Question about Jandy Digital PoolSpa Control w Actuators for AquaTherm Heat Pumps
Aquatherm pool heater
Pool spa Heat pump
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
Make sure it is connected to the solar to get it to work
Posted on Oct 09, 2014
  • 61 Answers
SOURCE: Pool pump will not fill back up
It sounds like you are sucking air into the pump. Make sure strainer baskets and pump baskets are clear, and the valves are in the right position. Also check the water level in the pool, and make sure that the pump is not sucking the skimmer dry. Next try lubricating the gasket on the pump lid, or if it is in bad shape (flattened/cracking) replace it. If this does not solve the problem put silicone around the inlet to the pump (silicone is a temporary fix that could last days or months--for best results replumb with teflon tape and sealant). If all that fails you could have debris stuck in the impeller.
Posted on Apr 05, 2009
  • 163 Answers
SOURCE: Jandy Lite2 Pool heater will not stay lit after firing.
Look at the sensor that tells unit that everything is lit. There should be some sort of sensor that tells the ECU that the ingnition area is a burn temp. It sounds like the unit can't tell that flame is lit. Hope this helps.
Posted on May 17, 2009
  • 16 Answers
SOURCE: Jandy pool pump will not prime it is a Jandy plus HP model PHPM 2.0
make sure pool is full of water
check skimmer weir doors and make sure not stuck in up position
fill pump basket with water and try to prime
if that doesn't work
replace diffuser oring
http://www.jandy-downloads.com/pdfs/PHP_Manual.pdf
Posted on Jan 16, 2010
thepool
  • 78 Answers
SOURCE: digital read out....fault high ref pressure.
Verify circulating pump is on and that there are no water flow restrictions to the heat pump. Make sure all necessary valves are open or in the proper positions to allow proper water flow to the heat pump. Verify filter and skimmers are clean. Check for water level in the pool. This condition may also appear if the heat pump has not been operated for an extended period. To clear the condition, cycle the heat pump, on and off, up to 3 times. If this does not correct the problem, call for service.
Posted on Apr 22, 2010
adamh294
  • 310 Answers
SOURCE: dont know how to start
If you let me know what heater it is I can help. Not enough info here.
adamh@newconceptchem.com
Posted on Oct 27, 2010
Value position to heat pool
turn the valves so ALL the water goes through the heater and back to the pool
Apr 17, 2014 | Hayward Pool Products Pool & Spa
Jet pump and spa heat enable on their own
Check your time settings. It sounds like the Spa Mode has been set to run at given times and with heat enabled the heater will automatically turn on when the the spa is activate.
Jan 09, 2013 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
Raypak pool heater is making a knocking noise
low water flow check manual bypass in heat exchange if spring broke letting too much water bypass and overheating water in unit also see if pump ok and filters
Jun 11, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
How do I turn on the heat and the spa in the pool?
You must first make sure the filter pump is on and running (primed). If you have a pool spa combo, you will need to turn on the heater by making the desired temperature higher than the current temperature. This is a call for heat. You must then move the suction and return valves to **** and return to the spa. This is accomplished either by moving the valves manually or by putting it into spa mode if you have a control system. You didn't say whether or not you have a manual or automatic system.
May 18, 2010 | Hayward H Series Pool & Spa Heater...
I want to heat the pool from the spa. I have the spa and spa heat on but the spillover wont come on when I have the spa on. When I turn the spa off the heat goes off. What do I do
When your system is put into Spa mode the system draws water from the spa only to the heater to keep the spa at temp, this is why the overflow doesn't work and why you can not heat the pool in spa mode. If you could heat the pool this way it would take a very long time, since the spa is smaller then the pool. You can heat the pool and spa at the same time in pool mode. Water is pulled from the pool, heated and goes back into the pool and spa.
Mar 27, 2010 | Jandy AQUALINK RS TELELINK KIT
Gas heater and heat pump chiller control problem
NO. BUT YOU CAN CONTROL WHAT EQUIPMENT TO COME ON BY INSTALLING A RELAY FOR EACH ONE THEN ASSIGN A AXUILIAR BOTTOM IF ANY LEFT
Nov 18, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Aquatherm pool heater runs but not heat up
Did you replace the dryer on the unit?
Oct 27, 2009 | Heating & Cooling
Same Issue
the pump stop so will not drain spa dip # 4 may turn off for the delay but not sure if the pump will still turn off since this is new tech. good luck
Jul 05, 2009 | Jandy Aqualink Rs4 One Touch Control...
Raypak pool heater piliot light on heat will not turn on
Make sure that gas control knob is set to ON (counterclockwise). Make sure that ON/OFF switch is ON. Check that temperature setting is high enough to call for heat. Make sure pool pump is running and water is flowing to unit.
If not above there is a diagnostic procedure on page 33 of manual at:
http://www.raypak.com/uploads/6000.52AG.pdf
May 24, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Jandy Digital PoolSpa Control w  Actuators for AquaTherm Heat Pumps Logo
61 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
