Question about Black Box Media Converter Transceiver
Can't get the green light to come on.Only has power light on.
Can a converter box be faulty on arrival?
    Problem Solver:
  • 8 Answers
Yes. Anything can be faulty on arrival. But the green light not comeing on does not nessicarly mean that it is faulty.
Posted on Mar 12, 2009
2004 Chrys Concorde, new utility trailer, tail light converter. Problem: There is output from conv box in yellow wire, when turn signal is on, but when it is connected to the trailer harness, no output...
Your vehicle CANNOT be wired for a trailer without using the converter box. The only vehicles that do not require a converter box are the vehicles that use the stop lamp bulb as a turn signal. Your vehicle is equipped with SEPARATE stop lamp and turn signal bulbs.
To make the converter box work correctly, it must be wired according to the instructions to BOTH the stop lamps AND the turn lamps. The tail (or PARK) lamps DO NOT go through the converter box.
Your trailer uses the SAME bulb for stop and turn - THIS is the reason you need a converter.
The wire color for both your LEFT TURN and your RIGHT TURN are LIGHT GREEN/TAN. Although the wire colors are the same at the bulb sockets, these are SEPARATE circuits and must be wired to the correct wire at the converter box. (LEFT and RIGHT) The converter box will have an INPUT connection for EACH of these.
The wire color for your STOP lamps is WHITE/TAN. The converter box should only have one INPUT wire that connects to this. It doesn't matter which side of the vehicle you connect this wire to. All of the stop lamps are on the same circuit.
The converter will then have only one wire for LEFT turn and stop (usually YELLOW) this is the wire that needs to go to your trailer connector for left turn and stop.
The RIGHT turn and stop will most likely be GREEN coming out of the converter.
Sep 05, 2011 | Chrysler Concorde Cars & Trucks
Trying to hook up to digital converter box and cannot get the tv to see it? It won't let me in to set channels.
Check ur tv converter box a small button on the back of the converter box make sure it is not set to channel 4,make sure it set it to channel 3.Put ur tv on channel 3.Take the antena signal input put it in the converter box hole that call ANT.Take the wire that came with the converter box put the wire one side of it connected to the other hole into the converter that said OutPut.The other side of the wire should be connected to the hole in the tv said ANT hole.Now make sure ur tv converter box power a/c cord plug into the a/c power outlet and the power button is press on and have power to the converter box.The converter box now power LED light on indication should be on and it is green.Now the tv CRT screen picture should have a menu of the converter box funsctions.Just follow the on screen instructions and press the enter button on the remote and it will now auto scan for those free air Digital DTV channels.When the auto scan it reaches 100% is it done.Now u have done it.
Nov 12, 2010 | Curtis-Mathis Televison & Video
Wiring bath fan with Fan/ light combo. Want to operate the features on seperate switches. Have power wire Black/ White/Green. Each switch has own wire Black/White/ Green. In the unit there is a Blue/white...
If I understand correctly you are installing two wall switches.
Your switches are switch1 and switch2
Each switch has 2 brass-colored screws
If you have a double switch, see page bottom
And you are installing a fan/light combo with separate wires for fan and light.
Bare ground wires and green wires connect to each other and to green screw. A ground wire runs from fan/light to switch box where it connects to other bare copper wire and these wires will not be discussed.
Lets work from the fan/light down to the switch.
Blue-wire-fan connects to either brass screw on switch1
White-wire-fan connects to white Neutral (we'll talk about this wire as we go)
Black-wire-light connects to either brass screw on switch2
White-wire-light connects to same Neutral as White-wire-fan.
So you need 3 wires running from fan/light to your switch box.
One wire arrives at switch box and connects to brass screw on switch1
One wire arrives at switch box and connects to brass screw on switch2
One wire is the Neutral wire and it arrives at switch box and connects to other white wires inside switch box. Twist these wires together and cover with wire nut.
Now your white Neutral is connected to other white wires in switch box.
Each switch still needs another wire.
The Hot black wire from breaker box connects to brass screw on both switches
Pardon the crude drawing.
The switches would actually be located next to each other, but it was easier to draw like this.
Drawing shows 3 wires coming from fan-light to switch box.
The drawing shows the black and white wire arriving from breaker
The drawing does not show how the white wires are joined with a wire nut
If you have a double switch, with 2 switches stacked vertically.
The screw colors can be different.
Double switch could have brass screws on both sides, in which case your Load (fan-light) wires connect on one side of device, and your Hot from breaker connects to other side. It doesn't matter which side, but loads on one side, hot on other side.
Double switch could also have dark screw(s) on one side and brass screws on other side.
In this case, the black Hot from breaker connects to dark-colored screw(s)
And your Load (fan-light) connect to brass colored screws.
If you need more information, or if something is still confusing, answer back.
Oct 26, 2010 | Broan-NuTone Fan,Bathroom Exhaust Broan...
We unplugged out VCR, and now the converter box won't turn on. has power to it, but the little red light won't turn green.
plug your vcr back in, or undo co-ax cable from vcr and put antena wire to antena in on converter box and wire going to the back of tv to tv out on convrter box
Nov 26, 2009 | Insignia Digital-to-Analog Converter for...
My xbox has three red flashing lights, how can I get it working again?
My sons Xbox had the 3 red lights! It depends what colour of light is showing on your power pack the colour indicates what the problem is! The light will either be red,amber or green, my sons light was amber and that was due to a faulty power pack, Microsoft were very obliging and replaced the power pack free of charge,it arrived in 3 working days! Here is a link that will take you through the different lights and how to fix the problem!
http://support.microsoft.com/kb/907534
Hope this helps, good luck!
Jul 04, 2009 | Microsoft Xbox 360 Console
My digital stream converter box DTX9900 was purchased on 8/7/08
My (otherwise great...) DTX9900 converter box died with these same symptoms. (Units green LED flashes continuously and unit is dead)
Upon inspecting the unit I located a blown electrolytic capacitor on it's power supply board. After replacing the blown capacitor the converter has worked fine. A blown capacitor can be identified visually. The canister's top will be expanded out instead of flat. Just compare all of the caps. Look for any that are not flat on top. Blown caps will usually be discolored. The bad cap in my unit was a 330uf / 16v - 105c value cap. I replaced it with a slightly superior brand 330uf / 25v - 105c cap.
HTH
Jun 22, 2009 | Philips Magnavox 20MT133S 20" TV
Drive stopped working
I had the same problem - green light on power cord but when plugged in the green light would go off and the hard drive would do nothing. I took it into Geek Squad finally and it turned out that the problem was hard drive casing, which I had to have replaced.
Jun 07, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
I hooked my converter box direct to my v c r. Do I have to keep the green light on to record
yes, you do because no power to the converter box, no change in signal for what it was ment for.
Feb 18, 2009 | Insignia Digital-to-Analog Converter for...
Black Box Media Converter Transceiver Logo
215 people viewed this question
Top Black Box Computers & Internet Experts
1860ph
Level 1 Expert
Are you a Black Box Computer and Internet Expert? Answer questions, earn points and help others
