Question about Maytag Atlantis MAV6000 Top Load Washer
Water drips after the wash cycle is complete
Machine drips water after wash cycle is completed.
  • Anonymous Jan 20, 2009
    My transmission is shot in my 5 year old machine. Time to get a new one. Piece of ****!
    Novelist:
  • 101 Answers
Check and see if the leaking is coming from the pump. There could be a leak in the hose that comes off the pump or there could be a leak in your pump. If there is a crack or anything on the pump then just replace it and your problem will be fixed. It's an easy and cheap fix. The pump is located right at the front of the washer on the front of the motor. Just make sure you clamp off the hoses with hose clamps before taking the pump off or you will have water every where. I hope this helps you and if you have any other questions feel free to ask. Good luck.
Posted on Jan 22, 2009
3 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: water drips into washer tub after washing machine
The problem is caused by a sticking water inlet valve/s.
Only solution is to replace unfortunately.
Please rate my solution.
Thankyou.
Posted on Jan 17, 2010
Testimonial: "Thank you it was very helpful"
SOURCE: Water continues to drip in after complete cycle
I just fixed this same problem.
The issue is that the valves are not fully closing because debris is preventing them from seating.
To fix, from the rear of the machine
1: Turn off water, unplug, and disconnect hot and cold lines.
2: Take off top panel (three screws)
3: Unhook hose at on valve at Water Outlet
4: Remove valve (one screw).
5: Using compressed air, blow air into the Water outlet.
This will probably open the valves, so you can pour water into the Water outlet. Use more compressed air to clean out the unit.
When you are done you the valves will probably be open, thus you might be able to blow into the water outlet (that is OK).
The goal is to remove any sediment in the valves.
Reinstall. When you the water is hooked up, the water pressure should force the valves closed.
Test by running the washer, then let it sit for a 12 hours. If you do not have any standing water, your valves are seating properly.
Worst case you can buy a new valve assembly for about $30.00
Posted on Jun 24, 2010
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
Water continues to drip into the tub even after all cycles have completed. my tub is filling up with water, I have turned off the water to the machine but it continues.
The water inlet valve needs to be replaced. It's not shutting off the water completely. It's located where the water hoses connect to the washer.
Oct 09, 2010 | Maytag Washing Machines
Keeps filling up with water even on spin
Close the water supply valve and allow the machine to completely drain the water from the tub. Turn off the machine and disconnect it from the power outlet. Open the water supply valve. Replace the water inlet valve if water drips into the tub when the machine is off.
Start a new cycle if the machine stops filling when it is off. The control board or the water level switch is malfunctioning if it keeps filling even during the spin cycle. Indicate the model number for proper troubleshooting and repair assistance.
Feb 05, 2010 | Washing Machines
Water drips into washer tub after washing machine has completed its cycle
Thankyou.
Jan 17, 2010 | Washing Machines
Unit will not complete wash cycle that uses hot or warm water
do you have cold? will stop at rinse cycle and hum if you have no cold
Jan 09, 2010 | Washing Machines
Fisher & Paykel GWL11
After several loads, the drip stopped. I'd guess a valve was not closing completely.
Mar 31, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washer continues to drip into tub after cycle in complete.
contstant water dripping into tub sounds like a bad water valve, no repairing valve just replace it
Feb 25, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
127 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
