Question about Kenmore Dryers
Need to replace the heat element for my Dryer Kemore
How to replace my heat element for my Kenmore Dryer #86860100, is there a instructional view or how to get to the area to replace the unit?
    President:
  • Kenmore Master
  • 2,651 Answers
Sorry couldnt find your modle number, but kenmore dryers are enerally whirlpools in which case are easy to replace. the harder issue is determining if this is your problem.I would assume your guessing on a bad heater, only for the face that if you truly did check hte heater, you would find how to remove it( a few screws will release it from its mounting. A simple check with a Meter will determine if indeed it has gone bad. A more likely source or just as common cause of no heat would be a blown thermal fuse, or a bad high limit thermostat, all can be checked for continuity with a meter
Posted on Jan 20, 2009
I have a old kenmore dryer and it won't dry my clothes, if the rubber gasket around the door is gone will this prevent drying? Thank you Gloria
That could be the problem or if it doesn't heat up at all it's probably the heating element in it. Any local appliance supplier should have either part part in stock or look up the model online and you can order one. Replacing them is pretty easy.
Apr 08, 2017 | Kenmore Dryers
Where is the heating element for a Kenmore heavy duty 60 series soft heat large capacity?
How to Replace Your Electric Dryer's Heating Element
www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid Electric Dryer's Heating Element. Here's a common job that many folks are afraid of, but it's ...
Whirlpool / Kenmore Dryer Heater and Thermostat Test ...
? 7:40
https://www.youtube.com/watch?v=KZY9CQ_CqvY
Sep 13, 2010 - Uploaded by Bill Newberry
Basic checks for a Whirlpool made dryer. ... Whirlpool & KenmoreDryer Repair - How To Diagnose No Heat ...
Whirlpool - Kenmore - Maytag Dryer Not Heating Repair ...
? 2:42
https://www.youtube.com/watch?v=i95okOr2rOI
Mar 1, 2011 - Uploaded by ApplianceAdvice
It will explain step by step instructions on how to test the thermostats, fuses, and heating element inside the ...
How To Fix Dryer With No Heat ' Dryer Repair - PartSelect
Dec 12, 2015 | Kenmore Dryers
Kemore dryer will not dry
Clean your venting systems. Take a look at what mine looked like.... this killed my heating element.
Sep 11, 2012 | Kenmore Dryers
Kemore dryer serial number 96292110 dryer turns and operates but dosent produce any heat
Your dryer innards look like this
Their is usually a flap you can remove to get to the element.
It slides out after you remove a screw or 2 These videos show how to get into the dryer:
Older model:
Newer model:
More Here
Jan 15, 2011 | Kenmore Dryers
Kenmore Series 70 Dryer
I'm not familiar with your dryer model but general advice regarding dryers with the problem that you have described would be to ensure that any filter on the outlet is clean, whether it be a condenser or traditional external vent.
Ensure, if it is vented rather than condensing (only connected to a drain) that the vent tube has clear access to expel the damp air circulated during the drying process.
If the wash load is heating to a substantial temperature in the dryer, it isn't the element causing the problem.
May 07, 2009 | Kenmore 60172 Electric Commercial Dryer
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
MY DRYER DOESN'T GET HOT
If it's completely cold, you probably have a burn out heating element. If it gets warm and takes forever to dry, then it's probably the fan wheel.
Hope that helps...
Geno
Mar 22, 2008 | Kenmore 62602 Electric Dryer
Kemore Elite Dryer Repair
at the bottom of the unit there will be 3 torks screws remove them and the panel will open so you can see the insde and the heating element box...UNPLUG FIRST!!!
Nov 25, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
67 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
