Question about 126307 Flip FiberMax 2004-2012 FORD F150 Regular, Super Cab &
Vibration in drive at stoplight withfoot brake on. disappears in neutral.
  • 1 more comment
  • Sam Black Jan 09, 2013
    Mech. it was mtr
    mech. said it was mtr. mounts but when he changed them it got worse.
  • darryl Jun 29, 2014
    what about rear gearbox mount as well.could be loose nuts or bolts
  • BAK Master
  • 16,010 Answers
Torque converter...
Posted on Apr 06, 2013
How to replace the brake light switch on a 1997 grand marquis
REMOVAL
  1. Disconnect the wire harness at the connector from the stoplight switch.
NOTE: Locking tab on connector must be lifted before connector can be removed.
  1. Remove the hairpin retainer and slide the stoplight switch, the push rod and the nylon washers and bushing away from the brake pedal. Remove the stoplight switch by sliding the stoplight switch up/down as required to remove.
NOTE: Since the stoplight switch side plate nearest the brake pedal is slotted, it is not necessary to remove the brake master cylinder push rod and one spacer washer from the brake pedal pin.
INSTALLATION
  1. Position stoplight switch so that the U-shaped side is nearest the brake pedal and directly over or under the pin. Then slide stoplight switch down or up trapping the master cylinder push rod and black bushing between the stoplight switch side plates. Push stoplight switch and push rod assembly firmly toward brake pedal arm. Assemble outside white plastic washer to pin and install hairpin retainer to trap whole assembly.
CAUTION: Do not substitute other types of pin retainers. Replace only with a production hairpin retainer. Component damage may occur.
  1. Assemble the wire harness connector to the stoplight switch.
NOTE: Stoplight switch wire harness must have sufficient length to travel with stoplight switch during full stroke of brake pedal. If wire length is insufficient, reroute harness or service as required.
  1. Check stoplight switch for proper operation.
Dec 18, 2015 | 1997 Mercury Grand Marquis
When I stop at a stoplight and put my foot on the brake while the Car is in drive the car vibrates but when I put it in neutralit vibrates less
There are several reasons this could be happening.could be engine or transmission mounts are bad,could need a tune up possible idle control motor,how does the car run going down the road.
Oct 11, 2015 | 2005 Hyundai Elantra GLS
Vibrates at idle RPM
Duplicate question.
May 17, 2013 | Cars & Trucks
Why does my 2005 Corolla vibrate at idle?
chech your pvc value first if that does not fix it it could need a new intake gas
Jan 06, 2012 | Cars & Trucks
2007 Mazda CX-9 has recently developed a front end vibration under heavy acceleration. Vibration disappears if shift to neutral at highway speed, engine rev's smoothly in neutral. Suspect engine...
Try to rev the engine while at neutral if you get the same vibration to pinpoint if its from the engine or the drive shafts. If the issue occurs at a certain rev it may likely be the variable valve unit. Check if possible if you can get errors from the computer.
Sep 08, 2011 | 2007 Mazda CX-9
Abs has caused brake lights to fail
Check the wires going to the stoplight switch on the brake pedal. If one of them is broken (gray wire or green wire) it can cause this problem. Or it may be the stoplight switch itself. Let me know what you find.
Jun 24, 2010 | 1997 Ford Econoline
Ford F150 vibrates at low idle.
sounds like exhaust system is grouding against the frame
Dec 30, 2009 | 2005 Ford F-150
2007 nissan frontier/Vibration at idle
Have you tried checking the exhaust heatshields?
Apr 15, 2009 | 2006 Nissan Frontier
03 sonata
Where do you feel the vibration? if you feel it where you sit it is coming from back which is usually rear brakes. If you feel the vibration in your feet and hands it is coming from the front which could be your ABS or front brakes.
Sep 06, 2008 | Hyundai Motor 2003 Sonata
126307 Flip FiberMax 2004-2012 FORD F150 Regular, Super Cab & Logo
71 people viewed this question
Top BAK Vehicle Parts & Accessories Experts
Leighton Hurry
Level 1 Expert
Lawrence Oravetz
Are you a BAK Vehicle Part and Accessory Expert? Answer questions, earn points and help others
