Question about Sta Rite STA-RITE IMPELLER 2HP FULLRATE & 2-1/2HP UPRATE, C105-238PEB
Have a GL sunlighter with 2 hp sta rite 220 vtl 2 speed motor, when in periodic filtering mode about every 4th or 5th cycle the motor fails to start and just humms until overheat trips, if I hit high mode while the motor is humming the motor starts up and runs properly, If I leave the filtering set at constant filter the motor runs ok. Do you think this is a capacitor or a bad armatur problem ? thanks for reply
  • Sta Rite Master
  • 1,358 Answers
Well have the capacitors checked and the start switch checked. search your area for pool pump motor repair with free tasting
Posted on May 30, 2013
3 Suggested Answers
tweedleedee0
  • 15 Answers
SOURCE: I have a sta rite pool filtere and it is running
Pump motors used in most pool aplications can not be reversed. Changing the wires on the capacitor or reversing the line connections will not change the motor rotation. A failed capacitor can, from time to time, let a motor start "backwards" but it will not happen often if even at all. You might need to take the motor to a local electric2_bing.gif motor repair shop for an inspection.
Posted on Jun 27, 2010
  • 366 Answers
SOURCE: pump was running until turn
either debris in pump causing impeller to hang, or you need a start capacitor.
Posted on Aug 14, 2011
What is a Sta-Rite Max-E-Pro Pool Pump impeller
take off silver band clamp that will separate the motor from the wet end remove the plastic piece on the side with the motor impeller is inside check to see if glogged use a stiff piece of wire to clean out
Aug 08, 2014 | Sta Rite Max - E - Pro 1 1/2 Hp Dual Speed
Sta rite pump
no bearings available need new motor
May 01, 2013 | Hayward 1 Hp 2 Speed Super Pump Inground...
3 hp hot tub motor Sta-Rite tub has two speed low for filtering and high for jets low starts and then stops high speed works fine
make sure you make a wiring diagram or just unplug the plug from the mother board and search your area for your local pool pump repair guy with free testing. these are a high $$$ motor and not a good one to practice on, save it for a pro ! it might just be a dirty switch or need to be reset I don't charge any thing for that, and while your there ask him how to take better care of your $$$ pump ?
jay the pool pump repair guy longwood Florida
Sep 05, 2012 | Sta Rite Sta - Rite 1hp Dura - Glas...
Looking for manual on Sta Rite Sand filter Model HRP830
Here is a copy of the users manual for Sta Rite BRPB30 pool filters.
http://www.pool-filters.com/pdf/Sta-Rite-HRPB-Filter-Manual.pdf
Apr 16, 2011 | Sta Rite Sta - Rite 31" Sand Filter & 1.5...
I turn my pump on, it starts pumping then about 10-15 sec it shuts off. Doesn't seem as loud or pulling pressure either.
Check the label and then the wiring on the motor to see if you are wired 120 or 240 first. If you are supposed to get 240 and are getting 120, the motor will run @ 1/2 speed for a little while and then shut off. If this continues, your motor will short out. If your motor is getting 240 volts while running, you have a bad motor.
Oct 09, 2010 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
May 31, 2010 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
We have a Sta-rite mode P2RA50-120L, when trying to empty the pool of excess water the pump runs for appox. 30sec and then cuts out...the pool was very over full we bailed some ot the water out but it is...
If all you are doing is running your filter system to waste or backwash the fact that the pool is over full has nothing to do with it. It should run fine in either case. Your motor is likely starting to fail and as it overheats, shuts off. You may want to consider taking it to a local electric motor shop for repair or replace the motor. That motor is somewhere around $150 from most places. We sell it as well. If you would like a quote, please contact www.arrowmotor.net
Jun 18, 2009 | Sta Rite Sta - Rite 2hp Max - E Pro...
Sta Rite STA-RITE IMPELLER 2HP FULLRATE & 2-1/2HP UPRATE, C105-238PEB Logo
81 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Jim Goldsmith
Jim Goldsmith
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
