Question about Phil & Teds Explorer V2 Twin Stroller
Fold Can't fold up
    Novelist:
  • 200 Answers
The manual was located here, it is a big file! After unzip it shows a complete manual in .pdf format:
http://philandteds.com/us/Support/Instructions
Posted on Jan 06, 2013
How do i fold the back seat down on the 1998 ford escort.not remove, fold down
Some have buttons some have levers, push / pull button/ lever & push seat back forward to fold
Nov 28, 2016 | 1998 Ford Escort
I can't fold my caddytek lite 11.5 v2 cart
I'm sure you figured this out by now, but for others stuck with the same question, here's how you fold it: the upper handle of the cart is 'locked' into place with the lower cart just above the upper bag strap. It's the same plastic piece that adjusts the angle/position of the handle. Slide this plastic piece back up the shaft (toward the ball holders), and the upper handle will release & fold down. The 2 side wheels also fold in at the same time.
Jan 21, 2013 | Caddytek CaddyLite 11.5 v2 Deluxe Push...
Yukon xl 2009 passenger power fold mirror won't fold
the cable that controls the mirror is more than likely broken or if it's gear driven the gear is stripped or broke. I would first try to take the switch apart and clean it
Jul 14, 2012 | 2009 GMC Yukon XL
Need help to print brochures
You can take help from a brochure printing company that would provide you best attractive designed brochures for your business or service.
I can suggest you best template collection that you can use as a base template or for inspiration.
Brochure Templates PSD would provide you a wide range of templates which is designed carefully with best fonts, colors, and layouts.
Mar 12, 2012 | Office Equipment & Supplies
I can't find a latch, lever or anything to fold my 3rd row seat down on my 2003 GMC Envoy
you have to pull the part you sit on up and forward (to front of truck) then the backs will just fold down sams as trail blazer
Mar 02, 2012 | 2003 GMC Envoy
2007 passenger folding mirror will not work
{: ) Have someone control the power fold buttons, while you check closely the passenger mirror. If you can feel or hear even a faint hum of the motor while commanded, try giving it a little help, but don't force it if you think it doesn't have enough power to extend or retract itself. The motor could be really stuck or inoperative.
Sometimes when the mirror has been accidentally or manually folded, it needs to be reset by just pressing on the fold buttons a few rounds and let the mirrors fold by itself. Like an exercise.
If you hear the humming noise whenever the fold buttons are pressed, we can assume that the circuit on that side is ok since it is responding electrically, and that a jammed or stuck mechanism is preventing it to move.
If you don't feel or hear any humming, as in totally no sign of response, then there will be additional considerations before deciding to go for a replacement mirror. You will need to confirm if the fault is on the wirings, a door module, or the mirror motor itself. A scan tool test may be recommended for effective diagnosis.
The power fold mirror can be serviced as an assembly. So, goodluck.
Aug 30, 2011 | 2005 GMC Yukon
We can't get the stroller to fold correctly, it worked once but we cannot get it to fold again.
I can't get my First Years Wave stroller to fold close. I have handle positioned down along with back wheels. Then slide red button, pull on handle/lever thing, but it doesn't fold the legs down. HELP PLEASE!
May 18, 2011 | First Years The Wave Stroller Crimson...
Hello, I recently bought a quinny buzz 3 (second hand) and its very difficult to collapse the frame, but it's easy to open it back up. What would I need to do to fix the problem?
Good Evening
It sounds as though you're not quite depressing the fold buttons fully when trying to collapse it, so you're pushing against the natural spring of the chassis which is making it difficult.
The Buzz is easiest to fold when you're standing in front of it. Either remove the seat unit, or make sure it is forward facing and in the upright position before you start. Swivel the front wheel straight and lock it into position. Standing in front of the Buzz, push the left side button in until you can't make it go any further, then roll the right button toward you as far as possible. It should only require a small amount of pressure to fold the unit, but remember, due to the style of the automatic unfold you are working against it to fold it up. If you hear any clicks, pops or creaks, don't force it as you'll break the fold knuckles.
If this still doesn't work, give the chassis a good, thorough clean to make sure no dirt or debris is causing the problem. Use a dry Teflon spray (found in the laundry aisle of most supermarkets) or normal furnature polish with a soft dry cloth and give the whole chassis a thorough cleaning. Then as you're folding it down, follow the black plastic down the central tube as it goes toward the front wheel unit to make sure its totally clean. This should make it smoother to fold.
Failing that, the product will need to be returned to the engineers for inspection - which country are you in?
May 18, 2011 | Quinny Buzz Three Wheel Stroller
Phil & Teds Explorer V2 Twin Stroller Logo
Top Phil & Teds Baby Gear Experts
Jennifer Rock
Jennifer Rock
ray gallant
Bill Boyd
Are you a Phil & Teds Baby Gear Expert? Answer questions, earn points and help others
