Question about SpectraVideo Logic 3 - iPod i-Station 3 Speakers (Black) - PC Docking Station
Logic3 speakers don't work
No sound and won't charge ipad
Connecting samsung surround sound to palsonic tv.
see the connection attached. God bless you02ba774a-7740-4204-81bc-4ffcc9660684.png
Jul 18, 2013 | Audio Players & Recorders
My iPad won't find my Bluetooth speaker
Go to settings, General, blue tooth and remove any "other" previous paired BT devices & Turn off BT, then go to Sett. General, scroll down to reset and reset network settings, this will not delete anything. Power off BT speaker. after iPad re-boots turn on BT Speaker First, make sure BT is off on iPad as well as WIFI-wait like 10-15 seconds and then turn BT on in iPad it should see your speaker now and let you pair it up.
Jan 14, 2013 | Harman Kardon JBL Flip black
I have a 12 inch Klipsch synergy series sub. for my surround system and want to put my JL audio 12w6 speaker in the box, will the amp drive the woofer or is the ohms a factor?
ohms is a big factor. also it will probably take more power to drive the W-6 so it won't sound as good. I suggest you don't do it. especially if you can't match up the ohms. You will fry the amp, or it will sound like ****.
May 19, 2012 | Car Audio & Video
How do I make the new iPad's battery recharge faster?
There are many things you might be doing wrong but slow battery charge is a problem with the new iPad. The battery is actually a lot bigger than the iPad 2 which means it is going to take you much longer to charge.
Use the provided charger and don't charge from your computer. It is almost twice as slow to do it plugged into a computer. Charge it at night to give it the most time to charge as possible. I usually turn it off so programs don't run and slow down the charging speed. Every little bit helps.
I can help you with other things too if you ask.
Mar 27, 2012 | Apple iPad HD
2010 Elantra Touring - car won't start - doesn't turn over (battery is fully charged), clock/radio & A/C units don't work, and EPS doesn't work. Dealership cannot figure it out.
sounds like a fuse. check them and get back to me. If the shop you took it too cannot figure it out they probably should not be a shop. i hope they didnt get you for a diag fee. Im going to locate a wire diagram to help you figure this out.....Also you said you put a new battery in the car, check that the battery terminals are clean and tight.
Oct 06, 2011 | Cars & Trucks
I have a problem with my computer speakers because they don't work & i've even tried to to use headphones & even they won't work so what should i do
It sounds like it may be a driver issue, but first, I'm assuming you check the volume controls on Windows to make sure it wasn't muted or anything. Yeah? Good. So let's get to the drivers. I actually have a tip here that will show you how to do this. Check it out: http://www.fixya.com/support/r9307246-fix_sound_installing_new_driver Hope this helps!
Aug 27, 2011 | Computers & Internet
Hi want to connect bose 901s with active equaliser to my pioneer sc-lx81
According to this picture, you're in luck BUT...
http://www.avland.co.uk/pioneer/sclx81/rearlrg.jpg
(Short answer from personal experience.)
There is no way around this part. Get a separate power amp for the 901's if you want to use them in a multichannel way or alongside non-901 speakers. A good 100-wpc amp will do. (I like Carver)
Connect the Active EQ between the Front pre-outs and the amp input. Run speaker assignment, levels, etc and have fun.
Helpful Hint: If you don't have sufficient between-speaker room for proper reflection off the front wall you CAN turn the 901's around and you won't believe the amount of air these things push! I have actually felt it ten feet away after explosions or crashing ocean wave sounds. Now THAT is multi-media.
Oct 09, 2010 | Bose 901 VI Main / Stereo Speaker
SpectraVideo Logic 3 - iPod i-Station 3 Speakers (Black) - PC Docking Station Logo
Top SpectraVideo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a SpectraVideo Audio Player and Recorder Expert? Answer questions, earn points and help others
