Question about Crosley CE35111AA Electric Kitchen Range
Jenn-air slide in electric range F1 signal continious beeping
Jenn-Air Range displaying Error F1-8
Did not find an error code "F1-8"
I did find these. Seems that about everything that can go wrong with a Jenn Air is related to the clock.
https://www.repairclinic.com/RepairHelp/FaultCodes/26/Range-Stove-Oven
Sep 22, 2017 | Jenn-Air JES8850AAS Electric Kitchen Range
Beeps and flashes F1 while trying to use covection roast
Usually this is a failure in the electronic control. We rebuild a lot of these.
Best Regards,
Bruce
www.fixyourboard.com
Jun 12, 2010 | Jenn-Air SVE47100 Slide-In Electric...
F1-7 code
F7-E1 - Common Switch Wire Is Defective - This error occurs when common wire to latch switch and door switch is shorted.
Check all connections at control board and at the latch switch and door switch.
If connections are ok, then check individual switches as outlined for the F5 error code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 07, 2010 | Jenn-Air SCE30600 Slide-In Electric...
F1 fault code? Jenn-Air SVE47100
HI. This is concerning the relay board that is installed in your unit. I would recommend to inspect the entire wiring harness that is linking the relay board to the elements, and other power component's. If the harness is ok, and connected tightly, and correctly, this will confirm that the relay board has failed. It must be replaced in the case. Be sure to inspect all wiring harness connections for corrosion before you replace the board. This could be as simple as a failed connection.
PRB Part Number is #71002144
Nov 14, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air SCE 30600, oven error codes F1 and Probe
An F-1 error code on your model means the element was energized when it should not have been, A shorted interconnect harness or failed power relay board.
A probe indication could be a failed meat probe jack or bad harness in a unit that has one. In a unit without a meat probe, suspect a bad board.
Both conditions would warrant bringing in a tech.
Before you do, turn off the circuit breaker fot 3 miutes and turn it back on. This will reboot the boards. If problem persists, the call a service tech.
Nov 04, 2009 | Jenn-Air SCE30600 Slide-In Electric...
My Jenn-Air SVE47100 slide in electric range does
Obviously it does not work fine. The thermostat sensor or the stat itself could be an issue. Can you see the sensor 'bulb'? Clean it with oven degreaser and steelwool. What is the temp in the oven with a 'oven thermometer'? Is this consistent with the oven readout?
Sep 24, 2009 | Jenn-Air SVE47100 Slide-In Electric...
F1 code. Stove is beeping
F1 defective touch pad or membrane. 1. replace touch pad or membrane ( this problem is usually the touch pad).
or
F! watchdog on board. 1. replace touch pad or clock assembly (also called the ERC).
Aug 25, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Beeping noise - letters appear fc
Since Jenn-Airs codes are F1-F9, the cicuit board may be on the way out since the code resets after you turn it off for a while.
Sep 14, 2006 | Jenn-Air SVE47100 Slide-In Electric...
Crosley CE35111AA Electric Kitchen Range Logo
65 people viewed this question
Top Crosley Kitchen Ranges Experts
Vitaliy Gins
Vitaliy Gins
Oloyede Monsuru
Andrew Taylor
Andrew Taylor
Are you a Crosley Kitchen Range Expert? Answer questions, earn points and help others
