Question about Simmons Mattress Geneva - Snow White Crib
Foot rail release
Replacement parts
2 Suggested Answers
  • 5 Answers
SOURCE: simmons baby crib
Have you tried the website: http://www.simmonskids.com/consumer_service.cfm
Posted on Jul 30, 2008
Hi, My Quantum 9960, needs the bobbin refilled, but the machine shows me an icon of the foot paddle, then an icon of machine and conect? cord. The cord is connected, I've tried it 3x. Don't know what to...
Is there an up arrow in the icon you see? What you describe could be the Release foot controller pedal icon. Take your foot off the foot pedal. See the trouble-shooting page on page 102 of the manual. The manual is available from Singer here: http://www.singerco.com/uploads/download/5b9200a32cfd31ffc30b8d29fd195a57dff4a9e3.pdf .
You are supposed to take your foot off the controller (or press Stop) after winding a few turns of thread on the bobbin. Trim the excess thread above the bobbin. Then step on the foot controller or press Start. Release the foot pedal again when the machine stops winding the bobbin. See page 28 of the manual for the procedure.
I hope this helps. If you do not have the Release foot controller icon displayed, please add a longer description of the icon or indicate which icon from the trouble-shooting section of the manual that is closer to the one you see. If you have released the foot controller and the icon persists, then something may be wrong with the control pedal. A replacement control pedal is ~$35; see http://www.sewingpartsonline.com/singer-9960-quantum-stylist-parts.aspx .
Jul 21, 2017 | Sewing Machines
How do I fix the foot pedal assembly for the handle release on shark vacuums?
You should call cust service. Call may still replace it.
Aug 04, 2014 | Shark Vacuums
My 2000 Land Rover Discovery II doesn't start unless I manually give it gas from the foot pedal. It seems that once the truck runs, it doesn't idle and stalls when I release the foot pedal. There are 2...
The second cable should be for cruise control. Your problem sounds like either a vacuum leak (air entering the engine unmeasured by the air sensor), or fuel vapor in the fuel rail. A vacuum leak can be determined by spraying starting fluid at the air intake hoses, plenum,and connections while the engine is idyling and noting where the engine accelerates to determine where the vacuum is leaking (unmetered air is entering) from. Tighten or replace gasket,hose,seals etc. Bleed the air on the fuel rail if needed with care.
Aug 11, 2010 | 2000 Land Rover Discovery
I need a replacement pressure foot release lever for a Simplicity BH600 blind hemmer.
Supposedly, Simplicity is made for Tacony. I would start there to ask about parts.
Is this a presser foot lifter?
I do not recall ever seeing a pressure foot lifter.
Mar 04, 2010 | Simplicity Sewing Machines
Foot controlled handle release lever is broken. Where to get parts?
I had same problem - the foot release pedal would not spring into place when unit was upright (but would work if you nudged in place with your foot). I installed a replacement part, and it didn't fix the problem. I cut out a small sqare of sponge and jammed it behind the flat end of the bent plastic spring on the release pedal, and it now springs back as it shoud. Hope this helps.
Jan 11, 2010 | Hoover U6630-900 WindTunnel Bagless...
Foot latch is broken. need to replace with new one. how does one access to remove the foot pedal latch. By foot latch, I mean the foot lever that releases the upright to lower the handle and begin...
it is accessed from the bottom underneath by the rear wheel. However, If there are and cracks on the pedal release socket area then the base will need replacement. parts are little cost but the unit needs to be completely disassembled.
Oct 17, 2009 | Hoover U6446-900 WindTunnel Bagged Upright...
Replacement parts for a crib
Try www.productsamerica.com they sell replacement parts and also conversion parts for older cribs. They are a little on the expensive side, but they are on the only place on the net that I could find for this.
Their number is 800-772-1041. You can call them and give them you make and model that they can match up what they have with what you need.
Hope this helps! Deanna
Jul 31, 2008 | Baby Gear
Simmons Mattress Geneva - Snow White Crib Logo
20 people viewed this question
Top Simmons Mattress Baby Gear Experts
Stan Skaggs
Stan Skaggs
Glen Weitzdoerfer
Tom Chichester
Are you a Simmons Mattress Baby Gear Expert? Answer questions, earn points and help others
