimes buzzing loudly, then my bet is there's nothing wrong with your evaporator fan. It's a problem with the design of GE fridges: They don't defrost completely. So ice builds up on the back freezer wall, etc., and on and around the evaporator fan. That's not a problem when the fan is in "low speed mode". But open the door, get the fridge warm, and the fan kicks into "high speed mode". That's when the noise will start, as the fan blades and assembly warps under speed to hit ice and start vibrating.
Acid test is this: While the noise is occurring, turn the fridge temp (not freezer) control up as high as you can without turning off the fridge. That will make the fan shift into low speed. If the noise stops, you got ice on the fan, my friend.
In that case, unplug the fridge, and get a hair dryer and blow warm air into and onto the evaporator fan area. Maybe gently whack the fan area with your hand a bit, to knock the ice off. Once you get all the ice off, turn it back on. If it runs on high, without any noise, the problem is fixed ... until the next set of high humidity days. I plan to post a video about this, once I get it edited to remove the expletives. ;-)
GE will sell you a "moisture kit" for $340, which may fix the problem, but only if your fridge is out of warranty.
If your fridge is still under warranty, GE will tell you there's nothing wrong and that maybe you just need ear plugs.
Nov 18, 2008 | Refrigerators
Jun 25, 2008 | Jenn-Air JCB2388G Side by Side...
Kemore model 795.7731 bottom freezer
You are probably correct that it is the evap motor. If you are seeing frost on the back wall then there is probably some ice built up around the motor and the fan blade is hitting it.
Try defrosting the freezer and look very closely all around the seal for the freezer drawer. It is common for moisture to freeze in the self closers in the drawer rails and not let the drawer close completely on one side or the other. If this happens the small gap will allow the freezer to frost excessively.
Sorrry to be slow in responding. I have been very busy this week and have not been on line very much.
Mike
Apr 10, 2008 | Refrigerators
Can you Help?
Check your blower inside the unit, blower frame may be deformed causing the blower to touch the frame make some noise.
Mar 06, 2008 | Refrigerators
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
