Question about HP DeskJet 882c InkJet Printer
Where does power cord go into printer?
Dog got under table where wires/cords were and now I can't tell where to plug the power cord back in. There is a space in the back that doesn't have a cord but the power cord has 2 holes that don't match up to the space available (without a cord in the back); middle hole. I'm thinking maybe there was so sort of adapter piece that either got eaten by dog or vacuumed up.
  • bshumphrey
    bshumphrey Jan 09, 2013
    The cord is intact and not chewed but the end not plugged into the powerstrip, the end that goes into the printer somewhere has two holes (that are supposed to be there) and the only place I can see that it must plug into, doesn't seem to match up. I guess what I need is an illustration of where the cords go and what the cords look like. I'm guessing, maybe there was possibly another piece that fell off or got vacuumed up or eaten by the dog caue what I've got on the end of the cord doesn't seem to match up to the available place to put a cord. Then again, I may not even be looking in the right place to reattach it. Is it possibly hidde somewhere?
  • HP Master
  • 1,121 Answers
Pl check WMV..
Posted on Jan 06, 2013
5 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: HP Psc 1410v All-in-One Printer Power cord And adapter
Check www.hp.com partsurfer or eBay
Posted on Jan 09, 2009
leroyal
  • 2120 Answers
SOURCE: Hp PC 1410v All-in-One Printer Power cord and Adapter
Check www.hp.com partsurfer or eBay.
  • 8404 Answers
SOURCE: my dog chewed the cord in half! ?? dog is ok
Yea yea yea ... blame it on the poor dog ...
Is this printer a 110 VAC into the device or is it powered by a transformer?
If by a standard cord, use any computer cord. If by a transformer, there is that possibililty you can repair the broken wire by removing the damaged portion and reconnecting the two ends. Pay attention to the marks on the wire (white mark or ridge or color of the conductor). Make sure the two wires are insulated from each other.
If you are not able to effect this repair yourself, or by a neighbor with a such skills, get yourself to the computer repair shop around the corner from where you live and plea your case. Expect to pay $15.00 for this repair job. If you require a new power supply, please check www.hp.com/support for your model, e-bay or Craigs List.
There are a few emergency ideas for you. If it is really really really critical and you can't find or make the repair ... you can always get a new, economy printer to use until you can get this one going again.
Thanks for your interest in FixYa.com
Posted on Feb 22, 2010
nadirsalim
  • 185 Answers
SOURCE: Hello, I was running the vacuum around the
Hmm. Please make sure the new (used) power supply meets both voltage (and most importantly) the amp. requirement for printer.
Posted on Nov 06, 2010
I have a 12 inch chraftsman table saw with 2 wires coming from motor. The wiring diagram inside the cap shows it to be wired for 240 how do I wire that thru a switch and to a three wire recepticle
Not quite sure what your question is - Are you trying to plug a 240 into a 110/120 outlet? Or are you trying to plug this into a 240 3 prong outlet?
Traditionally, table saws don't come with a power cord - you must supply one. Usually on the motor there is a metal plate that describes volts/amps/phase/hp etc. Get the Volts/Amps from this plate, then measure the approximate distance between your table saw and the 240 outlet. The gauge of the power cord depends upon the Volt/Amps and the length of the cord. There are many volts/amps vs length for wire gauge conversions on the net. I always get a bigger wire (smaller gauge) than what is recommended. Expect to pay $100 or more for the cord (don't be cheap here). If you have an under rated cord, you can start a fire, burn up your motor, melt plugs into outlets and have to replace the outlet (don't ask how I know).
I'm a little suspicious of the "white and black" wire from 240 - it's usually "white and red" with a "black" ground. 240 is made from two 120's - opposite sine wave. So black is usually the common ground, while the white and red are the two 120's. Volts between white-red=240, white-black=120, red-black=120. If you're absolutely sure that white-black=240, then you can just connect a ground wire to the motor case. Many home table saws can be wired for 240 or 120 - you need to make sure that you're hooking 240v to the correct wires. If you're uncertain at all, then don't do it.
I have wired 120 to a 240 motor by accident and the motor ran - it had no power and didn't spin at full RPM. You can damage a motor this way, so I wouldn't recommend it. I have never put 240 to a 120 motor - so I don't know what happens (guessing you could burn up the motor coils).
With all that being said, if you have 240 outlet with 3 wire receptacle, then just use a multi-meter to determine the 2 "hot" and the 1 ground. Volts from hot1-hot2=240, hot1-ground=120, hot2-ground=120. If you don't have a multi-meter, buy one (approx $12). Once you have it wired up, then try the motor by flipping the switch on then off again. If the motor didn't spin, then you did something wrong. If it hummed but didn't spin, you have some connections wrong inside of the motor. If it spins the wrong way, then your wiring inside of the motor is wrong (doesn't help to flip the wires on the outlet). If you blew a circuit breaker, then the wiring to the motor is wrong.
