Question about Microtek ScanMaker X6 Flatbed Scanner
How to instal the scanner?
Show to me how to install the unit
    Problem Solver:
  • 19 Answers
Well basically, if the machine is WinXP or newer you can plug the unit in the computer while its running (most likely it is connected via USB), when the install wizard pops up on the screen cancel it out and run the installation cd that came with the scanner
Posted on Jan 20, 2009
In spite of the fact that I properly downloaded and installed my ION Film 2 SD Plus Slide and Film Scanner into my Toshiba Laptop computer, I cannot scan anything into it. I repeated the downloading a
i am surprised that it is not a stand alone scanner. for almost the same price i have a wolverine which basically works on mains power, or powered from laptop. it scans and stores the images in the unit. those can be later transferred to the laptop while connected via usb. one question, does the scanner lcd show the scanned image? if not may be something is wrong with the unit itself.
Nov 25, 2014 | ION Audio Film 2 SD Plus Slide and...
KV-S2026C not scanning
does this unit show any error?
how old is this unit> is it under warranty?
Oct 02, 2008 | Panasonic KV-S2026C Pass-Through Scanner
Replaced the toner cartridge and unit will not recognize new cartridge
First Install the Printer Driver.
if the Printer Unable o Scan & show the Error -- There is no TWAIN-compliant device installed. Please Install one & try.
Then U Follw this Tricks.It will solve Ur Problem 100 %.
Click on Add devicesClick on Start - search on scanner word -- click on View scanners & cameras -- Next - Selcet Manufacture Name & select the Printer Device Nname - next - Fiinish.
Mar 08, 2012 | HP Laserjet M2727nf Multifunction Printer
Scans but wont show up in preview
your program may be corrupted. uninstall the device in control panel, remove the usb cable from the back of the scanner, uninstall the software, restart your computer.
without attaching the cable to the unit, install the software: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=23762&prodoid=35836299&infoType=Downloads&platform=Windows
after you begin installation it will ask you to plug in the unit. Do this so the install can finish. after the software is installed, restart the computer and run the program. when you first run the program it should ask you to run a test. make sure the selection for aligning the scanner is selected and RUN THE TEST! a lot of people just skip this but it is very important to do this as the system doesn't know where the initializing point of the scanner is. your computer is like a child. it has to learn too!!!
If you have any problems let me know and please leave positive feedback for me. Jethro
Feb 01, 2011 | Epson Perfection 1670 Flatbed Scanner
INSTALLING SCANNER not working. The scanner icon installer shows in the dock installer process seems to work still cant scan.
what type of scanner? Try to remove the usb cable then restart your pc, after restarting plug again the cable then look at the system tray if the system is installing the scanner, if not unstall it then install again after rebooting.
Nov 19, 2010 | Computers & Internet
Scanner doesn't work
You most probably need to install/re-install the printer/scanner software and scanner manager.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp240#DriversAndSoftware
Above please find your canon drivers, download these and install as Administrator...also make sure you install the scanner driver as well as the printer driver...also you need a Scan manager too..
If you have installed the scanner before you need to remove it from device manager, by removing the drivers. Once that's done, unplug the printer. Then reboot,.(If you have a CD/DVD that came with the unit, you can and should use this, else download the files from the link given) Then install the new software now do NOT connect the device, only connect when/if asked, or at the end of the install and after a reboot, then, plug in the printer/scanner.
It should be detected and install itself, it may ask for drivers if so, show it where they are, and it should proceed and you should now be able to scan and print, now you must use a scanning program, and or the interface that came with the unit, Canon Scanmanager, however, if installed correctly you can also scan into Mspaint, Word, Publisher etc. but there are many free scan manager programs on the 'net. a good one is Vuescan, http://www.hamrick.com/ now the beauty of this program is that is doesn't require any "Drivers" as it has it's own, so as long as the scanner physically works, then this program will scan with it.
Another is Freekapture ,http://www.freewarefiles.com/FreeKapture_program_32165.html
This uses TWAIN drivers, that should install at the same time.
http://www.ehow.com/how_2006169_troubleshoot-scanner-printer.html
http://www.tutorialsweb.com/computers/printers-scanners/Tools-to-troubleshooting-printer-scanner-problems.htm
Above are a couple of DIY sites to help also.
Nov 08, 2010 | Canon PIXMA MP240 All-In-One InkJet...
How to scan a picture?
1. were you able to install the printer software correctly? if yes, please check the epson software in the program files if there a scan/imaging applicatoin installed.
2. if you have adobe photoshop. click import then select your scanner device. it will popo out the scanner software..
Jun 13, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Dell laptop wont recognize ls2000 scanner
The LS-2000 is a "legacy" device to XP and the Nikon software. It needs to be connected to a true SCSI bus adapter, and it's actually pretty finicky about which ones will work in XP. Sorry, you won't be able to use this with your laptop.
Feb 28, 2009 | Nikon LS 2000 Film Scanner
Copier not working shows a flashing L on display
Sharp AL-1553 code
E7 03 Scanner position error 04 Exposure lamp blown 05 CCD calibration error 12 White level calibration error 14 Main board malfunction 15 Exposure lamp blown L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed H2 00 Fusing unit temperature error H3 00 Overheated fusing unit H4 00 The fusing unit doesn't heat up U2 01 Counter error 04 EPROM error CH blinking Dev unit is not properly installed
Nov 18, 2008 | Office Equipment & Supplies
ImageRUNNER 1600 E100 System Error
if a little part of drum is broken the door of laser is closed. J am sorry for my english .
Mario. (Rome-Italy)
Nov 26, 2007 | Canon ImageRunner 1600 Copier
Open Questions:
Microtek ScanMaker X6 Flatbed Scanner Logo
176 people viewed this question
Top Microtek Office Equipment & Supplies Experts
Alun Cox
Tony
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
