Question about Farberware T490C 1500 Watts Toaster Oven with Convection Cooking
Need thermal fuse for a Bravetti oven Tf 141, D139PRLP
3 yr old Bravetti Plat. Pro microwave/convection does not heat food. Lights, turntable work. Is there a fuse somewhere that is blown???
in 90 % of my microwave is damaged the magnetron, on the electronic plate you have 2 fuses and dawn under the rear fan you have another fuse(glass fuse) in a plastic cover.
Feb 21, 2010 | Euro-Pro EP278 Bravetti Platinum 1500...
I broke the plastic dail for the toaster/toast/bake/ dail. Where can i get a new plastic dial?
Contact Euro-Pro by phone at (800) 798-7398. b The replacement knobs will cost you about $10 (3 knobs and shipping and handling) Call-don't email as I got the wrong information when I emailed. You are better off speaking with a person, even if they are in India.
Oct 13, 2009 | Euro-Pro EP278 Bravetti Platinum 1500...
Bravetti Toaster Oven
If you just purchased the toaster oven, contact the store that you purchased it from, and they should be able to get a manual for you. If you've had the toaster oven for awhile (usually 3 months or more), you'd have to contact the manufacturer (Bravetti) for the manual--a lot of times, their phone number is printed right on the back (or bottom) of your oven!
Good luck! :)
Aug 26, 2009 | Toaster Ovens
THERMAL FUSE BLOWN ON KITCHEN AID KCO100508 TOASTER OVEN. WHERE CAN I BUY A REPLACEMENT ? This Thermal fuse [ 206 degrees C ] is a ceramic housing mounted to a bracket near the oven wall. It contains a...
Thermal fuse is a one time safety device, order by specification. My Kitchen Aid toaster oven has one on the side with the controls marked 206c for 206 degrees Celcius when it blows, and marked with a part number that when Googled was found to be 2 amp. The fuse blows in this sequence: temperature first, then if that fails the regular fuse action will kill the circuit at 2 amps. I called electronic supply places around Los Angeles. $1. 25 later I have my part. Mouser electronics carries them for .44 cents. Placed the new one on the ceramic base of the old one, and am back to using my favorite toaster oven. Will not be using it for broiling again - that is when it got hot and quit on me.
May 28, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
Lost instruction manual for Bravetti Model#TO285 toast/conv.oven
The same unit was marketed under the Euro-Pro name, with the same TO285 model number. The manual, as a PDF, as well some replacement parts are available at this link:
http://www.euro-pro.com/europro/default.aspx
Hope that helps.
Nov 30, 2008 | Euro-Pro EP278 Bravetti Platinum 1500...
Time control knob for bravetti platinum pro convection oven
Thanks for allowing me to help you. The replacement knob is available from the following link:
www.euro-pro.com/europro/productdetail.aspx?pid=1D76CC6A-4A86-4D6B-8120-7DB204F16DF4(Euro-Pro+Base+Catalog)
You can also get a user's manual if you need one.
If you found my assistance valuable, please give me an appropriate rating. Thanks for using FixYa!
Oct 19, 2008 | Euro-Pro EP278 Bravetti Platinum 1500...
Farberware T490C 1500 Watts Toaster Oven with Convection Cooking Logo
70 people viewed this question
Top Farberware Toaster Ovens Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Farberware Toaster Oven Expert? Answer questions, earn points and help others
