Question about RCA 27V530T 27" TV
Power cord We have a RCA tv and we were moving. While we were moving the cord came unplugged from inside the tv. We cannot find where to plug it back in.
    Sergeant:
    Champion:
  • 346 Answers
You would need a qualified tv personal to re- insert the power chord
Posted on Feb 02, 2009
RCA F19421 Stuck on video since switched from dishnetwork to cable
Some RCA TV's have a "video" option that requires you to use the original remote control to cycle up or down the channels.
Also, try unplugging the TV's from the power receptacle for 30 minutes....some times, that will cause the TV to reset.
With the power cord unplugged, manually push the power button on the front of the TV to discharge all capacitors.
Ensure the 30 minute is complete before plugging it back in.
Let me know if this works.
Thank you!
Jan 02, 2014 | RCA F19421 19" TV
46LA45R RCA 46" TV does not power up following a power loss
If a power loss someone needs to open set and see if when power came back it popped the line fuse, follow power cord inside to the fuse which it goes directly to.
Dec 11, 2012 | RCA 46 46LA45RQ LCD TV
Rca l26wd23 will not turn on, screen remains blank.
TVs today are becoming similar to computers and use hardware and software to deliver the picture and the sound. Similar to how a computer can lock-up and then you have to re-boot, TVs sometimes have problems that you can fix by resetting, or rebooting, them. To reset your TV, unplug the power cord from the wall outlet, power strip, etc. Keep your TV unplugged for about 5 minutes. Then, plug the TV back in, turn the TV on, and see if the problem is fixed. If the problem remains, then please contact RCA Customer Support using the Support link in the top navigation on this page.
Jul 08, 2011 | RCA L26WD23 TV
I need to replace the power cord
you will have to open up the back of the tv. This can be a very dangerous as there can be a lot of stored voltage inside even if its unplugged. If you choose to do it, look on the back of the circuit board for an empty connector that used to have the power cord. Sometimes they are soldered striaght in, Do you have a replacement? Also if there is some wire left you can splice the wires togeher without having to do any soldering.
Feb 03, 2009 | RCA 27F530T 27" TV
Blurry picture
Try to reset first if nothing happens we proceed another solution;
Resetting the TV
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can saved time.
1. Unplug the TV power cord from the power outlet for 6 hours.in order to dessipitate the charge current.
2. Unplug any connected devices (Satellite, DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Jan 08, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
RCa P52926 52inch
CHECK THE SIMPLE THINGS --MAKE SURE THE PLUG IS STILL PLUGGED IN AC...IF YOU HAD SOME POWER INTERUPTIONS ...MAY HAVE BLOWN THE MAIN FUSE BY THE POWER CORD.DO YOU SEE ANY LED LITES ON THE FRONT OF TV..POWER INDICATOR??? .REMEMBER ,ALWWAY S UNPLUG THE TV IF YOU TAKE THE BACK OFF...TUNICA
Sep 04, 2008 | RCA P52926 52" Rear Projection Television
No picture, no sound, power light steady green
First: Check the power outlet. Check it with a good lamp so you know you are getting power to the set.
Secondly: Check the power cord. Wiggle it around the molded ends to make sure it is not open inside the molded portion of the plugs.
Thirdly: If you know for sure the set is getting power and still no indication at all (you should be getting some little light on the front panel; standby indication) then there may be a fuse on the back panel or just inside the back cover (you will have to remove it; after unplugging the power cord) that needs replaced.
Fourthly: After all these checks if you are getting nothing, you may have some failure inside that is very serious. Normally we do not recommend serious repairs to a set over 4 years of age. This is because the set is likely to develop some other problem soon after the repair is made; further, the repairs are getting more expensive day by day while the price of new sets is coming down dramatically. Lastly, the new sets have better picture, longer lasting circuits and better features.
Hope this is a good solution for you.
thanks for your questions.
Aug 25, 2008 | RCA HD52W56 52" Rear Projection HDTV
TV won't turn back on after power cord was disconnected from unit
If power cord was jerked out of the outlet or set, make sure it wasn't damaged. If it was unplugged violently, the circuit board inside the set could be damaged. Also make sure the outlet that it is plugged into is not damaged or a switched outlet.
Aug 03, 2008 | Fujitsu Plasmavision 42" TV
TV turns off by itself, juggling power cord causes TV to come back on
It could seem to be a power cord problem But when you move around the cord you are realisticly flexing the printed circuit board assy. If you know all the safety issues around the servicing a solid state tv, then Of course I will assit you, in any way I can, But you must be aware of the high voltage that these sets store , even if they Are unplugged. Its a total safety issue. If you have no experience using a multi- meter as well as the safety issue awarness, then PLEASE seek a pro to assist you with this reapir, as it will get worse in the long run and cost ya more to fix, as everytime you move around the cord and the set shuts off, then goes on , your surging the componets!. Good Luck
Jun 19, 2006 | RCA F36668 36" TV
RCA 27V530T 27" TV Logo
67 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
