Question about Frigidaire FEQ332E Electric Dryer
Kenmore dryer model 41780042990
Can someone tell me why my dryer gets very hot on the top and the back of the dryer and doesn't seem to dry the clothes as fast. It's a kenmore model 41780042990.
thanks
  • Fridgy69 May 11, 2010
    Does it turn?
    How clean is your filter?
  • 61 Answers
Sounde like you have a clogged vent line be shure the vent hose is not cinked in any waty that would restrict the air flow. Next turn the dryer on and make sure you and a good flow of air out side the house if the air is not blowing out the vent out side you will need to clean this out or have it cleaned.
Posted on Jan 20, 2009
Kenmore electric dryer won't dry clothes. The
What is the model number of your unit?
Nov 17, 2012 | Dryers
Dryer doesn't seem hot enough
how do you nget front panel off dryer
May 20, 2010 | Kenmore 63942 Dryer
I am having a problem with a 41780042990 dryer
2 things can cause this. 1st the felt bearing at the front that the tub rides on may be worn the 2nd is the rear bearing that the tub actually attaches into. one of these is bad or going bad.
Apr 12, 2010 | Dryers
My kenmore series dryer does not heat. the timer
the heater element has two parts to the heat coil if one of the coils breaks it will not get hot enough to heat the load all the way to set of the sensor to stop . it seems like you need to replace your heat element . if you want to know how to take it apart i have a couple of posts that tell how or reply back the coil costs about 89 dollars you can get one pre strung for around double the cost
Feb 25, 2010 | Kenmore 63942 Dryer
Kenmore dryer gets really hot on top of the dryer, not while clothes are drying but when finished, kinda scary?
Remember heat rises. However if it burns your hand or you can smell something you need to unplug the power to it asap. Most of them come with a one year in home service repair. It takes a while the heating elements to get hot in the dryer so that's probably why it seems its getting hot on top after the clothes have been in for a while.
Sep 03, 2009 | Dryers
Kenmore front load dryer will not heat
Most likely a bad thermo-fuse also called a high limit. Not hard to fix and cost little.
Please rate solution if helpful
Aug 25, 2009 | Kenmore 62872 Electric Dryer
Overheating/burnt rubber smell
classical sign of a bad motor. the motor has a thermal switch on it telling the unit to shut off when it gets hot. after it cools down, the switch will tell the motor to turn back on again. good luck, i'm pretty sure that's your problem. contact me for further help if needed. thanks :)
Jul 06, 2009 | Kenmore 73952 Gas Dryer
Dryer
Disconnect the vent from the back of the dryer and dry a load unvented too make sure you don't have lint built up in the vent line causing an air flow restriction.
Jul 30, 2008 | Kenmore Dryers
Kenmore Dryer model 41783142300
this is an airflow problem. make sure you are using a rigid metal duct behind the machine and not a flexible one. clean out the exhaust duct behind the dryer and in the wall all the way to the  outside. any residue of lint inside these ducts will increase drying time dramatically. basically clean everywhere the air flows.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
  • picture is from fixitnow.com
Jul 21, 2008 | Kenmore Dryers
Frigidaire FEQ332E Electric Dryer Logo
231 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
