Question about Gear Head WC330I Webcam
CAN'T DOWNLOAD MY CD TO MY NEW COMPUTER WITH WINDOWS 8
I KEEP RUNNING THE DISK AN A ERROR MESSAGE COMES UP
  • Gear Head Master
  • 10,322 Answers
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Posted on Feb 02, 2013
Ntlrd missing xp tablet on my hp tc1000 with no cd rom
Causes
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
  10. Failing to enable USB keyboard support in the BIOS.
Solutions
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette or CD is in the computer, unless you are attempting to boot from a diskette.
Note: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any card reader or flash reader make sure that no memory stick is inside the computer. Additionally disconnect all USB drives, cameras, ipods, iphones, etc. from the computer.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt.
If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive.
Verify that your computer hard disk drive is properly setup in the CMOS setup. Improper settings can cause this error.
Corrupt NTLDR or NTDETECT.COM file
Windows 2000 users
Windows XP users
Sep 24, 2011 | Computers & Internet
After clicking user name on Windows XP welcome screen error message appears: C:\Windows\System32\command.com parameter is incorrect. Clicking OK does not close the error message. Desktop does not appear,...
Try starting up in safe mode keep tapping f8 untill the advanced start menu comes up
login as administrator
press start -> run -> type in the run menu: msconfig and press enter
in msconfig open the startup tab and click disable all, apply and ok, restart normal mode. should work fine.
Aug 11, 2008 | Computers & Internet
Hi. Every time I turn my Toshiba Satellite Laptop on (A305-S6905) it turns on normal then it goes to this black screen and says "A disk read error occurred press ctrl+alt+del to restart." I...
The disk read error message appears when the motherboard can't read what is in the hard disk and use it to launch the Windows boot process.
It means that the hard disk is dead and everything on it is lost, including the recovery partition that new laptops use instead of the recovery disks. You will have to replace the hard disk (a quite complicated job that only an experienced person should do) then order a recovery disk from here
https://www.csd.toshiba.com/cgi-bin/tais/support/jsp/serviceUnitVerification.jsp
and use it to reinstall Windows.
Jul 15, 2011 | Toshiba Satellite A135-S2386 Notebook
How to fix and repair a not valid win32 application?
Often this error message will be similar to the below error message.
C:\Program Files\myprogram\program.exe is not a valid Win32 application.
Cause
This issue can be caused by any of the below possibilities.
File is corrupt, bad, or missing.
File is not designed for your version of Windows.
File is a virus, worm, or other malware file.
Hardware incompatibility.
Answer
If the file or program you're attempting to run is corrupt or missing, Windows will be unable to execute the file properly and sometimes generate this error message.
Download files
If you downloaded this file and verified it is complete and compatible with your version of Windows, delete the file and try downloading and running it again. It's possible during the download that the file became corrupted.
Finally, if the second download does not work, try downloading the file from a different webpage. It is possible that the person or company maintaining the website mistakenly uploaded a corrupt version of the file you're attempting download.
Installing a program from a CD or other disk
If you're attempting to install a program and are getting this error, verify that the CD is clean. If the CD is dirty or bad, you could get this error during the install or after the program has been installed because it was not copied properly onto the computer.
Running a program from the computer
If you're running the program from a shortcut on the computer, verify that the program is still on the computer. In some cases if the program is no longer installed on the computer you may get this error.
If the hard disk drive is corrupted or bad it can also cause working programs to fail either because not all the data can be read from the hard disk drive or because the program has become corrupted while on the drive. Run scandisk and defrag on the hard disk drive to check for any potential errors.
Long file name issue
Make sure the program or file you're attempting to run does not contain the same name as the long file name directory it is contained in. For example, executing a file named "program" in the "program files" directory can cause errors in some versions of Windows.
Additionally, if you're attempting to install a program and after the install the program does not work, you may also want to try installing the program in a different directory.
Bad file
Any file can be changed or renamed to be a .exe file. If you're downloading the file, make sure the file is supposed to be a .exe file and that it's not being changed. If you're attempting to create a .exe, file make sure you're compiling the file for Windows and never just rename a file to a .exe file. For example, renaming a .bat file to a .exe file will not make the file an executable file. For a file to become an executable file it needs to either be compiled or converted through a software program designed to convert the file.
If you're trying to run a program that is not designed for your version of Windows you may get this error. Although many older programs designed to work in older versions of Windows will work with new versions of Windows, unfortunately, not all programs will work.
If the program is an older MS-DOS program or early Windows program you may get this error.
If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
Getting old MS-DOS games to run in Windows.
This error can be generated by a file that is a virus, worm, Trojan, or other malware file. Often, this will be caused because the virus scanner installed in the computer will not allow the file to be installed or run. Try scanning the file to verify it is not a virus or infected.
