Question about Kenmore Refrigerators
Kenmore refrigerator model 9751751
Ice maker stopped making ice
applianceboy
  • 77 Answers
SOURCE: Kenmore refrig not making ice and top shelf area in refrig not cold
if you are having tempurature issues make sure the fan in the freezer is operating. it should be on when the compresor is running. this may explain both warm fridge and no ice.
Posted on Sep 26, 2007
  • 109 Answers
SOURCE: ice maker
verify the water supply to the valve first, second verify valve to icemaker works(unit has dual valve at rear bottom of fridge, switch plugs, then press water dispenser and see if icemaker fill with water ) if fills icemaker is bad , if not valve is bad. replace one or the other.
Posted on Mar 28, 2008
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
  • 351 Answers
SOURCE: Kenmore Ice Maker Not Working
Probably need a new ice maker, whirlpoolpartssurplus.com
Posted on Jun 23, 2009
SOURCE: GE refrigerator ice maker model can9 stopped
The schematic to my CAN9 is cast into the front cover.
Posted on Apr 04, 2010
Kenmore refrigerator Monel 1065682 has an ice maker button to turn on and off. Left on vacation and did not shut off. Will the ice maker stop making ice when full or will continue to and overflow?
If water is still on at house it will make ice and stop when full. Don't worry but next time you go Dwayne sure to turn pacemaker off and turn water off to house for safety
Feb 12, 2016 | Kenmore Refrigerators
106.57029 ice maker intermittent
there is usually an ice overflow switch or electric eye
sensor telling the ice maker that the bin is full. Something
may be obstructing this.
Nov 08, 2013 | Kenmore 57029 Side by Side Refrigerator
I have a Kenmore model number 106.51552104 my ice maker stopped making ice.. The water on the door still works but no ice what should I do??
I believe I answered this one on another page of unsolved problems HERE. Thanks for the model number. If the ice slots inside the ice maker are empty try pouring tap water in the slots and allow the water to freeze. If after the water freezes the ice drops into the ice bucket and the ice maker does not refill this would indicate that the side of the=> W10408179 Water Inlet Valve is defective on the side that controls ice maker water supply. If the ice maker just sits there and does nothing this would point to a defective ice maker. Depending what is wrong with the ice maker will determine what parts are replaced. Here is a list of those parts here=> Kenmore Refrigerator Model 106.51552104 Ice Maker Parts and if need you may be able to find a complete ice maker replacement by asking. Most people don't like replacing ice maker parts. I am here should you have questions or comments, Sea Breeze
Aug 30, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My kenmore refrigerator stopped making ice. in door water still works model 106.5779*703 Ice maker is on, door bin is clean
make sure the unit is on and the flag is in work position.
if tis not help you might need to replace the ice maker unit which go for 120-150$
Dec 28, 2009 | Kenmore Refrigerators
Jun 23, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator ice maker stopped working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
mnnmbnm
Jan 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker won't stop making ice
it's time to replace the ice maker, it will not stop, the you can feel the small bar when it looks in to the of position.
Dec 10, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore side by side refrigerator
Check the water valve in back of refrig.. u have a double valve... one side for water the other side for your ice maker.. make sure ice maker valve is working.
Sep 11, 2007 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
