Question about Hotpoint TDC32 Electric Dryer
My Hotpoint electric dryer only buzzes when I turn the start button will not come on
Reatern it if you can
Posted on Jan 06, 2013
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Hotpoint TDC62p is making a buzzing/humming sound and the drum will not spin though it does move if you push it.
Either something is binding the blower wheel up or the motor is bad. The best thing is to take the front of the machine off to access the blower wheel to verify ifanything is indeed binding it.IF not read the next section.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
May 17, 2012 | Hotpoint Tumble Dryer Tdc60n Tdc60p Tdc60s...
When I push the "Start" button there is a buzzing
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 15, 2011 | Fisher and Paykel DE06 Electric Dryer
Dryer will not start when I push the start button. All I get is a loud buzzing.
The buzzing is a good sign that the motor is bad...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Oct 11, 2010 | Maytag MDE9700AYM Electric Dryer
Maytag dryer makes an electrical buzzing noise when start button
It sounds to me like the motor is not turning, but the heating element is coming on. with no air flowing over the element, it is getting too hot. Can you operate the start switch with the top tilted up so you can see if the motor is turning but the drum is not, and just where the buzzing is coming from. Also, I would try the dryer on manual setting and on air dry to see if any setting works. Good luck
Jan 07, 2010 | Maytag MDE6000 Dryer
Hotpoint year 2000 Ser.GZ700149A
The problem was the buzzing noise when I turned the switch on. A repairman said to try holding the door switch down and then turn the
switch on and turn the inside with my hand and it happened to start turning again. He gave me that information over the phone. I thank the Lord for his information.
Dec 28, 2009 | Hotpoint NBXR463EBWW Electric Dryer
Whirlpool LER 5436 tumble drier- loud buzz
When start button is pushed there is a buzzing noise but dryer will not start.
Oct 21, 2009 | Whirlpool LER4634J Electric Dryer
Turned knob and got a buzz. turned knob again and no sound. Just finished a load and was starting on the next.
Hi. im assuming the buzz came from the timer knob(behind the knob). if so, this will confirm timer failure and, you will need to replace this timer control module in order to restore proper function to your unit.
If the buzz was located behind the start switch, replace as well.
May 21, 2009 | Hotpoint Dryers
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
Just buzzes
 the only thing you can do to possibly solve this problem without a professional is to:
  • tape down the door switch with strong tape, or have someone else hold it down.
  • physically turn the tub inside the dryer while pushing the start switch.
  • this will hopefully loosen whatever has the motor stuck.
if this does not work then the motor in the dryer might be bad or going bad, especially if a burning smell is present when you hear the humming sound.
Jul 25, 2008 | Hotpoint NVL333EY Electric Dryer
Hotpoint TDC32 Electric Dryer Logo
64 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
