Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
It turn off itself.
I changed the two STK392-010 ICs. The TV started working very well, but now it has developed another problem: it turns off itself. Whenever that happens, I have to unplug it from power and replug it again before the TV canm be turned on. Sometimes I have to wait for even 30 minutes or more before it accepts power. What is the problem? is it still related to the convergence? But it had been doing fine for the whole day since changing those ICs.
  • 2 more comments
  • Mzee Mzima Jun 29, 2007
    After replacing the ICs, the convergence was very good. It worked very well for the whole day and even for half of the nmext day before the problem started. Currently it does not start at all. I have unpulgged it for about one hour now and it is still not truning ON.
    I will check the high voltage connectors.
    Is it possible that the Hi Voltage transformder is dead?
  • Mzee Mzima Jun 30, 2007
    Chacked all connections, they are OK. I have noted that the it does not respond to the manual push button although it seems to respond to the remote controller keys.
  • Mzee Mzima Jul 06, 2007
    Leslake,
    I used silicone thermal material. I am not sure whether I cleaned it to avoid contacting the IC terminals but I guess this material does not conduct electricity.
    Scholar:
  • 150 Answers
How does the Blue look, alot of Samsung CRT Projos have bad/ leaky blue crts and it may have leaked and caused a short, check for fluid on circuit boards below, and beware! This "coolant" can possibly be a fire hazard.
Posted on Jul 04, 2007
  • les lake Jul 04, 2007
    Also did you put some heatsink dope on the backs of the IC's before reinstalling them and also clean up the old dope? If you didnt you could have shorted the new IC's and need new ones.
    New Friend:
  • 129 Answers
After you replace the ic's how was the convergence? bad or ,almost good if . you had it to do a deep alignmet may you still have problems in the same circuit area.
Posted on Jun 29, 2007
  • Luis Amado Jun 29, 2007
    Be sure that all the Hi voltage connectors are all the way in. could'be arching
Panasonic pt56wxf95a turns itself off
Did you replace the bulb? clean dust out of fans?
Apr 17, 2010 | Panasonic PT-56WXF95 56" Rear Projection...
Shuts off then flashes power light
I think this is a power problem, check the power supply for bulging or leaking electrolytic capacitors or other damaged components.
Jul 20, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Samsung HC-P4752W Does Not Turn ON
The proble you have is an intermittant power supply or sweep power supply. Unless you can find a bad connection on the power and deflection board, this could be a very difficult problem to find. I have ran across this problem a couple of times, and after spending countless hours troubleshooting, I replaced the main board and all the problems were taken care of. The board part number is at samsungparts.com and I found the board for you. it is located here: http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP94%2D01266A&search%5Fmodel=HCP4752W Good Luck
Jul 04, 2007 | Samsung HC-P4752W 47" Rear Projection...
How do I repair a convergence problem? when I turn it on, the convergence is out of wack, so I adjust the multipoint on both the red and blue, and save. I turn the unit off, and when I turn it back on, the...
You need to adjust Green first, then Red, then Blue. Upon completion you need to save your changes so when you power down and back up the changes will still be there.
Good luck
Jan 04, 2010 | Philips Magnavox 51MP392H Rear Projection...
Tv turned itself off. turn power back on, picture
Your TV is experiencing a convergence issue as indicated by the 3 blinks. The only way to fix this is replacing the convergence ICs. It is not a hard task to replace these ICs. You just need to know how to solder and work on printed circuit boards.
The convergence ICs are mounted on a large heat sink and are marked with codes starting with the letters STK and there are two of them. You need to replace both.
Look for the heat sink with two ICs mounted on it and check the markings.
Once found, cut the IC legs with a small side cutter and unscrew it from the heat sink. Remove the legs left soldered on the board.
Take note of the IC markings for ordering the right part and how it was installed. Don't forget to buy along with the IC a thermal compound.
Check the pico fuses on the same board. Most likely you will find a blown one. These fuses look very much like a resistor, not like the usual transparent fuse, and usually yellow.
Once you have the replacement ICs, put it on the board in the same way as it was installed before. Make sure the screw holes are aligned before soldering the legs into the board.
Put a reasonable amount of thermal grease/compound between the ICs and the heat sink and fix them with the screws.
Double check the board for any splash of solders that might cause a short circuit and damage the board.
Dec 07, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Tp55f80 tv. to much red on screen
You have a convergence failure. It may be possible to simply re-solder the pin connections under the convergence output ICs as they have a tendency to develop cold solder joints which cause intermittent mis-convergence. If the solder connections are good, then replacment of the ICs will be necessary. Expect to pay $350-450 to have a toshiba servicer fix this.
michtech
Feb 17, 2009 | Toshiba TP55F80/81 55" Rear Projection...
Panasonic pt-47wx42f
Yes you can get replacement IC STK392-110 convergence ICs at the following link and they provide free instalation instructions with pictures. The Ics are located on the board on the left side attached to a large heatsink. You will need to replace both ICs heres the link.
http://servicemanuals.vstore.ca/
May 19, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Looks like watching 3D movie(colors) and rounded
This is a convergence problem and is either bad connections on the convergence ICs or defective ICs. If you feel that you can solder, you should be able to repair this yourself. First try resoldering the pins on the convergence ICs. If that fails, replace the ICs. These ICs are large black ICs attached to a heatsink and should be marked STKxxx.
Keep us posted.
Dan
May 13, 2008 | Toshiba 57HDX82 57" Rear Projection HDTV
Projection Tv Problem
The problem you are seeing is a convergence problem. This is a common problem and is fixed either by resoldering bad connections on the convergence ICs or replacing the ICs. These are large black ICs attached to a heatsink and are marked STKxxx. Try resoldering the pins on these ICs first.
Dan
Mar 17, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
51 people viewed this question
Jerry Greenberg
Jerry Greenberg
