Question about Samsung Microwave Ovens
Replacing keypad smh9187st - Samsung Microwave Ovens
    New Friend:
    Problem Solver:
  • 5 Answers
You can do this without removing unit from wall. First unplug unit. Next remove the two screws on the top of the unit closest to the front. These screws simply keep the up facing vent in place. Next slide the vent to the left (plastic latches on bottom hold in place) to allow vent to be removed. You should now see a single screw above the control panel. Remove it then open the microwave door. Gently slide the control panel up which will disengage the plastic latches on the panel sides. Suggest if you are going to remove the controller and replace take a picture before removing it so you know exactly how to reconnect all the wires.
Posted on Feb 03, 2013
SAMSUNG MICROWAVE SHOWS SE AND WILL NOT WORK.WHY?
SE is an error code for a shorted keypad, although the keypad might not really be shorted.
Unplug the oven for a few minutes to see if it clears the error code. If not, then leave it unplugged over night. If the problem persists, then you probably do have a shorted membrane switch on the keypad.
Aug 29, 2014 | Samsung SMH9187ST Microwave Oven
My samsung oven is showing se error cpde. How do i fix it?
Unplug it for a few minutes to see if that clears the code, if not, unplug it overnight. If the problem persists, then you might have a shorted membrane switch on the keypad.
Jul 06, 2014 | Samsung SMH9187ST Microwave Oven
Why does my Samsung microwave smh8165ste have error code --SE--?
SE indicates a shorted membrane switch on the keypad. Unplug the oven for a few minutes to see if it clears. If not, leave it unplugged overnight. If the problem persists, then you probably do have a switch that's bad.
Jun 27, 2014 | Samsung SMH9187ST Microwave Oven
Samsung Microwave Mod # SMH9187ST. Starts on its own, "bake potato" on display screen. After shutting down, code SE appears on screen. No response from keypad until unplugged. Reset and problem ret
Contact Samsung, I was having a similar problem with the SE error appearing on my microwave. Apparently its a problem with the control panel and they are going to replace it free of charge under there epidemic warranty
Mar 18, 2013 | Samsung SMH8165W Microwave Oven
Se code
Contact Samsung for the SE error message. They are fixing my microwave for free today even though it is 4 years old. Model #SMH9187ST.
Feb 22, 2013 | Samsung SMH7178STD Microwave Oven
How fix se error
"SE" error means you have a shorted membrane keypad.
On some models, you can peel off and replace the old keypad.
On others, it's best to replace the control panel frame, which contains a new keypad already.
You didn't mention your full model, but if it;s the same as the category in which you posted (SMH9187ST) here is a specific solution:
The simplest way to fix this is a simple DIY solution, to replace the control panel frame assembly, which comes with a new keypad already attached.
It is part number DE94-02001C "assy control panel" and you can order it from the Pros here for about $30 plus shipping.
They may not have it in stock, but if you order it, they can have it in a few days.
You can download the service manual from our site here.
At our Web site , we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some connectors have a lock:
Then move your board to the new panel assembly, but be careful since the display is made of glass.
Oct 25, 2012 | Samsung SMH9187ST Microwave Oven
Samsung microwave se error
Oct 24, 2012 | Samsung SMH9187ST Microwave Oven
How do you remove the door panels on a samsung SMH9187ST? I am replacing / repairing the door latch.
Hi Jerry, it sounds like I have the same problem as you. Have you been able to fix yours?
Sep 08, 2012 | Samsung SMH9187ST Microwave Oven
My Samsung SMH8165ST Stainless Steel 1600 Watts Microwave Oven Problems
This indicates a system error, the keypad has a short in the membrane, the keypad control board will need to be replaced.
May 02, 2012 | Samsung SMH9187ST Microwave Oven
Samsung microwave se message
That indicates that the keypad membrane is shorted.
Apr 24, 2012 | Samsung SMH9187ST Microwave Oven
Microwave Ovens Logo
75 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
