Question about Coleman Air Tools & Compressors
Kobalt air compressor 37296
Trips circuit breaker
  • 4 Answers
SOURCE: Air compressor trips breaker
check the ground wire most common mistake
Posted on Nov 19, 2008
  • 89 Answers
SOURCE: kobalt air compressor problem plastic tube gets a hole
EVERYONE WANTS TO MAKE EVERYTHING PLASTIC THESE DAYS. REMOVE PLASTIC LINE AND REPLACE WITH 1/4" FLEXIBLE COPPER ( ANY KIND ) JUST PICKUP A SMALL ROLL AT A HARDWARE STORE. MAKE SURE YOU GET A COUPLE OF FITTINGS, NUTS AND/OR FERRELS. HOPE THIS HELPS, JODY
Posted on Apr 20, 2009
  • 5 Answers
SOURCE: need wiring diagram for a kobalt 60 gallon 3.7 hp
I have a Kobalt 60 Gal 3.7 hp air compressor. Send me your email address and I'll make sure you get your schematic. Hope this helps! MichaelGG@health.ok.gov
Posted on Jul 15, 2009
  • 98 Answers
SOURCE: breaker relay tripping out
If the unloading valve trips , which i think is the safety valve that tells me the compressor is pumping up past its maximum allowed pressure. that black switch should be the overload switch. check the amps of the wires going to the motor while its running and then look at the name plate of the motor to see the maximum amount of amps that the motor is allowed to draw.
Posted on Jul 21, 2009
SOURCE: Air compressor starts slowly and then trips 20 amp breaker.
jsd
Posted on Mar 07, 2010
How do i fix my central air conditioner from tripping the circuit breaker?
tripping circuit breakers indicate shorts in the system or overload from a compressor failure
call in a technician to properly diagnose the problem and get a quote
Jun 01, 2016 | Heating & Cooling
Where to get a circuit breaker for a 2hp 5gal kobalt air compressor
Such equipment is mostly of generic far-Eastern manufacture and few spare parts and even less information tend to be available.
Such spare parts as are available tend to be either parts salvaged by the dealer from returns or generic parts which aren't always exactly interchangeable. By circuit breaker I assume you mean the pressure start/stop/isolator switch? Ask the seller who might say no (not surprising).
You might find a similar switch on ebay. Switches on larger higher quality compressors do the same job but if you have to resort to buying one of those you could discover a new compressor is cheaper.
Mar 28, 2016 | Air Tools & Compressors
What causes caravan aircon to trip circuit breaker on start up
My first guess would be that the compressor has seized. If not the compressor seizing, then I would look for a short to ground in the wiring. If you pull the cover of the AC you will most likely find that the compressor motor is plugged into a receptacle. If you can unplug or otherwise disconnect the compressor motor from its' power source and activate the thermostat to run and the circuit breaker does not trip, it is the compressor motor. If the circuit breaker trips, then it's in the wiring.
Aug 30, 2014 | Dometic Rooftop RV Air Conditioner
Why does air conditioner trip circuit breaker?
call the technician
indicates a compressor problem
could be a failed start/run capacitor or compress failure
Nov 19, 2017 | Heating & Cooling
Circuit breaker trips after water supply cycle
check the condensor fan in the compressor area and make sure its running if not the compressor will overheat causing high head pressures on the compressor causing it to draw too much current to operate the compressor and kick the breaker out,also make sure the condenser coils there are clean and it has ample air movement away from the wall
Apr 21, 2013 | Kitchen Appliances - Others
Compressor trips breaker on startup or quickly after
The breaker may be too small. Check the amperage requirements against the breaker size.
May 31, 2012 | Craftsman 33 Gallon Vertical Portable Air...
I have a Quick Cool (59516.501) which just started tripping the 20 A circuit breaker. I replaced the circuit breaker. Unit still trips the circuit breaker.
you will need to access the unit and look for burnt/shorted wires on/at compressor. if not then the compressor is locked down/shorted and will need replaced Tim
May 29, 2011 | Dometic Rooftop RV Air Conditioner
What oil should I use if Hitachi oil isn't avalible?
On your next trip to Lowes look for Kobalt air compressor oil in the tool department. It sells for under $3 and works great for normal use. They also have Kobalt synthetic compressor oil for extreme conditions and longer use between oil changes. Sell for about $7. I also used Hitachi synthetic oil #19210b 8oz about $8 but hard to find. Kobalt synthetic costs less and works. Good luck.
Aug 02, 2010 | Hitachi EC12 Portable Electric 2hp Air...
If the unit is new then the unit may be over-sized for the electrical circuit. If the unit is not new then the compressor may be failing
Apr 19, 2010 | Amana PTH153B35AJ Air Conditioner
Problems with kobalt air compressor 26 gal. simply would not start
Check and reset motor thermal overload (red button) on motor, also check circuit breaker for your power supply. other than that the pressure switch is what stars and stops the motor, and depending on your level of knowledge you will need to check continuity through the pressure switch with a ohm meter.
Jan 20, 2010 | Air Tools & Compressors
Air Tools & Compressors Logo
123 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
