Question about Eidos Interactive Revenant for Windows
How Can I Run Revenant On Windows 7...It Say's Windows Can Not Run This Program.
I have the print master gold deluxe software and I'm not able to use it with window 7. please help
All you need to do is download & install Windows XP Mode for Windows 7
http://www.microsoft.com/windows/virtual-pc/download.aspx
Once installed you will be able to run all your favorite old programs , if you run into any compatibility issues , right click on the .exe file & select "properties" , compatibility mode , & select the settings your program is known to work with .
After all this if you still can't run the program , try using " virtualbox " or " vmware virtual machine " & install a copy of windows xp as a virtual machine .
Apr 16, 2011 | Broderbund PrintMaster Gold 16 for PC
Need video driver dell optiplex 170l for windows 7
Drivers can be found at this link:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid=&SystemID=PLX_PNT_P4_CEL_170L
However, you might want to consider the instructions below, as many people have had the same issue you're having with getting those drivers to work with Windows 7:
You may need to install the drivers in compatibility mode for Windows XP
To run the driver installation program in compatibility mode
Configure the driver installation program to run in Microsoft Windows XP Service Pack 2 compatibility mode. To do this, follow these steps:
1. Locate the executable file for the driver installation program.
2. Right-click the file, and then click Properties.
3. In the PackageName Properties dialog box, click the Compatibility tab.
4. Click to select the Run this program in compatibility mode for check box, click Windows XP (Service Pack 2) in the Run this program in compatibility mode for list, and then click OK.
5. Double-click the executable file to start the installation program.
Mar 05, 2011 | Dell OptiPlex 170L PC Desktop
We had an error from our Createa Card Gold 3 program. It is a "run time error & abnormal program termination". FMnot32.x was the file that cannot be accessed. The program was for Window 95/98 and we...
Probably need to reinstall the program...go to the installation file, RIGHT CLICK, and click TROUBLESHOOT COMPATIBILITY ...then you can have the option to run it in a mode for Windows 98/2000 if it has problems installing in Windows 7. If it installs in Windows 7, then there's no need for this.
Aug 02, 2017 | Broderbund American Greetings Creatacard...
Not able to see the images properly on my computer screen. Everything else is working fine. but when there is any image on the web page, then I can not see that image. Can see only colors. but can not...
Well I'm assuming this is a Dell,since this is in the Dell section. First,try viewing a pic off your hard drive. If you can see that fine,then go on to the next step,if not then the video card or onboard video has a problem. Could be as simple as re-installing the driver for the device. If the pic displayed fine, then I'll assume you're using Internet Explorer 7 or newer. I'd go to www.microsoft.com & download the latest version of Internet Explorer (8 is newest but 7 is fine for older pc's). You can also try a free browser like Google's Chrome or Firefox & see if that makes a difference. Also, do yourself a favor & download Advanced System Care Free version from www.download.com . Run the windows maintenence portion & then the system diagnostics, leaving all options stock. It's a one click ,let it run program, nothing to adjust. Finally,under utilities in the same program, install the defrag program, run the internet optimizer,the disk clean up. You can actually run this program before anything else,that's if you can see the writing on the webpage to do so. that program alone fixes 80% of what I run into daily in my business. This problem appears to be software related, so the above reccomendations should help. This applies to all versions of windows.
May 14, 2010 | Computers & Internet
Future CE-250 software compatible with Windows 7?
I just bought a new Futura CE250 & had the same problem.
I fixed my "can not run an x86 build of this utility on x64 platform" by visiting the futura support website & downloading a service update. I have a computer with Windows 7 installed.
The website is www.futura-support.com
When you are there, click on the link on the left for "Service Updates."
The actual link to where I downloaded my udate is: http://www.futura-support.com/downloads/ce150.html
Happy Embroidering!!!
Jan 19, 2010 | Singer CE-200 Quantum Futura Computerized...
Software incompatible window 7
Step by step instructions for Windows 7 32-bit follow:
Insert the Panasonic CDROM.
Don't use autorun - Cancel autorun popup.
Right click on CDROM drive in "My Computer" and select 'Open'.
Right click on Setup application & choose 'Troubleshoot Compatibility'.
Select 'Troubleshoot program'.
Select "The program worked in earlier versions of Windows but won't install or run now' & click
the "Next" button.
Select 'Windows Vista (Service Pack 2)' & click the "Next" button.
Click on "Start the program..." button.
Proceed with program installation.
When installation finished cancel out of the 'Program Compatibility' window.
If you have Windows 7 64-bit the instructions are:
Insert the program CDROM.
the "Next" button.
Installation will start.
VideoCam Suite will probably be flashing on the taskbar so select it.
The window will show: 'This application does not support this 64-bit operating system. Are you
sure you want to install?'
!!! Click the "Yes" button !!!
Dec 28, 2009 | Panasonic SDR-H80 Hard Drive Camcorder
Funny ust scandle
The Virus Must Of Dammaged Your Registry Or Windows Explorer,
call microsoft they will fix it by connecting to your computer and helping you out or they will tell you to do a simple system recovery witch directions can be found at
XP:
http://www.microsoft.com/windowsxp/using/helpandsupport/getstarted/ballew_03may19.mspx
Vista:
http://www.howtogeek.com/howto/windows-vista/using-windows-vista-system-restore/
By The Way I recomend to restore to the day before this happend.
Hope The Really Helped,
--Todaysgeek
Aug 27, 2009 | Microsoft Windows XP Professional With...
Is there microsoft "Return of the arcade
Try installing and playing that using 95/98 Compatibility mode.
To install a program using Windows XP's Compatibility Mode, hold
down SHIFT as you insert the game CD, use My Computer to browse
to the setup program, and then skip down to step 1 in the list below:
To run an installed program using Windows XP's Compatibility Mode,
first right click the program and "Send To..." / Desktop (create shortcut).
1.. Right click on the shortcut to the program.
2.. Click on Properties.
3.. Click on the Compatibility tab.
4.. Click on Run this program in compatibility mode and select one of these:
a.. Windows 95
b.. Windows 98
c.. Windows NT 4
d.. Windows 2000
5.. Under Display settings, check mark the mode that you think that is best:
a.. Run in 256 colors.
b.. Run in 640 X 480 screen resolution.
c.. Disable visual themes.
Click on Apply.Click on Ok.Double click on the program.
Of course, let's not forget to check for any patches or updates for that game.
A good place to find them is: www.avault.com/pcrl/patches_list.asp?letter=a
If you'd like to learn more information about compatibility mode, you can click the
link in the Compatibility tab that reads "Learn more about program compatibility",
or watch this Application Compatibility Power Point Presentation:
http://support.microsoft.com/servi [...] 112202.ppt
Jul 16, 2009 | Microsoft Return of Arcade for Windows
Eidos Interactive Revenant for Windows Logo
886 people viewed this question
Top Eidos Interactive Video Game Consoles & Games Experts
Michael Vincent Cruz
James Wishart
Are you an Eidos Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
