Question about Sanyo DS24425 24" TV
My Sanyo DS24425 24 inch screen moves slightly to the left and stays there. its very frustrating because i play games on that tellie and cant see part. it's not parted halfway though. its like one a couple of centimeters. the right side is black.
    Scholar:
  • 47 Answers
The problem can be corrected by only qualified technician. There is what is called the service man's menu which can only be accessed by a partciular code in service manual for that particular TV. Your local service technician should be able to locate the the manual and then perform what is caller a horizontal centering adjustment. In today's tv's there are no alalog controls for easy adjustment, it all done with eprom ic which allows the manufacturer to use the same chasis for many different picture tube sizes. If you could get manual. and have basic computer skills , you could probably do it yourself. You might try ordering the maual from Tritrinics/Cititrinix 1-800-638-3328. Scrivitron
Posted on Jun 29, 2007
SOURCE:
How to reset 46 inch Sanyo flat screen modelz#46841
find the factory reset access code feed it on your remote while facing it to the telly then a technical menu will appear ..........NOTE AND WARNING ! Dont attempt this @ home if you are not a qualified tech u may mess up the tv settings completely besides i dont see why you wanna reset the tv
Oct 08, 2015 | Sanyo Televison & Video
LG 4200A
hi the problem wouldnt be the screen instead your probably right with the video card if the screen was dead it would stay black but with it changing slightly you know the screen is gettin power.
When you press the controll does an led flash on the telly to tell you the controll is working just incase the telly is stuck on an av channel.
If you have got a dvd player hooked upto the telly switch this on with the telly on and see if the telly will work using the dvd player this would rule out the fault being with the ports on the telly not picking up the signal.
If this still dont change anything then it could either be a resistor gone or a couple or it could be what you thought with the video card/controller but their is no way of knowing without testing the resistance at certain points on the board but it deffinately wouldnt be a problem with the screen so it shouldnt cost to much to repair.
It mgith be a case that the telly has overheated and blown a resistor thse can be brought for pennys but locating will be the problem let me know what you want to do and wether you are considering doing the repair yourself if you are you will need schematics to follow off and also multimeter to test resistance at certain points on the board.
Jan 16, 2008 | LG 42LP1D 42 in. LCD HDTV
My tv is a 42 inch lcd sanyo the left side started having vertical lines andn then fuzz when turned on then it slowly started staying that way and going farther across screen if you move the tv around it...
Its probably a bad ribbon cable on that side of the tv. if u put pressure on that side ( on the plastic) it may resovle the issue. otherwise it could be a bad tcon board and the tcon board would need to be replaced.
Dec 15, 2013 | Sanyo DP32746 32 in. LCD Television
Change tv screen size
Refer the user manual to your TV for details about changing the aspect ratio of picture.
Jul 10, 2013 | Sanyo Televison & Video
X box stays on and telly blurryy but showing the picture?
It sounds like bad soldering, your tv doesn't freeze it's your xbox video/audio output that does. Did you use the towel trick, that is one possible way to have gotten it. You should send it to Microsoft for repair.
Mar 14, 2009 | Microsoft Xbox 360 Console
Image is too large for screen
**** man, i have the same problem, sucks in video games where the objective is shown at the top of the screen and i can only see the bottom half of the text.
May 22, 2008 | Apex Digital AT2702 27" TV
Sanyo DS24425 24" TV Logo
103 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
