Question about Music
I have a solid state guitar amp its a crate GTD65 it has a chorus problem i cant turn off the chorus how do i get this taken care of i want to be able to play my guitar again
Help i need to fix this if anyone can tell me what to do i will be very thanful im unemployed and i cant pay 65 dollars to repair it if someone can tellme what to do thanks
  • 6 Answers
SOURCE: fender M-80 electric Guitar Amp.
You might have a ground problem. Does it do it in different outlets or when you take it to someone else's house? One easy solution to ground problems can be running a three prong to two prong adapter on the power cable. Give that a try and see if it helps.
Posted on Nov 10, 2008
  • 11 Answers
SOURCE: turned on switch to crate V33-212 and it shorted out
Your amplifier is a solid-state rectified tube amplifier. This means that a tube is NOT used for the power supply. Why is this significant? Because most of the time you have the problem you are describing, it is because of the tube rectifier.
Since this amp does not have a tube rectifier, the problem is likely one or more of the tubes. I have seen in 95% of the amps I repaired that the tubes were the cause, and since the amp is so new, I would suspect tubes first.
Now the hard part: which tube? Without a tube tester, you will have to use the 'firewall' technique. You will need to get a bunch of replacement fuses, as you might go through a few untill you find the problem. Radio Shack is a great place for fuses (make sure they are SLOW BLOW type).
The problem is almost guarenteed to be the power tubes: they are a big failure mode in tube amps (the preamp tubes are not as likely the problem).
This is what I do at a customer site without a tube tester:
(1) Have either a KNOWN TO BE GOOD REPLACEMENT SET OF TUBES or a NEW SET OF TUBES.
(2) Have plenty of fuses.
(3) Start with power tubes: they cause most of these problems. Replace burned out fuse.
(4) Replace all 2 (or 4 in your case) with the good tubes.
(5) Turn on amp and play on it (30 minutes at various volumes and settings). Turn it on and off many times using the on/off procedure your amp requires (like using the standby switch on some models).
* if the amp plays and works, likely you had a bad power tube. If you are blowing fuses, the problem is either the power amp circuitry or the preamp tubes.
* Leave the good power tubes in before going on to the next step. Also: the minor difference in bias wont matter for what we are doing now: the bias being WAY out is almost never the cause.
(6) Check preamp tubes (easy to do, as this does not require us to poke around on the insides).
(7) Replace burned out fuse (atleast number two by this point).
(8) Replace all preamp tubes.
(9) Turn on and repeat step 5.
* Blowing fuses at this point means atleast two types of repairs needed: retention tube sockets or someone to look inside the amp. Either way, this is a serviceman repair (things I do). Since the amp is so new, take the warentee buyout and throw it back to where you got it. Crate is real good about dealing with these issues (if you are the only owner and it is within warantee).
If you need to contact warantee support, you can tell them you have had the amp re-tubed and the problem still persists (meaning they can brush you off with 'just get it retubed and then call us if there is problems'. This is like 'take two asprins and call me in the morning: 95% of all tube amp problems can be fixed by this (retube, not asprins).
If you have to do the warantee route, KEEP YOUR NEW TUBES. The preamp tubes are fine, but the power tubes may be damaged. Wait for what Crate tells you before you use them. This is if you are cheap. I would pitch all of the tubes and consider the 70 bucks as my cheap attempt to bet I am in the 95% solution number (tubes are the cause). Otherwise, the repair will cost shipping at a minumum. Dont you love it: tube amps are expensive and require someone with deep pockets to enjoy the tone. But what can we do: tubes DO sound better and when everything is working, they perform reasonably well.
Good luck on this!
