Question about Skil 7 1/4" Magnesium "Mag 77" Wormdrive Saw With Twist Lock Model # SHD77M 72
I need to know how much oil goes into a skilsaw worm drive resvr.
I am changing the oil in my worm drive saw. How much goes into the
reservoir of an industrial worm drive saw by Craftsman Skil
  • David Ford
    David Ford May 11, 2010
    On some worm drive saws there is a fill line on the side. If you give me the model number i will research and see what I can find for you.
  • 2,176 Answers
Haven't heard anything so I checked the Milwaukee worm drive saw and they recomment about 1/2 oz. Make sure you use an oil for a worm drive that is not foaming. Hope this helps. Also when checking oir level have the shoe set for max depth and on a flat surface remove the oil plug, when filling tip the saw on its side and fill, turn back over and allow excess oil to run out if overfilled.
Posted on Jan 24, 2009
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 142 Answers
If it's a Skil 77 that Craftsman is using it's maked right below the 1/2 inch fill cap on the right hand side of the saw. It's basically just below the bottom of the fill cap.
Posted on Dec 16, 2011
Im trying to figure out how to adjust the bevel on my new skilsaw 7 1/4 worm drive. I adjust the lever and I'm trying to turn the shoe of the saw and it won't turn. Can somebody please help?
New saw = tight pivot points where the saw meets the shoe. You have one in the front and one in the rear. As long as you are sure that the bevel adjustment lever has loosened its grip on the quadrant. You can spray the pivot points with some wd-40 or even attempt to muscle the shoe to get the pivot points broke lose. Just not so much that you separate the shoe from the saw.
If you still cannot get it I would return it for another one.
Mar 03, 2016 | Skil - Skilsaw 77 Saw Hook - / Bosch...
I need the outer flange/blade clamp for my Skil model 77 type 15
This sounds like a worm drive. Try going to this web site to order your part.
http://www.ereplacementparts.com/skil-shd77-f012sd7700-worm-drive-skilsaw-parts-c-130_160_7479.html
This is the part for the blade clamp washer $5
Blade Clamp Washer
This is the flanged plain washer $4
Blade Clamp Washer
and retaining ring $4
Retaining Ring 2610341359 for Power Tool eReplacement Parts
Dec 03, 2014 | Skil Saws
What type of oil does the saw require and how much?
Your Skil tool has been properly lubricated and
is ready to use. However it is recommended
that the gears be relubricated only with Skil
lubricants: No. 80111 (8 oz. tube), No. 80112
(pint) or No. 80113 (1/2 gal. can).
Always check the
oil level before
using the saw. To
check and add oil:
Remove plug from
power source and
place the saw's foot on a horizontal surface.
Remove oil plug using the same wrench used
to remove the saw blade. The oil level should
never be below bottom threads in the housing.
When adding oil, fill until oil starts to run out of
oil hole at arrow on housing and replace oil
plug.
part #80111 and is available from http://www.ereplacementparts.com.
Sep 27, 2012 | Skil MAG 77-75 7-1/4-Inch Magnesium Worm...
How do I replace the spring on the retractable blade guard on a model 77 worm drive skilsaw?
Bearings maybe......I'd also check the armature fan and see if it came loose. Either way it doesn't sound cheap!
Aug 07, 2011 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
I need to know what kind of oil do I use to change the oil in my skill saw 77? Mine is pretty dirty, runs great but thought I should change the oil. Thanks Bill
Use Skil worm drive oil #80111 ($5-$6.00) at Home depot, or Bosch WD7LUB 2.3 FL. OZ. (I bought for $3.50 at Bosch service center.)
Aug 28, 2010 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
How much/what type of oil goes in my old wormdrive saw?
their owners manual doesn't give an exact quantity however they say to unplug the tool first then remove the fill plug and the lower plug and the oil should run out past the first thread. they recommend using their oil 80111 8 oz. tube however any good worm drive lubricant will work, Don't use anything like gear lube because the worm drive lube has an additive for anto foaming. Let me know if you need more assistance
Nov 18, 2009 | Saws
Need to know the type of oil that the skilsaw 7 1/4'' mag 77 use
skil recommends using their lube 80111 for an 8 oz tube or 80112 for a pint. however any good quality worm drive lube will work. Don't use a gear lube because the worm drive has additives for anti foaming and gear wear added. Let me know if you need more help
Nov 17, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Need lower blade guard for Skilsaw Model Model 77
Yes I do Know where, here you go !
http://www.toolpartsdirect.com/skil/skil-34.html
Nov 09, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Skil 7 1/4" Magnesium "Mag 77" Wormdrive Saw With Twist Lock Model # SHD77M 72 Logo
2,129 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