Sep 27, 2014 | Saws
Curling iron power cord replacement
Simply get a cord of the same amperage and voltage, strip both cords, splice them, tape them well and you should be good. Keep fido away from the unit, lest he become a corn dog!
Aug 19, 2017 | instyle.com Computers & Internet
OfficeJet 7410 wont boot up.
I would try resetting the power supply.
You can do this by unplugging the power adapter cable from the wall outlet.
Unplug the other end from the printer.
Unplug the power cable portion from the rectangular power adapter.
You should be left with a power cord, a power adapter, and a printer; All three are not plugged into anything. Leave it this way for 30 secs, then retry the turn-on process after plugging the cords back into where they belong. Also, try plugging straight into a wall outlet, and not into a surge protector.
If this is not working still, double check the outlet in question by testing it with an appliance like a hair dryer or lamp.
Bruce
Apr 02, 2012 | HP OfficeJet 7410 All-In-One InkJet...
Can't reset canon pixma mp140
RESET CANON PRINTER
1, Power off the printer
2, Unplug the printer's power cord, wait 5 seconds then plug the power cordback in.
3, Hold the Power button for 6 Beeps
4, Release the Power Button
This will reset the printer and should resolve incorrect cartridge detectionproblems
Feb 26, 2012 | Canon Office Equipment & Supplies
HP 5510v all in one is froze. In the led box it keeps blinking error:oxfoaf8004 Have tried unplugging & plugging several times, popped open cartridge door and had to manually move cartridges,...
  • unplug the power cord from the back of the printer and from the wall outlet
  • hold down the power button for a minute to drain power
  • plug the power cord back in to the wall
  • press # and 3 on the keypad while plugging in the power cord to the back of the printer
  • let go of the keys when the printer starts up
Jul 29, 2011 | HP Officejet 5610 All-In-One InkJet...
All of sudden the fax component will not send or receive. Checked phone jack with plugging in phone and getting dial tone. Lights up/scans/ tells you to dial number but than nothing
Is this HP Printer ?
Disconnect the power cord from back of printer ( while printer is on )
while holding power button printer - connect the cord.
Under Setup - Advance Fax Settings - Turn off ECM
Under Setup - Fax settings - Reduce the Fax Speed to slow
try to send fax.
Jun 19, 2010 | Office Equipment & Supplies
My dog chewed the cord in half! ?? dog is ok
Feb 22, 2010 | HP PSC 1210v All-In-One InkJet Printer
We have the following message on screen. Insert black or photo print cartridge inright stall. We have cleaned contacts, renewed both cartridges, and still have this message. Can you advise as to the...
first make sure that your printer is directly connected to the wall socket.
Now unplug the power cord from thew back of the printer & press and hold the # and 3 keys together and plug in the power cord back into the printer (partial reset). check if it resolves the problem, if not then unplug the power cord from thew back of the printer & press and hold the # and 6 keys together and plug in the power cord back into the printer (semifull reset). check if it resolves the problem, if not then. take out all the cartridges from the printer & unplug the power cord & plug it back in without inserting the cartridges. once the printer powers on it will give you an error "ink cartridges missing" or it will ask you to insert the ink cartridges, then insert the cartridges in the printer 1 by 1 starting from the black (hard reset). This should resolve the problem. please let me know the same
Aug 20, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Hp 2175 all in one displays scanner failed mesage
Performing a partial reset
Follow the steps below to perform a partial reset of the all-in-one:
  1. Unplug the power cord from the all-in-one.
  2. In the table below, locate the button combination for your model.
NOTE:
If your all-in-one model is not listed in the table, your model does not have a partial reset option.
  1. Press and hold the button combination for your all-in-one.
  2. While still holding the buttons down, plug the power cord back in. Release the buttons after the all-in-one starts up.
  3. (FROM THE TABLE) HP PSC 2170 series --Press and hold Cancel and the Left Arrow while plugging in the power cord.
Jun 17, 2009 | HP PSC 2175 All-In-One InkJet Printer
I need a power cord for an emerson tv
Hope the dog is well. Best to go to hardware store and buy a plug to replace yourself. Is it two wires, or three? Is it round or flat cable? Also if this is a continuos problem you might want to get a length of metal clad cable to put over the cord before you put the new plug on.
Mike
Mar 26, 2009 | Emerson EWF2704 TV
Open Questions:
HP DeskJet 882c InkJet Printer Logo
37 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