-mike
Posted on Mar 30, 2009
danforddan1
  • 192 Answers
SOURCE: amps broken need to fix it
Their may be a schematic on the inside of the amp.I don't remember if Crate puts one or not. And I have had several Crate amps. never needed repair except for tube replacement. If there is not one in side , go here and find what you need . http://www.crateamps.com/support/warranty/ Good luck DFD please rate me TK U
Posted on Apr 19, 2009
bolinlamar
  • 157 Answers
SOURCE: looking for a circuit board manual or diagram for
try the Crate Website
http://www.crateamps.com/support/discontinued.phprate
Posted on Aug 20, 2009
  • 5 Answers
SOURCE: Fender Frontman 65R Solid State guitar amp.
There is a protection thermistor in the circuit to keep it from over-heating, this is why it works again when it cools. Check and make sure you are not covering any ventilation holes, or if the unit has a fan, make sure it is working.
Posted on Aug 22, 2009
Buzz across all channels in crate rfx120
I also have this issue. Same crate combo amp. There is a loud buzz emitted only when there is a cable plugged in. Cables and instruments checked good, only possible issue is inside the input of the amp. Popped it open, solders and connections were intact and appeared solid. Anyone have a guess as to why this is happening?
Feb 12, 2012 | Crate Music
Flexwave 120H Speaker wire shorted amp won't work
Solid state amps are very subject to blowing out the output transistors if speaker leads get shorted. Take it in for repair.
Aug 31, 2011 | Crate FlexWave FW120H Guitar Amp Head with...
Basically i cannot seem to make the pedal work in tandem with my crate flexwave 120w 2x12 dsp amp i prefer to use the built in dis,chorus, and delay effects but can find no way to put the hb01 behind the...
Norrmally you run the guitar into the pedal and then into the amp. IF you want it behind the built in effects, The look on page 6 of your users manual showing the special cable you will need to do the "insert" of your effects pedal.
If you don't have a manual, download it here:
http://www.crateamps.com/pdf/manuals/FW120H_OM.pdf
Jan 11, 2011 | Behringer HB01 Hellbabe Wah Pedal
Crate GTX-30 Guitar Amp Schematic... The thing blew, and I need to replace two components...
Hi. use this link to check for the schematics.
or
music-electronics-forum.com/sitemap/f-60.html.
take care.
May 31, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
I have a small crate rx15 solid state amp. The
This is likely a power supply failure OR the amp chip is bad, It is probablly in the TDA family such as a TDA2050
May 15, 2010 | Music
I have a small crate rx15 solid state amp. The power light comes on, but no sound comes out of either the amp or headphone jack. No buzz etc....
Power light means very little. If unit has a preamp output, plug a set of headphones into it and see if you can hear anythin going through. (it will be weak). If you can, the power amp section is bad. Take in for service.
Mar 29, 2010 | Crate Music
Dirty high switch on a Crate practice amp
NEVER use switch cleaner such as DeOxit on pots !!!!!
I have used CRC226 available at Home Depot electrical dept.
I SUSPECT that the resistance element in that pot is cracked. This is common if the knob sustained a hit. Replacing the pot is the only cure if the element is cracked.
Reviewing the schematic, ALL audio passes through the wiper on the HIGH tone pots. If the wiper is intermittent, so will be the sound.
If your unit is solid state amp, the pot looks like a 10K ohm LINEAR taper.
If you have a tube type, then the pot is a 250K ohm LINEAR.
Note that the other tone pots in the units are AUDIO tapers, but the high is a linear taper.
Get repair parts from either DigiKey.com or Mouser.com
Mar 23, 2010 | Crate Music
Crate Flexwave 120h (Half Stack) volume issues
Perhaps you have a bad capacitor on your volume control?
You can get an ESR meter and test your exposed isolation caps for leakage? The have to be removed so unplug the unit if you are gonna do any work inside the cabinet.
Also, try a shorter or higher quality guitar cable. This will cut impedance between the pickups and the amp.
Good luck and be careful!
Mar 08, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Looking for a circuit board manual or diagram for a crate mx120r guitar amp
You can try Loud Technologies @ 866-858-5832, techmail@loudtechinc.com.
They hooked me up with parts and schematic for my Crate G212XL.
Apr 18, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Music Logo
22 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
