Question about Refrigerators
Not cold enough to make ice or freeze meat - Refrigerators
    New Friend:
There is a switch plugged into the side of the compressor that we always called the "clixon" It is a switch that energizes the start windings in the compressor.
!, Unplug unit and pull away from wall in either order.
2. Find compressor, It may be hidden behind a panel.
It looks like a small gas cylinder.
3. Find where wires are plugged onto clixon on side of compressor. Remove wires from switch. Draw a picture if you can't remember for later.
4.Write down model and serial number and proceed to parts store. Some parts stores will test switch before selling one to you
.5. If this does not fix refer you probably have a gas leak or a locked compressor.Neither of which is usually worth paying to have repaired.
Post script. There should be a humming sound coming from compressor as it attempts to start with faulty clixon,
Posted on Jan 06, 2013
  • Refrigerators Master
  • 17,173 Answers
Sounds like the self defost is stuck on or the coils are frozen because the defroster did not come on. What is the model?
  • Reed Henderson Jan 06, 2013
    Sorry Brad. If it were a defrost issue the freezer would be cold and the refrigerator would be warm. The ice you spoke of would block the airflow to the refrigerator.
  • Brad Brown Jan 06, 2013
    Not if the defrost coil is stuck on or the timer is hung up
SOURCE: frigidaire PLHS267ZDB2--Not cold enough
Replaced the fan and the damn thing works like a charm....Thanks alot for all your suggestions.This is a cool site and you guys are doing a great great job! Keep up the good work!
Posted on Oct 22, 2007
dcp2
  • 63 Answers
SOURCE: freezer not cold enough to freeze items solid
Here are some things you can check yourself. Does it run all the time almost non-stop? if so check the vents under the front of the frig and make sure they are clean. Aslo check the condenser coil (either in back of the frig,or under the frig)Make sure that coil is clean. The condenser coil has to have contact with the outside air in order to release the heat it removed from inside the freezer.
Make sure you frig has plenty of ventilation ( wall too close on sides and back) Hope this helped. If not then you should have a pro look at it.
Posted on Jan 28, 2008
mikedurland
  • 481 Answers
SOURCE: bosch frost free fridge freezer not freezing ice cream/pops at all and meat not totally frozen
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Posted on Jun 28, 2008
SOURCE: refrigerator not that cold and freezer not freezing well
dirty coils underneath the fridge, or the fan in the bottom (to cool the compressor) is not working.
Posted on Aug 07, 2008
  • 531 Answers
SOURCE: Freezer too cold and fridge too warm
check fan cold control or damper control
Posted on Apr 07, 2009
Freezer not cold enough to freeze ice cream and bread.. I have setting at coldest. What else should I check?
First check the manufacturers website for troubleshooting. When refrigerator or freezer not cold enough, typically the problem is the freon is low or a more expensive repair is your compressor might be on it's way out! Sliding Pull Out Shelves Denver Colorado
Mar 09, 2017 | Refrigerators
Where do I put cold cuts and meats I don't want to freeze?
Best place for cold cut meats is the bottom drawer in the refrigerator. It's also good for cheeses. That drawer is the coolest but not freeze place. The upper two drawer are good for veggies and fruits. We put the lever controls in the middle selection for them.
Aug 02, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge not freezing meats
I was writing a big note here before then hit the wrong button, it was just a bunch of jargon anyway. Yes it is the condenser fan motor causing your problems. Doesn't cool the refrigerant properly than nothing works. I would change the fan before it causes any damage to the compressor.
Sep 04, 2012 | Whirlpool Refrigerators
Upright Freezer not cold enough
Honestly it sounds as if you have a sealed system issue, most likely low on freon.
Jun 13, 2012 | Freezers
My Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator bottom meat section and veggie drawer is freezing my meats and vegetables. Why?
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Dec 16, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Loading
You need to remember heat rises and cold air falls. The best way to load a freezer is to put meats on the bottom. They take alot longer to freeze and thaw and can save your stock if you have a power failure. Keep non-critical things like ice cream, ice, and other thing towards the top for quicker access.
May 10, 2010 | Frigidaire 12.8 cu. ft. Chest Freezer...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Freezer not cold enough to freeze items solid
Jan 28, 2008 | Frigidaire GLRS264ZA Side by Side...
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