If the file has been checked and is clean, it is still possible that the virus protection program or another program installed on the computer is causing issues during the install or execution of the program. Boot the computer into Safe Mode and try running the program; booting the computer into Safe Mode will make sure nothing is running in the background that could be causing this issue.
If you're getting this error during the installation of a program it's also possible that the CD-ROM drive or the drive you're installing the program from is not compatible with Windows or has drivers that are not compatible with Windows.
Download the latest drivers for your CD drive or other drive through our drivers page.
Source : ( http://www.computerhope.com/issues/ch000726.htm)
May 30, 2011 | Microsoft Computers & Internet
I cannot start my e-Machines 350-21G16i netbook. I`m being told that the following file is either missing or corrupt: "<Windows root >\system32\hal.dll" "Please re-install...
HAL.dll is a critical file of Windows - it's the only file that connects Windows with the hardware. This message appears when this file is either missing or not where it's supposed to be. Just 2 things can cause that: a failure of the hard disk or a severe Windows corruption. This in turn can be caused by 2 things : a serious virus infection(usually) or a really bad program that was running just before this message appeared.
The best way to fix this is to perform a full reinstall and then add only the absolute necessary programs. If the problem returns quickly then the hard disk is dying and you will have to replace it.
Apr 09, 2011 | Computers & Internet
I have a compaq laptop about 8 months when i turn it on it has a black screen says soft hard disk error 1 (301) what does that mean? how do i fix it?
a softdisk error 301 means the hard drive is failing it is common on hp and compaq laptops ( hp owns compaq) unfortunately you are screwed to say the leas the hard drive is failingt. BUT you can save your data by hooking up an external hd and running ubuntu live cd to boot and copy any files you need from your hard drive over. you can download ubuntu from ubuntu.com and download and burn the live cd then you will need to set via ur bios when you boot i think its f2 or del key to get into the bios then go to boot order and select cd dvd drive to boot b4 cd then boot into the ubuntu disk and copy your files.
Mar 14, 2011 | Computers & Internet
My computer lost ( ntlpd is missing) plus said press ctrl alt del it's not coming up.
Sounds like you've got some corrupted files. If you have your Windows disc, try a reinstall/repair or try to drop back to a previous restore point.
If those don't work, you might try to reformat/re-install your software. (backup your data if you can beforehand as reformatting will wipe all data from the drive).
This can even be a hardware problem, like the HD controller bad, which caused the file problem in the first place. Or a virus can cause such issues, which would make reformatting/reinstalling a good idea as well.
Make sure you have a defragment task running every month, if not every week. You can schedule to run at night or during the day, whenever you're not at the computer. If you turn it off when you're not using it, just leave it on that one day (or night) that the defragment needs to run... or start it manually before you go to sleep and unless it's a large drive, it should be done when you get up.
Good Luck!
8^)
Jan 02, 2011 | E-Machines eMachines Desktop PC
I have a compaq evo n600c laptop which just crashed running windows 98se and now i get error message 1782 disk controller failure followed by non system disk error.I do not have the op disk so i tried to...
Sure, no problem, http://download.cnet.com/Microsoft-Windows-98-SE/3000-18513_4-12296.html - 64k try this site and other related in order to create a system disk and reboot your system. Good Luck
Fehdi
Apr 12, 2009 | Computers & Internet
I forgot my Password to the Login of my Laptop
Have your HP laptop login password forgotten? Do you have another administrator? Have you created Windows password reset disk on your HP computer when it is available? Or whether you have installation CD?
If you have administrator, just change HP login account to this administrator and access HP computer with it. At this time, no matter which account, you can easily change or remove its password on Control Panel.
If you have password reset disk, on Windows login screen after you type incorrect password, there will be a message "Reset Password" prompting you to reset forgotten Windows password with reset disk. Just follow password reset wizard to do.
If you have installation CD, it will help you to restore HP computer or repair computer. But it is still dangerous for us to use it because it will delete some important data on your computer.
In consideration of data safe on computer, Windows Password Genius provides a safe Windows password reset environment WinPE. With it and in such password recovery environment, you will don't need to worry about data lost or damaged.
This is a video showing how to use it.
http://www.youtube.com/watch?v=quxuEqpG6f4&feature=youtu.be
Jul 11, 2008 | Computers & Internet
Problem with a disk read error
There are a couple of possibilities.
1. The hard drive is defective.
2. The operating system is corrupt.
The easiest way to test this is to run the restore cd that came with the computer to reload Windows.
If you get this error while running the restore cd then you will need to get a new hard drive.
Jan 03, 2008 | Computers & Internet
Gear Head WC330I Webcam Logo
47 people viewed this question
Top Gear Head Computers & Internet Experts
micky dee
Are you a Gear Head Computer and Internet Expert? Answer questions, earn points and help others
