Question about Samson Technology Zoom R16 Recorder / Interface / Controller
My Zoom R16 wont turn on
I'm no stranger to electronics repair, but this one has me puzzled. One night at band practice, I plugged my R16 in and when I switched the power on... nothing happened. I've checked the power supply (wall wart) and it's fine. I've tried the USB interface and batteries to power the R16, and neither of those worked. Faulty switch? Cracked solder joint? That was my next thought too. I opened the R16 up and looked for any obvious signs of damage. There were none. I used my voltmeter to check the switch and power is effected just fine by the switch. Physically, the R16 looks and appears to be mechanically sound. There's not a whole lot inside the R16 on the motherboard. At $400 to replace my R16, that's a bit much. I bought mine used about 2 years ago and have not had any problems until this problem 2 weeks ago. So, I'd like to get mine repaired. Any suggestions on who can service my R16? Will the repair cost outweigh the cost of just buying a new one?
    New Friend:
Hi , i have the same problem, did you fix the problem already ?
Posted on Nov 25, 2013
  • 3 more comments
  • Jonathan Maker Dec 02, 2013
    I meant in my previous post, if you already solved the problem. With the intention, if it has not yet been resolved, to mail me, because i know how you can fix this.
  • how do you fix it? mine would turn on for a few minutes then turn its self off, then one day nothing. Mine had leass than 20hrs of use and died 11 days past the waranty. Thanks!
  • Andy Longden
    Andy Longden Mar 21, 2014
    It's not been fixed. I suspect that the power input socket is at fault as it is loose compared to the socket on my 1266. I am hoping that this is the cause.
  • Christian MITOYEN
    Christian MITOYEN Apr 27, 2014
    You can try the R16 as sound card via USB .. no need power supply .. just wait about 5 s and then it go on and ask you for sound card function ... press enter twice ... If it's ok by this way, you problem is pehaps the power switch witch is NOT a real power switch because when you switch off, you can see the device don't power off instantely ... si it's a signal for the processor ...
  • Al Bettz
    Al Bettz Aug 26, 2014
    if either of you could provide a picture of the board while its dismantled I need know where three wires go from the little sister board to the main board, please email them to mrmellow1@gmail.com
I have a behringer pmp5000. At Practice one of the cables was stepped on and came out of a speaker.then, plugged back in immediately. There was some smoke and now the unit wont even turn on. Can this be...
Yes, it can be repaired. Likely at least the output transistors are fried, possibly the drivers are too. Possible other components like resistors gone, too. Needs somebody that knows amps.
Jan 20, 2015 | Behringer Europower Pmp5000 Powered Mixer...
How do I fix my zoom
Its initialihzin hard disk drive so the hard disk is probably broken put in another one dont know if you need to format it but its your hard disk for shure
Oct 20, 2014 | Zoom R16 Multitrack Recorder
The screen does not display any iinfo when on
The problem is related to LCD screen. I am currently looking for a replacement screen to do the repair myself. If you come across a part# for R16 LCD, please contact me.
Apr 20, 2013 | Zoom R16 Multitrack Recorder
Some tracks won't playback on R16, but are fine on my PC.
That would be because of the codec that this "Track" is encoded in.
Download an user friendly application like "Media info" to check the codec for the working and for the non working, then search for a converter to convert the non working track to the same format as the working one.
Nov 15, 2012 | Zoom R16 Multitrack Recorder
My Laney VS30 212 at band practice last week decided to intermittently cut out, but not fully just the volume would drop out then return about 5 mins later. Not sure if this was a common problem. It might...
Sounds like output valve, if the amp is more than few hundred hours then suspect this for sure. I don't know much about this amp specifically but does the sound fade/return suddenly or over a few seconds? Try running it with the back off and fan on the valves etc. Then play at loudness where problem occurs and see if any improvement. Remember that at band practice you always play much louder than you think and put a lot of stress on it.
May 03, 2011 | Laney VC30-212 VC Series 30 Watt Class A...
CAN I PLUG IT IN TO MY AMP
Yes the output jack socket can be used either to:
  • plug in a set of headphones for personal listening / practice
  • to connect to an amplifier.
The zoom pedals use either a mono or (tip and sleeve) or stereo (tip, ring. sleeve) 1/4 inch jackplug - i.e a standard guitar lead.
You should plug it into a line-level or high impedance socket on your amp. With the pedal in play mode you can adjust the output level (gain) to match the input requirements of your amp by rotating the 'Value' knob (top right)
Feb 26, 2011 | Zoom B1 Bass Multi Effects Pedal
I HAVE A ZOOM MRS-802 B. IT will not start up. keeps reading HDD eror. Can not scan disc due to this reading pops up after step 1 of BASIC MAintenance Procedure. Does not go to ExtFunc pops back to...
Mine did the same thing. Just by chance we had a universal laptop power supply unit with interchangeable tips made by powertran & my wife said to give it a try. The unit has a display window on it & it reads 16.9 volts when the zoom is running. When I plugged it in I couldn't believe it was going through it's start up menu. On the package it says 15 - 20 volts DC 90 watts & I reckoned it shocked the zoom into working again...well anyway, it worked & the zoom is running again. The power box package cost $89AU that I got at an electronics store.
Jan 30, 2011 | Zoom Music
My amp, was working fine last night, it wont turn on, and i tried switching guitar, cables, even power supplys and still wont turn on, i heard a pop last time i used my amp, and then the signal was lost...
The unit will require repair and if you are not adept at electronics, you will need to take it to a shop. Likely there is failure in the power supply or amplifier that has blown the fuse. Replacing the fuse WITHOUT repairing the cause MAY do additional damage.
Dec 28, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Samson Technology Zoom R16 Recorder / Interface / Controller Logo
764 people viewed this question
Top Samson Technology Music Experts
Michial Gueffroy
Chris Larocque
DROPNDEAL
DROPNDEAL
Are you a Samson Technology Music Expert? Answer questions, earn points and help others
