Question about Hoover Max Extract Dual V WidePath Carpet Washer
How to remove the bottom filter from a Hoover Max Extract Dual V
How to remove bottom filter from a Hoover Max Extract Dual V Carpet Cleaner
Why doesn't the water pick up on my carpet shampooer???
Hi Julie! If the cleaner is not picking up the dirty water this usually means something is not sealed off properly. Try these steps below to restore suction to your cleaner.
1. Remove the clean water tank. Recline the handle & let the handle lie down on the floor.
2. Remove the dirty water tank. Check that the dirty water tank cap is on the dirty water tank and tightened closed.
3. Clear the filter screen of any hair or debris.
4. Remove the nozzle. Clean the nozzle of any hair or debris.
5. Located on the machine behind the nozzle is a 2nd filter screen. Clean it of any hair or debris.
6. Replace the nozzle.
7. Replace the dirty water tank. Press down on all sides so that it is flush to the cleaner base.
Give it a try! The suction should be restored to your cleaner. If not I have included a video link where you may view these instructions. Hope this helps! Loss of Suction Won pick up Hoover Max Extract 77 FH50230 FH50222...
Nov 02, 2014 | Hoover Max Extract 77 Multi-Surface Pro...
Why would hoover carpet cleaner make a loud noise, start smoking and now won't come on.
I'm afraid you burned a coil in the motor. And accidentally it stopped while that coil is between the contact brushes. Or one of the (or both) brushes are worn.
Sep 20, 2014 | Hoover Max Extract Dual V WidePath Carpet...
How to use the upholstery attachment for hoover max extra 60 carpet cleaner?
Hey there! The nozzle/valve that releases the solution from the hose may be clogged and not closing off to stop the solution flow. You can try soaking the trigger end in warm water for a few hours to unclog it. Also make sure you are inserting the hose back into the hose slot in the back of the cleaner. If the cleaner is still dispensing from both the hose and the cleaner, your nozzle/valve assembly may need to be replaced. To order a replacement nozzle/valve assembly follow the link below.
Search Results
Hope this helps!
Aug 30, 2014 | Hoover Max Extract 60 Pressure Pro Carpet...
How to remove nozzle for cleaning
Hi! We made the nozzle assembly easily removable for the Max Extract Dual V. Follow these quick steps.
Remove both tanks from the cleaner.
Lay the cleaner on its back while in the upright position.
Lift up rear edge of nozzle. Slide nozzle up and remove from cleaner.
I have also attached a copy of the owner's manual which has pictures if you need it. http://hoover.com/file/1088/
Hope this helps!!
Aug 13, 2014 | Hoover Max Extract Dual V WidePath Carpet...
Why does my hoover max extract leak water onto the floor?
seals faulty, replace or shop replacement if within guarantee
Jun 28, 2014 | Hoover Max Extract 77 Multi-Surface Pro...
How do I clean cat hair out of spin brissels
Hey there! The brushes can be removed for cleaning. With the handle in the upright position, tilt the cleaner back so that handle rests on floor. Grab brush assembly and pull firmly. Remove hair and debris from brushes. You may clean the brushes under running water. If for some reason you are not able to clean the brushes, replacement brushes can be ordered by following the link below.
Search Results
Jun 12, 2014 | Hoover Max Extract 60 Pressure Pro Carpet...
How do I fix pin at bottom of clean water tank?
Replace the part. This might mean buying a whole new water tank. You can order most parts online. Have your make and model ready. Find a site by google. ie if it's a hoover enter, "hoover parts".
May 12, 2014 | Hoover Max Extract 60 Pressure Pro Carpet...
Hoover max extract 77 wont pick up water
did you make sure the dirty water tank is cleaned out and the cap is on?also did u check the clear kinda hour glass shaped thing in the front where the water sucks up at to make sure there is no blockadge?
Mar 30, 2014 | Hoover Max Extract 77 Multi-Surface Pro...
My max extract is making a whiring sound and i can smell rubber burning
The beater brush is binding in a locked up state. Probably by hair and carpet fibers. Dis-assemble and clean out any debris and change the belt/
Jan 31, 2014 | Hoover Max Extract Dual V WidePath Carpet...
Hoover Max Extract Dual V WidePath Carpet Washer Logo
73 people viewed this question
Top Hoover Air Purifiers Experts
Thatvacguy.com
Are you a Hoover Air Purifier Expert? Answer questions, earn points and help others
