Question about Toshiba Satellite A305-S6837 (4400 mAh)
Toshiba Satellite A305-S6837 is in a "DO -LOOP" with the following:
"Windows Error Recovery Windows Failed to start. A recent hardware or software change might be the cause. If windows files have been damaged or configured incorrectly, Startup Repair can help diagnose and fix the problem. If power was interrupted during startup. choose Start windows Normally. " I have tried both choices several times. the Launch Startup repair ran for about 10-hours then re-started and came back to the same screen. The 'Start Windows Normally' choice also restarts and comes back to the same screen. I have also tried a warm shut down when at the choice screen and taken the battery out then replaced and reconnected to the power cord, with the same results. Any suggestions how I can get out of this LOOP and get this lap top to re-start normally again?
  • Toshiba Master
  • 2,878 Answers
Use the Windows Install disc and load on top of previous version. Do not do a clean install, this will delete all previous settings and data.
Posted on Jan 07, 2013
  • Bill Anderson Jan 08, 2013
    Thank you Jose that sounds like the thing to do, now I need to find my Windows install disc.
  • Jose Diaz
    Jose Diaz Jan 08, 2013
    Windows 7 image can found at My Digital Life dot com. You must own a MS Product Key and must be exact version
3 Suggested Answers
  • 2246 Answers
SOURCE: Windows could not start because
reinstall your system, your windows was corrupt
please rate my answer
Posted on Jan 18, 2011
Ezrahite
  • 2632 Answers
SOURCE: I have a Toshiba Satellite A305-S6829 running
Welcome to Fixya. First you need to decide what Operating System you want to install and second can you please try to install the Windows Vista using the DVD and on the setup screen if your hard disk is detected you can format or delete the partition to remove all the windows components. However you need to keep in mind that if you will delete the partitions all files will be deleted as well. If still have the message that no hard disk drive detected please go to Bios Screen and check if the hard disk is detected.
If the hard disk is detected:
just select the partition you want to install windows then wait until the setup finish the installation.
If the hard disk is not detected in Bios:
Try to reconnect the cable from your hard disk and check if the bios will detect it. If not then the hard drive is bad.
Thanks for using Fixya.
Posted on Feb 21, 2011
Windows fails to start
Is the hard disk, change the hard disk and/or the sata interface wire.
Mar 10, 2012 | Toshiba Computers & Internet
My lap top A305-S6853 don't start, it sends me direcly to the black screen that says Launch start up repair or start windows normally, but when i hit any of this options shows a message that says that...
Get the disk - Otherwise, no way that you can attempt the repair operation which by the way is not a guaranteed fix for your issue. Or bite the bullet and install a new OS with drivers.
Aug 12, 2017 | Toshiba Satellite A305-S6853 Notebook
Hi. Every time I turn my Toshiba Satellite Laptop on (A305-S6905) it turns on normal then it goes to this black screen and says "A disk read error occurred press ctrl+alt+del to restart." I...
The disk read error message appears when the motherboard can't read what is in the hard disk and use it to launch the Windows boot process.
It means that the hard disk is dead and everything on it is lost, including the recovery partition that new laptops use instead of the recovery disks. You will have to replace the hard disk (a quite complicated job that only an experienced person should do) then order a recovery disk from here
https://www.csd.toshiba.com/cgi-bin/tais/support/jsp/serviceUnitVerification.jsp
and use it to reinstall Windows.
Jul 15, 2011 | Toshiba Satellite A135-S2386 Notebook
Problems booting windows vista on toshiba satellite l300d. ''Windows failed to start. A recent hardware or software change may be the cause''. My Toshiba had viruses so i restored it with the hdd recovery...
You may need to re-install the operating system all over again as you had tried to restore your computer using Restore Disc but failed. In these cases, you will have to try to wipe all your data and install OS once again.
Mar 12, 2010 | Toshiba Satellite Pro L300D-EZ1002X...
A305-S6837
r u still needing help
Dec 17, 2008 | Toshiba Satellite Laptop
Toshiba satellite pro l40 boot up problem
If you run a repair with the recovery disc you won't lose any info. The only time you'll lose the info is if you run a complete reload. Run the system disc until it gets to the point of finding installed operating systems, at this point instead of deleting the partition, press R and it will reinstall the operating system files only leaving other installed files and programs intact. Keep in mind that many times when this happens, it's a hard drive failure. If it is a hard drive failure, then you will have to replace the hard drive and you will lose the info, sorry.
Jul 02, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A305-S6837 (4400 mAh) Logo
107 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
